Login on OS6900 via NPS
tds85
Re: Login on OS6900 via NPS
Post by tds85 »
I will try this, but isn't this traffic encrypted?
We had to go to this release for this customer since we were facing some bugs (arp issues) that should be solved in this release.
devnull
Post by devnull »
I 'd go with the 7.3.3.589 (?) which was released on same date, they should have all the fixes included. 7.3.4 only when i'd have a 6900-Q32 (unfortunately not). But this is just my opinion.
Radius is not encrypted. Password is hashed the switches don't support eap which would afaik encrypt the whole Radius communication.
I would guess you can see radius communication in cleartext.
tds85
Post by tds85 »
I removed the radius configuration and added it again on my switch and suddenly it works, I don't know what was wrong before, since communications seemed to be ok and since I saw the failed tries on the NPS.
So case closed ;-) thanks for the help though.
Locked
Return to “OmniSwitch 6900”
