6900 virtual chassis error
mdhussainvlr
Post by mdhussainvlr »
When I try to change the chassis Id I’m getting the below error
Re: 6900 virtual chassis error
your switch is actual id 1 - so you have to configure the id 1 to 2.
virtual-chassis chassis-id 1 configured-chassis-id 2
after next reload your switch is id2.
mdhussainvlr
Still no success
mdhussainvlr
Show running directory it showing machine state as shutdown as well
Return to “OmniSwitch 6900”
