OMNISWITCH-6900 connection with controller 4550
Hi All,
I need to connect the core switch of alcatel 6900-X20 with controller i have created the new vlan 10 in the controller & in core switch as well both are connected by Fiber.
But still i cant able to ping the controller ip from the core switch & vice-versa.
Please can anyone help me to resolve the same.
Re: OMNISWITCH-6900 connection with controller 4550
You will understand, that we are not able to understand your setup until you provide more details?
So I would check at first if there is set up an IP interface on VLAN 10 for both devices in the same subnet.
And the port to the WLAN Controller is untagged (or tagged) on both devices.
And there is no additional cable between 6900 and 4550 (RSTP will block one of these links, afaik there is no 1x1 on 4550.
Provide configs / more details
devnull wrote:And the port to the WLAN Controller is untagged (or tagged) on both devices.
Thanks for your information
I made the connection ready now it is working
i made trunk port in controller & core switch i made as untagged port now i can able to reach from core switch to controller & vice versa but i was not able to reach the edge switch which is installed in one of guest floor in the hotel.
what configuration to be done to make communicate between 3 (wlan controller+coresw+6450) ?
please i want to make all the Access points which is connecting in the edge switch 6450 and to all the AP's ip will be given by controller dhcp
Please help me
In controller
i create vlan 10 with ip interface 10.200.200.11 mask 255.255.248.0 for the port 2 of controller
In core switch
i create vlan 20 with ip interface 10.200.200.1 mask 255.255.248.0 for the port 1/1/13
port 13 is untagged
In edge switch
i create vlan 50 with ip interface 10.200.200.1 mask 255.255.248.0 for the port 1/49 where the fiber up links coming from the core switch.
Also i tried configured the edge switch port both tagged & untagged but still i was unable to reach the edge switch from the core & controller & viceversa.
Hussain
In core switch
port 13 is untagged
In edge switch
Hussain
Scenario : connecting controller+core sw+edge sw -where Access points are connecting there is a one fiber up-link from controller to core sw & also from core sw to edge switch one fiber up link access points need to get the ip from DHCP of controller.
i need your support actually i configured controller vlan 10 as trunk port & core switch as vlan 90 as untagged after that in edge switch i configured as vlan 112 as default
i connected the laptop in edge switch i can able to ping the controller ip from edge switch continuously but from edge switch to core switch was not pinging continuously im getting random REQUEST TIMED OUT once again it starts to ping ?
What could be the issue & whether my configuration is right?
The problem got resolved after giving dhcp mode in laptop and then when i try to ping the controller & core switch pinging is 100% without RTO.
In the Edge switch 6450-POE-48(1) the fiber up-link is directly coming from the core switch to port no 49 and all the other 4 switches are stacked each other
like
6450-P48 - 1 -------------- FOR ACCESS POINTS
6450-48- 2 --------------- FOR DATA
6450-48- 3 ---------------- FOR IPTV
6450-P24- 4 ------------------FOR AP
6450-24-5 5 ----------------- FOR BOTH DATA & IPTV
But now what is the problem i cant able to reach my core switch from other 4 switches not from the 1 one.
i trying to put my laptop in the other than 1 switch and try to ping the core switch IP 10.200.200.1 it is giving destination host unreachable
what could be the issue?
then how the 4 switches will communicate with core switch
Configuration done in the core switch as follows :
-> show vlan members port embers
vlan port type status
90 1/1/13 default forwarding ---------------------------------->>>>>>> fiber up-link from controller to core switch
-> show vlan
vlan type admin oper ip mtu name
1 std Ena Ena Dis 1500 VLAN 1
10 std Ena Dis Dis 1500 VLAN 10
90 std Ena Ena Ena 1500 VLAN 90
4094 vcm Ena Ena Dis 1500 VCM IPC
-> show ip interface b
Total 7 interfaces
Flags (D=Directly-bound)
Name IP Address Subnet Mask Status Forward Device Flags
EMP-CHAS1 192.168.10.1 255.0.0.0 DOWN NO EMP
EMP-CMMA-CHAS1 0.0.0.0 0.0.0.0 DOWN NO EMP
EMP-CMMA-CHAS2 0.0.0.0 0.0.0.0 DOWN NO EMP
Loopback 127.0.0.1 255.255.255.255 UP NO Loopback
dhcp-client 0.0.0.0 0.0.0.0 DOWN NO unbound
int-50 0.0.0.0 0.0.0.0 DOWN NO unbound
vlan-90 10.200.200.1 255.255.248.0 UP YES vlan 90
Configuration done in Edge switch as follows:
Welcome to the Alcatel-Lucent OmniSwitch 6450
Software Version 6.6.5.63.R02 GA, December 16, 2014.
Copyright(c), 1994-2014 Alcatel-Lucent. All Rights reserved.
OmniSwitch(TM) is a trademark of Alcatel-Lucent registered
in the United States Patent and Trademark Office.
