Hi Guys,
someone can tell me why a stack member reboots? I've check if there was a crash file but i can't see nothing about it.
This is my log.
FRI JUL 03 07:26:49 2015 HSM-CHASSIS info T8: Ni(3) extraction detected
FRI JUL 03 07:26:49 2015 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni3
FRI JUL 03 07:26:49 2015 HSM-CHASSIS info === HSM === Power Supply 5 has been REMOVED
FRI JUL 03 07:26:49 2015 HSM-CHASSIS info === HSM === Power Supply 6 has been REMOVED
FRI JUL 03 07:26:49 2015 VLAN info CS_NI_DOWN/CS_NI_NOTPRESENT msg Rx for slot 3
FRI JUL 03 07:26:49 2015 VLAN info Del connection for slot 3
FRI JUL 03 07:26:49 2015 VLAN info VMC: Sent Pause for slot 3
FRI JUL 03 07:26:49 2015 VLAN info Start Timer on ni_down 3 @ 1435904809
FRI JUL 03 07:26:49 2015 INTERFACE info Close NI 3 ESM, socket 110 OK
FRI JUL 03 07:26:49 2015 INTERFACE info Close NI 3 NiSUp, socket 39 OK
FRI JUL 03 07:26:49 2015 GM info NI_DOWN 3
FRI JUL 03 07:26:49 2015 GM info Del connection for slot 3
FRI JUL 03 07:26:49 2015 GM info GMC: Sent Pause for slot 3
FRI JUL 03 07:26:49 2015 GM info Start Timer on ni_down 3 @ 1435904809
FRI JUL 03 07:26:49 2015 LINKAGG info EVT board down received slot 3 slice 0 recover 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 8: c failed!! event 2 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alert pmSend: aborting send... 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 4f: 3 failed!! event 3 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: a: 1 failed!! event 4 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: b: 1 failed!! event 3 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 31: 5 failed!! event 4 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 7: a failed!! event 3 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 20: 29 failed!! event 4 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 9: b failed!! event 2 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 28: 2 failed!! event 3 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: c: 1 failed!! event 4 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 12: 2 failed!! event 3 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 17: 6 failed!! event 4 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 5b: 2 failed!! event 3 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: d: 2 failed!! event 4 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 16: 0 failed!! event 3 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 96: 3 failed!! event 4 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 29: 5 failed!! event 2 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 95: 5 failed!! event 3 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: a3: 2 failed!! event 4 len 0
FRI JUL 03 07:26:49 2015 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 4d: 1 failed!! event 3 len 0
FRI JUL 03 07:26:54 2015 VLAN info Timer closed skt on ni 2 @ 1435904814
FRI JUL 03 07:26:54 2015 VLAN info Timer closed skt for GVRP NI on ni 2 @ 1435904814
FRI JUL 03 07:26:54 2015 GM info Timer closed skt on ni 2 @ 1435904814
FRI JUL 03 07:30:31 2015 STACK-MANAGER info Retaining Module Id for slot 3 unit 0 as 4
FRI JUL 03 07:30:31 2015 STACK-MANAGER info Retaining Module Id for slot 3 unit 1 as 5
FRI JUL 03 07:30:33 2015 INTERFACE info Got connection from slot 3:352
