Raspberry for OpenTouch Suite
Nico_1
Post by Nico_1 » 20 Jun 2016 08:30
i have a Raspberry for the OpenTouch Dongle, but i cant login.
What is the correct Login for Consol and SSH?
Thanks for help.
acrec
Re: Raspberry for OpenTouch Suite
Post by acrec » 27 Jun 2016 09:10
i have followed the instructions but the system do not permit login :|
the userid seem to be "admin"
I can't understant if i do something wrong or the commands are not correted
In attached there is the official alcatel documentation.
otsuite_im_dongleip_raspberry_8al90617usaa_1_en.pdf
rgauze
Post by rgauze » 05 Jan 2017 10:52
You don´t need to login on it.
Just edit de ipdongle-cfg.txt with the correct parameters.
ipdongle-cfg.txt
Best Regards
oldboy
Post by oldboy » 05 Jan 2017 14:51
you need to format the SD card, load the img file onto it, then modify the config file and away it goes.
Depends on Raspberry version you may need the .009 licence server and you will need the 1.0.020.001 img file
Return to “MAIN”
