change Chassis ID of a VC member
dpmp
Postby dpmp » 21 Jul 2016, 03:44
Hi @ all
I have two questions:
1) Best practice or easiest way to change the chassis-id of a virtual chassis member?
2) With microcode 7.3.4 is theire a way to convert chassis from virtual chassis mode to standalone mode.
(For the other way - standalone to vc mode - are a lot of instructions available.
Best regards
I tried the following to change the chassis id
show microcode
/flash/certified
Package Release Size Description
Tos.img 7.3.4.248.R02 211794508 Alcatel-Lucent OS
show virtual-chassis consistency
Legend: * - denotes mandatory consistency which will affect chassis status
licenses-info - A: Advanced; B: Data Center;
Config Oper Oper Config
Chas Chas Chas Hello Control Control
Chas* ID Status Type* Group* Interv Vlan* Vlan License*
1 1 N/A OS6900 11 10 4094 4094 A
show virtual-chassis vf-link
VFLink mode: Static
Primary Config Active Def Speed
Chassis/VFLink ID Oper Port Port Port Vlan Type
1/0 Down N/A 2 0 1 Unassigned
show virtual-chassis vf-link member-port
VFLink mode: Static
Chassis/VFLink ID Chassis/Slot/Port Oper Is Primary
1/0 1/2/1 Down No
1/0 1/2/2 Down No
show configuration vcm-snapshot chassis-id 1
! Virtual Chassis Manager:
virtual-chassis chassis-id 1 configured-chassis-id 1
virtual-chassis chassis-id 1 vf-link 0 create
virtual-chassis chassis-id 1 vf-link 0 member-port 1/2/1
virtual-chassis chassis-id 1 vf-link 0 member-port 1/2/2
virtual-chassis chassis-id 1 chassis-group 11
virtual-chassis chassis-id 1 configured-chassis-priority 200
! IP:
ip interface local chassis-id 1 emp address 10.214.6.111 mask 255.255.255.0
virtual-chassis chassis-id 1 configured-chassis-id 2
ERROR: Cannot change the chassis identifier while virtual-fabric links are configured (@1336)
no virtual-chassis chassis-id 1 vf-link 0
ERROR: Cannot delete a virtual-fabric link that has member ports configured (@2786)
cedric1
Re: change Chassis ID of a VC member
Postby cedric1 » 21 Jul 2016, 04:17
Hello
If you want to move from ID 1 to ID 2
Edit with vi vcsetup.cfg file
Exemple of file you need to have
show configuration vcm-snapshot chassis-id 2
virtual-chassis chassis-id 2 configured-chassis-id 2
virtual-chassis vf-link-mode static
virtual-chassis chassis-id 2 vf-link 0 create
virtual-chassis chassis-id 2 vf-link 0 member-port 2/2/1 ## Take care to change form 2/2/1 to 2/2/1
virtual-chassis chassis-id 2 vf-link 0 member-port 2/2/2 ## Same chassis id will change and need to find new port reference
virtual-chassis chassis-id 2 chassis-group 11
! IP:
ip interface local chassis-id 2 emp address 1.2.2.2 mask 255.255.255.0
Save via vi
reboot the switch.
Group value can be changed online but for chassis id this is my method.
Cedric
cedric1
Postby cedric1 » 21 Jul 2016, 04:23
My method to move form VC to standalone
-> remove vcsetup.cfg and vcboot.cfg
-> reboot
When I m working in a network where i have vc and no vc , I configure all switches with vcsetup.cfg file
If there is only one member ( same as standalone) I dont configure vf-link.
I do this to have same interface format on all switches x/y/z and not a mix of x/y/z and x/y for real standalone switch.
Cedric
dpmp
Postby dpmp » 21 Jul 2016, 07:52
many thanks for your fast response.
I know the methode of editing the vc_setup.cfg. But I thought there would be an more smart way to change the chassis id
sputniki
Postby sputniki » 21 Sep 2016, 03:24
dpmp wrote:many thanks for your fast response.
I know the method of editing the vc_setup.cfg. But I thought there would be an more smart way to change the chassis id
I remember that I tried both methods: Editing vc_setup.cfg and CLI and I think there should be the "smart way" too:
If you want to convert the chassis with id 3 for example to new chassis id 6 try
virtual-chassis chassis-id 3 configured-chassis-id 6
If you want to move back a VC chassis-member (f.e. chassis id 3) to standalone I guess you could set configured chassis-id to zero
virtual-chassis chassis-id 3 configured-chassis-id 0
But wether you edit vc_setup.cfg or use the commands - you have to reboot the chassis you want to change:
reload chassis-id 3
Please be careful, I didn't actually checked this. ;-)
PS: If anyone is asking why it could be a better idea to use cli than simply editing the vc_setup.cfg instead: It's a bit more secure then trusting, that you don't make a typo or remove the wrong vc_setup.cfg
Return to “OmniSwitch 6900”
Who is online
Users browsing this forum: No registered users and 3 guests