FRI JUL 03 07:30:34 2015 INTERFACE info Got connection from slot 3:354
FRI JUL 03 07:30:40 2015 HSM-CHASSIS info T8: Ni(3) insertion detected
FRI JUL 03 07:30:40 2015 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni3
FRI JUL 03 07:30:41 2015 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni3
FRI JUL 03 07:30:43 2015 GM info GMC: Got connection from slot 67, connIdx 2
FRI JUL 03 07:30:43 2015 VLAN info VMC: Got connection from slot 67
FRI JUL 03 07:30:43 2015 VLAN info MVRP_DUMMY_MSGID message received from NI, otherEnd = 10
FRI JUL 03 07:30:44 2015 HSM-CHASSIS info === HSM === Power Supply 5 has been INSERTED
FRI JUL 03 07:30:44 2015 HSM-CHASSIS info == HSM == Power Supply 5 is OPERATIONAL
FRI JUL 03 07:30:44 2015 HSM-CHASSIS info === HSM === Power Supply 6 has been INSERTED
FRI JUL 03 07:30:44 2015 HSM-CHASSIS info == HSM == Power Supply 6 is OPERATIONAL
FRI JUL 03 07:30:47 2015 HSM-CHASSIS info == HSM == NiNsmT1: NI STATE Rcvd (sl: 3), MsgFlag: 0 Local T.O. Flag: 0
FRI JUL 03 07:30:47 2015 HSM-CHASSIS info == HSM == NI UP Received from driver (sl =3)
FRI JUL 03 07:30:47 2015 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni3
FRI JUL 03 07:30:47 2015 VLAN info CS_NI_UP msg received for slot 3 cfgState 1
FRI JUL 03 07:30:47 2015 VLAN info CS_NI_UP InTakeover 0 vmcPrimaryCmm 1 NiDownRx 1
FRI JUL 03 07:30:47 2015 VLAN info VMC: Sent Ok for slot 3
FRI JUL 03 07:30:47 2015 GM info NI_UP 3
FRI JUL 03 07:30:47 2015 GM info GMC: Sent Ok for slot 3
FRI JUL 03 07:30:47 2015 LINKAGG info EVT board up received slot 3 slice 0 unlike 2 recover 0
FRI JUL 03 07:30:48 2015 VLAN info Sent VM_CFG_RQT_DONE msg
FRI JUL 03 07:30:48 2015 VLAN info Rx VM_CFG_ACK_DONE msg from slot 3
FRI JUL 03 07:30:48 2015 VLAN info Tx VM_CFG_ACT_DONE to slot 3
FRI JUL 03 07:31:02 2015 HSM-CHASSIS warning == HSM == RECEIVED NI_READY [3] from ESMDRV ...
FRI JUL 03 07:31:02 2015 HSM-CHASSIS info == HSM == Rcvd Ni3 READY from driver)
FRI JUL 03 07:31:02 2015 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni3
FRI JUL 03 07:31:02 2015 HSM-CHASSIS info == HSM == Clearing T.O. Flag on NI 3 when NI STATE READY
FRI JUL 03 07:31:02 2015 INTERFACE info RX CS_NI_READY NI 3
FRI JUL 03 07:31:02 2015 INTERFACE info NIs are ready
FRI JUL 03 07:31:02 2015 HSM-CHASSIS warning == HSM == NI [3] Request NI monitoring Start..
OS6450 stacking member restart
Re: OS6450 stacking member restart
What Version are you running?
There is no crash file on Stackmember 3?
-> rls 3 /flash ?
-> rls 3 /flash ?
Hi devnull, thanks for reply. I'm working with a 6.6.5.63.R02 GA.
No i don't have nothing in stackmember 3> rls 3 /
drw 2048 Feb 20 23:37 certified/
-rw 311 Jul 3 07:51 boot.params
drw 2048 Feb 20 23:37 working/
-rw 64000 Feb 20 23:07 swlog1.log
-rw 64000 Jul 3 07:31 swlog2.log
drw 2048 Jan 1 2001 switch/
-rw 12 Jan 1 2001 boot.slot.cfg
drw 2048 Feb 20 19:55 network/
-rw 20 Jan 1 2001 installed
-> rls 3 /working
drw 2048 Feb 20 23:37 ./
drw 2048 Jul 3 07:50 ../
-rw 16775643 Jan 30 16:38 KFbase.img
-rw 4096 Feb 20 17:42 ._KFbase.img
-rw 5792760 Jan 30 16:38 KFeni.img
-rw 4096 Feb 20 17:42 ._KFeni.img
-rw 2586839 Jan 30 16:38 KFos.img
-rw 4096 Feb 20 17:42 ._KFos.img
-rw 610993 Jan 30 16:38 KFsecu.img
-rw 4096 Feb 20 17:42 ._KFsecu.img
-rw 710 Jan 30 16:38 SOFTWARE.LSM
-rw 4096 Feb 20 17:42 ._software.lsm
-rw 3540 Feb 20 23:37 boot.cfg
-> rls 3 /certified
-> rls 3 /working
-> rls 3 /certified
