Policy or qos on swlog?
Mhunter1993
Post by Mhunter1993 » 25 Oct 2016 16:11
If there is a violation to a policy rule for example if i blocked telnet service, would it be register on the policy or the qos log.
For the policy rule i used
->policy rule "name" log enable
also configured traps
->policy rule "name" trap enable
Neither traps or logs are working at the moment.
Re: Policy or qos on swlog?
Post by silvio » 26 Oct 2016 14:22
for the logs you use "show qos logs".
Did you receive other traps? I haven't tested it with traps for rules (to much traps....).
Mhunter1993
Post by Mhunter1993 » 14 Nov 2016 15:14
I couldn't do it through the CLI yet using the Omnivista 2500 I configured a set of policy rules and in the config I applied notifications by traps and logs.
It show the logs and corresponding traps on the Omnivista 2500
Return to “OmniSwitch 6450”
