Core switch not accepting password with special characters
mdhussainvlr
Post by mdhussainvlr »
I have 6900 core switch I need to change the password for admin login I tried changing to switch1234 it was working instead I give $witch@HOC6900 it was not taking and when I try to login it showing invalid login or password .
I have 8.4.1 microcode
Re: Core switch not accepting password with special characters
Maybe only one part of the not working password is now active. Sometimes you need the password in "...." but sometimes in '....'
I know there are problems with ! within password.
If you have no other user with admin-rights you have the reset the password to default.
Break the boot sequence after power up and than:
⇒ setAdminPasswordDefault
⇒ boot
Return to “OmniSwitch 6900”
