Multicast Streaming not happening in 6450
Re: Multicast Streaming not happening in 6450
you have to activate the following:
-> ip multicast querier-forwarding enable
HUSSAINQCS
Post by HUSSAINQCS »
Hi Silvio,
As earlier setup all my IPTV in all zones are all in same vlan(901)but now customer want that to be in different vlan for zone wise
Zone 1
IPTV Source vlan 901--------(1/1/15)6900(1/1/1)--------6450----- TV clients(vlan 903)
Streaming Source vlan 902----(1/1/16)6900(1/1/1)-------6450------
Zone 2
IPTV Source vlan 901--------(1/1/15)6900(1/1/2)--------6450----- TV clients(vlan 904)
Streaming Source vlan 902----(1/1/16)6900(1/1/2)-------6450------
Now my config is up link vlan for IPTV source is in vlan-901, Streaming source in vlan-902
need to configure different vlan for TV clients(eg: vlan 903- Zone 1,vlan 904-Zone 2)
What config to be done in 6900 and 6450 to achieve to get the streaming in both vlans 903 & 904
at 6900: create in all three vlans an ip interface and activate dvmr for all of them.
at 6450: ip multicate must enabled
but both sources (streaming and iptv) need to sent mc traffic with ttl >1 (f.e. ttl=10). You can check with wireshark the ttl in your traffic.
HUSSAINQCS
silvio wrote: 21 Apr 2017 12:29 at 6900: create in all three vlans an ip interface and activate dvmr for all of them.
Hi Silvio,
Thanks for your answer but how the clients in vlan-903, & 904 will get ip address from vlan -901 which is the dhcp server for the tv clients
This need to be done in dhcp server as well correct me if im wronga
for this you need to configure ip helper at your L3-switch (6900).
Return to “OmniSwitch 6900”
