I need help to connect 2 switch ports SFP
carlomuc
Post by carlomuc » 11 Nov 2016 11:21
I Need Help to link two Switches
Good Morning, I'm starting to work with Alcatel switches and still do not know much about your configuration,
that is why I would like to support me guiding me what would be the procedure to link two switches the first
Alcatel is a switch OS6450-P24 and the second a Switch Alcatel OmniStack LS 6224P want them to link through the
SFP ports of both. Now I have the cables and the corresponding transceivers to connect, only
I wonder if just connect is enough, or need to make some settings in the SFP ports of both
to enable or so they can see.
Thanks and I look forward to your help.-
Re: I need help to connect 2 switch ports SFP
Post by silvio » 12 Nov 2016 11:50
You don't need any config for SFP. But the SFP must be supported from both switches.
Return to “OmniSwitch 6450”