-> show vlan port
1 1/50 default inactive
1 2/49 default inactive
1 2/50 default inactive
1 3/50 default inactive
1 4/3 default inactive
1 4/4 default inactive
1 4/5 default inactive
1 4/6 default inactive
1 4/7 default inactive
1 4/8 default inactive
1 4/9 default inactive
1 4/10 default inactive
1 4/11 default inactive
1 4/12 default inactive
1 4/13 default inactive
1 4/14 default inactive
1 4/15 default inactive
1 4/16 default inactive
1 4/17 default inactive
1 4/18 default inactive
1 4/19 default inactive
1 4/20 default inactive
1 4/21 default inactive
1 4/22 default inactive
1 4/23 default inactive
1 4/24 default inactive
1 4/25 default inactive
1 4/26 default inactive
1 5/3 default inactive
1 5/4 default inactive
1 5/9 default inactive
1 5/10 default inactive
1 5/11 default inactive
1 5/12 default inactive
1 5/13 default inactive
1 5/14 default inactive
1 5/15 default inactive
1 5/16 default inactive
1 5/17 default inactive
1 5/18 default inactive
1 5/19 default inactive
1 5/20 default inactive
1 5/21 default inactive
1 5/22 default inactive
1 5/23 default inactive
1 5/24 default inactive
1 5/25 default inactive
1 5/26 default inactive
112 1/1 default forwarding
112 1/2 default inactive
112 1/3 default forwarding
112 1/4 default inactive
112 1/5 default forwarding
112 1/6 default inactive
112 1/7 default forwarding
112 1/8 default inactive
112 1/9 default forwarding
112 1/10 default inactive
112 1/11 default forwarding
112 1/12 default inactive
112 1/13 default forwarding
112 1/14 default inactive
112 1/15 default forwarding
112 1/16 default inactive
112 1/17 default forwarding
112 1/18 default inactive
112 1/19 default forwarding
112 1/20 default inactive
112 1/21 default forwarding
112 1/22 default inactive
112 1/23 default forwarding
112 1/24 default inactive
112 1/25 default forwarding
112 1/26 default forwarding
112 1/27 default forwarding
112 1/28 default inactive
112 1/29 default forwarding
112 1/30 default inactive
112 1/31 default forwarding
112 1/32 default inactive
112 1/33 default forwarding
112 1/34 default inactive
112 1/35 default forwarding
112 1/36 default inactive
112 1/37 default forwarding
112 1/38 default inactive
112 1/39 default forwarding
112 1/40 default inactive
112 1/41 default forwarding
112 1/42 default forwarding
112 1/43 default inactive
112 1/44 default forwarding
112 1/45 default forwarding
112 1/46 default inactive
112 1/47 default forwarding
112 1/48 default inactive
112 1/49 default forwarding
112 4/1 default forwarding
112 4/2 default forwarding
1112 3/1 default inactive
1112 3/2 default inactive
1112 3/3 default inactive
1112 3/4 default inactive
1112 3/5 default inactive
1112 3/6 default inactive
1112 3/7 default inactive
1112 3/8 default inactive
1112 3/9 default inactive
1112 3/10 default inactive
1112 3/11 default inactive
1112 3/12 default inactive
1112 3/13 default inactive
1112 3/14 default inactive
1112 3/15 default inactive
1112 3/16 default inactive
1112 3/17 default inactive
1112 3/18 default inactive
1112 3/19 default inactive
1112 3/20 default inactive
1112 3/21 default inactive
1112 3/22 default inactive
1112 3/23 default inactive
1112 3/24 default inactive
1112 3/25 default inactive
1112 3/26 default inactive
1112 3/27 default inactive
1112 3/28 default inactive
1112 3/29 default inactive
1112 3/30 default inactive
1112 3/31 default inactive
1112 3/32 default inactive
1112 3/33 default inactive
1112 3/34 default inactive
1112 3/35 default inactive
1112 3/36 default inactive
1112 3/37 default inactive
1112 3/38 default inactive
1112 3/39 default inactive
1112 3/40 default inactive
1112 3/41 default inactive
1112 3/42 default inactive
1112 3/43 default inactive
1112 3/44 default inactive
1112 3/45 default inactive
1112 3/46 default inactive
1112 3/47 default inactive
1112 3/48 default inactive
1112 3/49 default inactive
1112 5/5 default inactive
1112 5/6 default inactive
1112 5/7 default inactive
1112 5/8 default inactive
2047 2/48 default inactive
2201 2/1 default inactive
2202 2/2 default inactive
2203 2/3 default inactive
2204 2/4 default inactive
2205 2/5 default inactive
2206 2/6 default inactive
2207 2/7 default inactive
2208 2/8 default inactive
2209 2/9 default inactive
2210 2/10 default inactive
2211 2/11 default inactive
2212 2/12 default inactive
2213 2/13 default inactive
2214 2/14 default inactive
2215 2/15 default inactive
2216 2/16 default inactive
2217 2/17 default inactive
2218 2/18 default inactive
2219 2/19 default inactive
2220 2/20 default inactive
2221 2/21 default inactive
2222 2/22 default inactive
2223 2/23 default inactive
2224 2/24 default inactive
