DHCP Issue on OS 6900-X20 Switch
yasirsattar06
Post by yasirsattar06 »
Dear's,
In my Network, I want to use 6900 Switch as DHCP Server. I have three different VLANs (Voice, Data, Wireless) and Subnets (192.168.10.0, 192.168.20.0, 192.168.30.0). 192.168.30.0/24 is for Wireless devices like Access Points.
I have configured DHCP Server with the following configuration.
server-identifier alcatel-lucent.com;
subnet 192.168.10.0 netmask 255.255.255.0
dynamic-dhcp range 192.168.10.1 192.168.10.99
option subnet-mask 255.255.255.0;
option routers 192.168.10.254;
option domain-name-servers 10.1.1.35;
option domain-name-servers 86.51.34.17;
option domain-name-servers 86.51.35.18;
option dhcp-lease-time 1000;
subnet 192.168.20.0 netmask 255.255.255.0
dynamic-dhcp range 192.168.20.1 192.168.20.99
option routers 192.168.20.254;
subnet 192.168.30.0 netmask 255.255.255.0
dynamic-dhcp range 192.168.30.1 192.168.30.99
option routers 192.168.30.254;
Access Points are connected on Edge Switches. How Access Points will be register in WLAN Controller?
Do we need to define "option dhcp-tftp-server 192.168.30.150;" in DHCP Pool for 192.168.30.0 subnet?
Yasir
Re: DHCP Issue on OS 6900-X20 Switch
you need option 43 and 60:
option vendor-specific x.x.x.x;
 option 60 ArubaAP;
yasirsattar06
Dear Silvio,
Thank You Sir for your prompt response.
In Network Config Guide of R8, This is asked to mention Vendor Specific Information in Hexadecimal. As Following
vendor-specific option vendorspecific vspInfo; hexadecima, l_text
Will option vendorspecific x.x.x.x (This is WLAN Controller Management VLAN IP) work?
Second thing is, We have to define both option 43 and 60 in DHCP Pool? Like
option vendorspecific 192.168.30.150;
option 43 ArubaAP;
option 60 ArubaAP;
Is this configuration correct?
Kind Regards,
Yasir Sattar
option 43 is same as vendorspecific - Ip of controller. One is enough. But I have always used 43.
60 is correct.
yasirsattar06
Dear Silvio,
Got it. Thank You for your prompt response.
I will check and will let you know.
Kind Regards,
Yasir
Return to “OmniSwitch 6900”
