Multicast Streaming not happening in 6450
Scenario:
(Hotel-A)Streaming server-------> 6450----->6900----->6450-----> PC(Hotel-B)
When the setup is like the above the streaming of video is fine in the switch which is connected in the hotel-A
But unable to get stream in PC when i connected to switch 6450 of Hotel B
Re: Multicast Streaming not happening in 6450
For mc-switching over all the switches you need to enable Multicast. At the 6900 (I assume that there is an ip interface in the mc vlan) you need to activate querier. And at the 6450 Hotel A you need to enabel querier-forwarding.
If both sites in different vlans you need MC-Routing in 6900 (f.e. DVMRP).
Siklvio
Siklvio
Integration between two hotels
Hotel A:
streaming source (vlan 902) -----------------------------------------6450(1/1)
IPTV Server(dhcp server for IPTV clients)(vlan 901) --------------6450(1/23)
streaming source-2 (vlan 903)-----------------------------------------6450-1(1/2)
Hotel B:
6450-1 (1/26) to 6900(1/15)----------6450
6450---------------------------------IPTV clients
Also Can you please tell me how to add static group in 6900 like below this is the avaya setup which is running in existing hotel A
interface VLAN 33
ip address 10.238.2.120 255.224.0.0
ip igmp static-group 239.10.1.1 239.10.1.254 3/20 static
ip igmp static-group 239.10.10.1 239.10.10.254 3/20 static
ip igmp static-group 239.10.2.1 239.10.2.254 3/20 static
ip igmp static-group 239.15.1.1 239.15.1.254 3/20 static
ip igmp static-group 239.15.2.1 239.15.2.254 3/20 static
ip pim interface-type passive
ip pim enable
Hotel A:
Hotel B:
interface VLAN 33
ip pim enable
Hi Silvio,silvio wrote: ↑27 Mar 2017 02:13 For mc-switching over all the switches you need to enable Multicast. At the 6900 (I assume that there is an ip interface in the mc vlan) you need to activate querier. And at the 6450 Hotel A you need to enabel querier-forwarding.
Siklvio
Thanks for your reply
Hotel A
IPTV Server(1/23) ------- 6450
Streaming source-1(1/1)-------6450
Streaming source-2(1/3) --------6450
Hotel B
Hotel A 6450 (1/26)-------(1/15)6900 (1/1/1)----------(1/49)6450-------IPTV Clients(vlan 901)
But here they want IPTV server(DHCP server for IPTV clients) in different vlan (vlan -901) & Streaming source-1 (vlan-902) also Streaming source-2 (vlan-903) and the IPTV clients in vlan-901.
If we want to achieve the above setup in my scenario what i have to do ? multicast routing ? or all need to be in same vlan
Please guide me
Siklvio
Siklvio
Hi Silvio,
Right now the setup was different
ISP up-link--------Avaya routing switch(igmp enabled)-------(1/1/16)6900(1/1/1)--------(1/49)6450(2/1)------iptv client
We have enabled ipms and dvmrp on 6900 but still facing issue in all ISP channel group address eg :239.10.1.196:22222 But Channels are getting freezed after sometimes but local channels are running without any issue
Configuration on 6900:
attached for your reference
Configuration ON 6450:
Group Address Source Address VLAN Port Mode Static Count Life RVLAN
239.3.3.24 0.0.0.0 901 2/1 exclude no 2 221 - ----------------------------------------working stream(VLC Client)
239.20.1.3 0.0.0.0 901 2/1 exclude no 15 197 -
239.255.255.250 0.0.0.0 901 2/1 exclude no 18 202 -
-> show ip multicast group
Total 3 Groups
239.10.1.196 0.0.0.0 901 2/1 exclude no 5 214 -
239.20.1.3 0.0.0.0 901 2/1 exclude no 8 222 -
239.255.255.250 0.0.0.0 901 2/1 exclude no 8 216 -
-> show ip multicast forward
Total 4 Forwards
Ingress Egress
Group Address Host Address Tunnel Address VLAN Port VLAN Port RVLAN
239.10.1.196 10.240.8.177 0.0.0.0 901 1/49 901 2/1 - ------------------------ not working stream(VLC CLient)(freezing )
239.20.1.3 10.238.2.125 0.0.0.0 901 1/49 901 2/1 -
239.255.255.250 10.45.0.5 0.0.0.0 901 1/49 901 2/1 -
239.255.255.250 10.45.0.10 0.0.0.0 901 2/1 901 1/49 -
I updated to latest code in 6450 but still issue totally fed up please need your support
What could be the issue?
your config seams to be correct.
Did I understand correctly, that only one stream 239.10.1.196 isn't working. And all other streams works correctly over all the switches??
If the stream is freezing than mostly the life-timer at -> show ip multicast group is aging out. Reason for it is, that querying isn't enabled. But this is in your config.
If the stream isn't there (is frozen): did you see at 6900 the stream 239.10.1.196 at port 1/1/16 (at command -> show ip multicast group and -> show ip multicast source)? If not than the avaya switch is the reason....
At the avaya switch all the mc streams (clients and source) in same vlan 902?
I hope that will help you to solve the issue.
All the streams related to 239.10.1.x having issue
Are all other streams (successfull streams) are sent by the same server?
please answer also to the other questions of my last post.
