Rename VRF instance OmniSwitch 6900
Muttley
Post by Muttley »
Hi all
Is it possible to rename a VRF instance up and running without delete/recreate the vrf ?
Thanks in advance.
Re: Rename VRF instance OmniSwitch 6900
I don't think so.... Easiest way is to use config-file (vcboot.cfg) and replace there all old-name with new one. You need a reload of the switch to bring this in action. All other ways with commands will be more complicate (delete old entries and replace it....). I have done this some years ago (without reload). But you have to be very sure about all your steps and monitor them.
Return to “OmniSwitch 6900”