2225 2/25 default inactive
2226 2/26 default inactive
2227 2/27 default inactive
2228 2/28 default inactive
2229 2/29 default inactive
2230 2/30 default inactive
2231 2/31 default inactive
2232 2/32 default inactive
2233 2/33 default inactive
2234 2/34 default inactive
2235 2/35 default inactive
2236 2/36 default inactive
2237 2/37 default inactive
2238 2/38 default inactive
2239 2/39 default inactive
2240 2/40 default inactive
2241 2/41 default inactive
2242 2/42 default inactive
2243 2/43 default inactive
2244 2/44 default inactive
2245 2/45 default inactive
2246 2/46 default inactive
2247 2/47 default inactive
2248 5/1 default inactive
2249 5/2 default inactive
-> show vlan
stree mble src
vlan type admin oper 1x1 flat auth ip tag lrn name
1 std on off on on off off off on wireless
112 std on on on on off off off on AP-2NDFLR
1112 std on off on on off off off on IPTV-2NDFLOOR
2047 std on off on on off off off on R-2047 ------- vlan for data ports
2201 std on off on on off off off on R-201
2202 std on off on on off off off on R-202
2203 std on off on on off off off on R-203
2204 std on off on on off off off on R-204
2205 std on off on on off off off on R-205
2206 std on off on on off off off on R-206
2207 std on off on on off off off on R-207
2208 std on off on on off off off on R-208
2209 std on off on on off off off on R-209
2210 std on off on on off off off on R-210
2211 std on off on on off off off on R-211
2212 std on off on on off off off on R-212
2213 std on off on on off off off on R-213
2214 std on off on on off off off on R-214
2215 std on off on on off off off on R-215
2216 std on off on on off off off on R-216
2217 std on off on on off off off on R-217
2218 std on off on on off off off on R-218
2219 std on off on on off off off on R-219
2220 std on off on on off off off on R-220
2221 std on off on on off off off on R-221
2222 std on off on on off off off on R-222
2223 std on off on on off off off on R-223
2224 std on off on on off off off on R-224
2225 std on off on on off off off on R-225
2226 std on off on on off off off on R-226
2227 std on off on on off off off on R-227
2228 std on off on on off off off on R-228
2229 std on off on on off off off on R-229
2230 std on off on on off off off on R-230
2231 std on off on on off off off on R-231
2232 std on off on on off off off on R-232
2233 std on off on on off off off on R-233
2234 std on off on on off off off on R-234
2235 std on off on on off off off on R-235
2236 std on off on on off off off on R-236
2237 std on off on on off off off on R-237
2238 std on off on on off off off on R-238
2239 std on off on on off off off on R-239
2240 std on off on on off off off on R-240
2241 std on off on on off off off on R-241
2242 std on off on on off off off on R-242
2243 std on off on on off off off on R-243
2244 std on off on on off off off on R-244
2245 std on off on on off off off on R-245
2246 std on off on on off off off on R-246
2247 std on off on on off off off on R-247
2248 std on off on on off off off on R-248
2249 std on off on on off off off on R-249 -------vlan for data ports
Total 2 interfaces
1 0.0.0.0 0.0.0.0 DOWN NO unbound
Loopback 127.0.0.1 255.0.0.0 UP NO Loopback
like
-> show vlan
Total 7 interfaces
-> show vlan port
-> show vlan
stree mble src
Total 2 interfaces
If you want to communicate from your laptop connected to edge switches to core switch ip 10.200.200.1 you have to configure vlan 90 on ALL your trunking ports and at least one port on edge switches with vlan 90 access or you have to configure ip router with access to vlan 90 and setup a route to this gateway.HUSSAINQCS wrote:The problem got resolved after giving dhcp mode in laptop and then when i try to ping the controller & core switch pinging is 100% without RTO.
like
-> show vlan
-> show vlan
stree mble src
Total 2 interfaces
The fiber up-link is connected in the edge switch-1 on the port 1/49 with vlan 112
But how from edge switch-1 i can able to reach core switch ?? not from the other switches which is stacked with the edge switch-1
Specify reason whether it is directly connected am i right ?
Please reply
Please reply
If you want to connect vlan 90 on core switch with vlan 112 on edge switch, you have to set the uplink default vlan to 90 for port 1/1/49HUSSAINQCS wrote:The fiber up-link is connected in the edge switch-1 on the port 1/49 with vlan 112
Please reply
But in general it is not a good design to jump between different vlan. It would be much easier to tag vlan 90 on uplink ports to your edge switches and to use it straight through your infrastructure for management of your wifi.
