Hi there
the core switch 6900 has the log like this and the ip phone sometimes can't get ip address from dhcp server. If I restart the ip phone and waiting a long time, sometimes it can get ip address, but sometimes not.
Tue Jun 2 08:43:08 : udpRelay main warning message:
+++ bootpGWHandleRequest(): sendto problem: Invalid argument
Tue Jun 2 08:44:17 : udpRelay main warning message:
Tue Jun 2 08:45:19 : udpRelay main warning message:
6900 udprelay waring
Re: 6900 udprelay waring
Which release are you running?
There were a couple of dhcp-relay bugs fixed in the last 7.3.3.598 if i recall it correct.
God, This is core switch!!!!devnull wrote:Which release are you running?
You can always open a TAC case.
If you have a VC you can try an issu (in my experience: still plan for a maintanance window).
Otherwise: plan a maintenance Window.
Even if it is a core Switch: also this devices need a software upgrade from time to time.
Thanks a lot! I means I can't believer that the core switch has dhcp-realy bugs !devnull wrote:You can always open a TAC case.
I'll ask for update the software and thanks again !
