6900 as a single switch
I have two 6900 need to make the switch as a single switch only by virtual chassis or we can do by some other way ?
Re: 6900 as a single switch
On 6900 single management is possible only with virtual chassis.
Hi Devnell,
Thanks for your info but I need to make two 6900 -x20 as active active master and two slaves can you guide me with configuration steps for this setup
I don't understand active active master.
Setting up Virtual chassis is done automatically or the manual steps are described in the manual. have you checked that?
Actually I need a clue that how can I make stack of two 6900 20 port switch as master and other two as slave totally 4 6900-x20 I m having
I have total 25 uplinks one should be connected to master and redundant uplink will be connected to slave 6900
Can somebody give me clue to stack in my scenario
In each stack and in each VC only one device is master, one the other is standby.
So you need 1 stack out of 4 Switches or 2 Stacks with each 2 switches?
What links to you want to use as VFLs? 10G? Seperate 40G interfaces on the module?
Please refrain from creating multiple single line posts.
I need a setup like in above picture with VFL links between all of them
