OS6900 not able to login using admin user ( PAM error )
hafidd3
Post by hafidd3 »
Dear All,
I am not able to login to to an OS6900 switch using admin user ..
Using a usb memory (Trescue.img ) it does work fine and I am able to login to both admin and root ..
Login messages when using account admin :
login[1459]: PAM (other) illegal module type: @include
login[1459]: PAM pam_parse: expecting return value; [...common-auth]
login[1459]: PAM (other) no module name supplied
login[1459]: PAM pam_parse: expecting return value; [...common-account]
login[1459]: PAM pam_parse: expecting return value; [...common-password]
login[1459]: PAM pam_parse: expecting return value; [...common-session]
Login messages when using account root :
(none) login: root
Password:
login[1459]: pam_unix(login:session): session opened for user root by LOGIN(uid=0)
login[1459]: root login on 'ttyS0'
# login[1459]: pam_unix(login:session): session opened for user root by LOGIN(ui
d=0)
Thanks to all
Re: OS6900 not able to login using admin user ( PAM error )
Have you loaded the AOS image into the switch after rescue the flash?
Return to “OmniSwitch 6900”
