cannot certify switch
songstadw
Post by songstadw »
I am unable to copy working certified. It returns the following: ERROR: Invalid entry: "working"
I can copy certified working and I can write memory. But when I attempt to copy the working config back to certified, it errors out.
Below is relevant command outputs.
Any help would be greatly appreciated.
-Bill
-> ls -lah
drwxr-xr-x 17 admin user 4.0K Oct 28 09:29 .
drwxr-xr-x 12 root root 0 May 14 10:22 ..
-rw-r--r-- 1 admin user 12.4K Oct 27 17:32 .bash_history
drwxr-xr-x 2 admin user 4.0K Jan 10 2017 .ssh
drwxr-xr-x 2 admin user 4.0K May 13 17:41 app-signature
-rw-r--r-- 1 admin user 248 Aug 25 2019 boot.cfg.1.err
-rw-r--r-- 1 admin user 173.0K Jul 18 2017 capManProcCmmTrace
drwxr-xr-x 2 admin user 4.0K Oct 28 09:16 certified
drwxr-xr-x 2 admin user 4.0K Mar 6 2012 diags
drwxr-xr-x 7 vendor admins 4.0K Jul 18 2017 extensions
drwxr-xr-x 2 admin user 4.0K May 13 10:40 foss
-rw-r--r-- 1 admin user 0 Apr 21 2017 history
-rw-r--r-- 1 admin user 283 May 13 17:40 hwinfo
drwxr-xr-x 2 admin user 16.0K Oct 10 2011 lost+found
drwxr-xr-x 2 admin user 4.0K May 2 2012 network
-rw-r--r-- 1 admin user 41.8K Jan 20 2012 pmbus_peek
drwxr-xr-x 3 admin user 4.0K Dec 8 2012 pmd
drwxrwx--- 2 root admins 4.0K Jul 18 2017 python
drwxr-xr-x 2 admin user 4.0K Feb 21 2014 running
drwxr-xr-x 6 admin user 4.0K Jul 18 2017 switch
-rw-r--r-- 1 root root 60.0K Oct 28 09:39 swlog
-rw-r--r-- 1 root root 1.2M Oct 28 09:29 swlog.0
-rw-r--r-- 1 root root 1.2M Oct 24 21:23 swlog.1
-rw-r--r-- 1 root root 1.2M Oct 21 04:47 swlog.2
-rw-r--r-- 1 root root 1.2M Oct 17 06:40 swlog.3
-rw-r--r-- 1 root root 1.2M Oct 13 18:56 swlog.4
-rw-r--r-- 1 root root 1.2M Oct 9 21:11 swlog.5
-rw-r--r-- 1 root root 1.2M Oct 6 01:39 swlog.6
drwxr-xr-x 2 admin user 4.0K Feb 21 2014 swlog_archive
drwxr-xr-x 4 admin user 4.0K Jul 18 2017 system
-rw-r--r-- 1 admin user 62.7K Jul 25 2019 tech_support.log
-rw-r--r-- 1 admin user 1.4K Jul 2 2014 tech_support_bfd.log
-rw-r--r-- 1 admin user 13.1M Jul 2 2014 tech_support_eng.tar
-rw-r--r-- 1 admin user 58.6K Jul 25 2019 tech_support_layer2.log
-rw-r--r-- 1 admin user 81.0K Jul 25 2019 tech_support_layer3.log
-rw-r--r-- 1 admin user 14.8K Jul 2 2014 tech_support_ospf.log
-rw-r--r-- 1 admin user 7.8K Jul 2 2014 tech_support_pim.log
drwxr-xr-x 2 admin user 4.0K Oct 28 09:36 working
-> show running-directory
CONFIGURATION STATUS
Running CMM : PRIMARY,
CMM Mode : MONO CMM,
Current CMM Slot : A,
Running configuration : WORKING,
Certify/Restore Status : CERTIFIED
SYNCHRONIZATION STATUS
Running Configuration : SYNCHRONIZED
-> show configuration status
File configuration: none scheduled
Error file limit: 1
Running configuration and saved configuration are identical
-> copy working certified
Thank you,
Bill
Re: cannot certify switch
on R8 switches you have to use the command: copy running certified
songstadw
Post by songstadw »
OMG, too funny. I guess I have some commands to update on my cheat sheet.
Thanks Silvio. You're a lifesaver once again!
Thank you,
Bill
Return to “OmniSwitch 6900”
