port monitoring output reading
Anirudhh-123
Post by Anirudhh-123 » 06 Dec 2016 06:42
In os6900-x20 start the port monitoring for one port and stop after some time and extract the port monitoring output and open in wireshark.
But in wireshark captured output showing after two days date and some random time.
All switches are sync with ntp server.
Please help
It is difficult when searching for root cause of the some problem due to the time difference between captured output and switch time.
Anirudhh
Re: port monitoring output reading
Post by silvio » 06 Dec 2016 14:00
I have used port monitoring very often with other switches. Time was okey. So you should open a SR at Alcatel to solve the issue. Maybe this is a known issue. Than you can look in releasenotes.
Return to “OmniSwitch 6900”