All streaming source and clients connected with avaya switch in default vlan
issue got resolved after remove all the vlans and kept only the iptv vlans
Below is the working configuration we removed all the vlans & IP interfaces pertain to wireless
vlan 901 -IPTV Clients
vlan 902 - Streaming source
! Chassis:
! Configuration:
configuration error-file-limit 2
! Capability Manager:
! Multi-Chassis:
! Virtual Flow Control:
! LFP:
! Interface:
! Port_Manager:
! Link Aggregate:
linkagg static agg 3 size 2 admin-state enable
! VLAN:
vlan 1 admin-state enable
vlan 901-903 admin-state enable
vlan 1000 admin-state enable
vlan 1000 name "MGMT"
vlan 901 members port 1/1/15 untagged
vlan 902 members port 1/1/16 untagged
vlan 901 members port 1/1/1 tagged
vlan 902 members port 1/1/1 tagged
vlan 1000 members port 1/1/1-18 tagged
! PVLAN:
! Spanning Tree:
spantree vlan 1 admin-state enable
spantree vlan 901 admin-state disable
spantree vlan 902 admin-state disable
spantree vlan 903 admin-state enable
spantree vlan 1000 admin-state enable
! DA-UNP:
! Bridging:
! Port Mirroring:
! Port Mapping:
! IP:
ip interface "vlan-902" address 10.238.2.119 mask 255.224.0.0 vlan 902 ifindex 1
ip interface "vlan-1000" address 10.10.0.254 mask 255.255.255.0 vlan 1000 ifindex 2
ip interface "vlan-901" address 10.45.0.254 mask 255.255.252.0 vlan 901 ifindex 12
! IPv6:
! IPSec:
! IPMS:
ip multicast admin-state enable
ip multicast querying enable
ip multicast spoofing enable
ip multicast vlan 902 querying disable
! AAA:
aaa authentication telnet "local"
aaa authentication ftp "local"
aaa authentication http "local"
aaa tacacs command-authorization disable
! NTP:
! QOS:
qos trust-ports
qos apply
! Policy Manager:
! VLAN Stacking:
! ERP:
! MVRP:
! LLDP:
! UDLD:
! Server Load Balance:
! High Availability Vlan:
! Session Manager:
session cli timeout 30000
session login-timeout 300
! Web:
! Trap Manager:
! Health Monitor:
! System Service:
! SNMP:
! BFD:
! IP Route Manager:
! VRRP:
ip load vrrp
! UDP Relay:
ip helper address 10.128.255.254
! RIP:
! OSPF:
! IP Multicast:
ip load pim
ip pim sparse admin-state disable
ip pim dense admin-state disable
ipv6 pim sparse admin-state disable
ipv6 pim dense admin-state disable
! DVMRP:
ip load dvmrp
ip dvmrp interface "vlan-902"
ip dvmrp interface "vlan-901"
ip dvmrp admin-state enable
! IPMR:
! RIPng:
! OSPF3:
! BGP:
! ISIS:
! Netsec:
! Module:
! LAN Power:
! RDP:
! DHL:
! Ethernet-OAM:
! SAA:
! SPB-ISIS:
! SVCMGR:
! LDP:
! EVB:
! APP-FINGERPRINT:
! FCOE:
! QMR:
! OPENFLOW:
! Dynamic auto-fabric:
! SIP Snooping:
! DHCP Server:
! DHCPv6 Relay:
! DHCPv6 Server:
! DHCP Message Service:
! DHCP Active Lease Service:
! Virtual Chassis Split Protection:
! DHCP Snooping:
! APP-MONITORING:
! Loopback Detection:
! VM-SNOOPING:
! PPPOE-IA:
! Chassis:
! Configuration:
! Multi-Chassis:
! LFP:
! Interface:
! Port_Manager:
! Link Aggregate:
! VLAN:
! PVLAN:
! Spanning Tree:
! DA-UNP:
! Bridging:
! Port Mirroring:
! Port Mapping:
! IP:
! IPv6:
! IPSec:
! IPMS:
! AAA:
! NTP:
! QOS:
qos trust-ports
qos apply
! Policy Manager:
! VLAN Stacking:
! ERP:
! MVRP:
! LLDP:
! UDLD:
! Session Manager:
! Web:
! Trap Manager:
! Health Monitor:
! System Service:
! SNMP:
! BFD:
! IP Route Manager:
! VRRP:
ip load vrrp
! UDP Relay:
! RIP:
! OSPF:
! IP Multicast:
ip load pim
! DVMRP:
ip load dvmrp
! IPMR:
! RIPng:
! OSPF3:
! BGP:
! ISIS:
! Netsec:
! Module:
! LAN Power:
! RDP:
! DHL:
! Ethernet-OAM:
! SAA:
! SPB-ISIS:
! SVCMGR:
! LDP:
! EVB:
! APP-FINGERPRINT:
! FCOE:
! QMR:
! OPENFLOW:
! SIP Snooping:
! DHCP Server:
! DHCPv6 Relay:
! DHCPv6 Server:
! DHCP Snooping:
! APP-MONITORING:
! VM-SNOOPING:
! PPPOE-IA:
It works now?issue got resolved after remove all the vlans and kept only the iptv vlans
