I want to send the logs of my switch Alcatel OS6450 to a log server under Linux (Debian).
(To configure my server correctly)
Question:
What port does my Alcatel OS6450 switch send its logs to (UDP(540..) or TCP(...)?
Thanks !
Log OS6450
Re: Log OS6450
hello
> swlog output socket 192.168.10.2
default UDP Port is 514
Re: Log OS6450
Hello, thank you M Silvio for the answer .
I want to retrieve the logs of the Alcatel OS6450 switch on a log server (Linux Debian) using syslog-ng
I want to retrieve logs of type bridge (level warning) in my server log
Switch OS6450 Configuration (@192.168.0.2) :
Server log (@192.168.0.1):
But I can not. Someone already do it? Another solution to retrieve my logs on a server?
Thanks !
swlog
swlog appid bridge level warning
swlog output socket 192.168.0.1
source s_client {syslog(ip(192.168.0.2) transport(udp)) ; };
destination d_local {file("/var/log/logs.log"); };
log {source(s_client); destination(d_local); };
Thanks !
Re: Log OS6450
please check "show swlog"
Have you a sniffer (wireshark) at your server to test it?
Re: Log OS6450
I have succeeded, thanks for your help!
Re: Log OS6450
Mind to provide your solution, so others can learn from that?
Re: Log OS6450
For my OS6450
For my log server (i use syslog-ng on y Debain)
In the file nano /etc/syslog-ng/syslog-ng.conf
Finally, it is necessary to restart syslog-ng to take into account the new configuration:
The logs of the switch are now sent to the file "alcatel.log"
end
For my OS6450
swlog
swlog output socket @server_log
@include ‘’/etc/syslog-ng/conf.d/’’
source s_udp { udp() ; } ;
destination d_dest { file(‘’/var/log/alcatel.log’’) ; } ;
filter switch { host(‘’@_IP_switch’’) ; } ;
log { source(s_udp) ; destination(d_dest) ; filter(switch) ; } ;
/etc/init.d/syslog-ng restart
nano /var/log/alcatel.log
