how do i do that ?
in the manuel it says that
when the switch back to factory defulet
it take ip atoumatic from dhcp (router dhcp)
here is all the start up boot
i try to find startup-config and delete it
did not find it
Detect SysClk 320MHz
Detect Tclk 200MHz
Marvell Controller initialization Done.
Eth int Ctrl.... Done
GPIO int Ctrl... Done
PEX int Ctrl.... Done
PEX0 init....... Done. DEVICE type selected
USB Init........ Done
USB int Ctrl.... Done
XOR int Ctrl.... Done
XOR init........ Done
mvCtrlInit2..... done
PCI auto config. done
sysHwInit2...... DoneUSB2 Host Stack Initialized.
USB Hub Driver Initialized
USBD Wind River Systems, Inc. 560 Initialized
Non-PCI USB device found: pgmIf=0xa0, idx=0 , baseAddr=0xf1050100, irq=19, swapFunc=0x10abf4
EHCI Controller found.
Waiting to attach to USBD...Done.
0xffffe50 (tRootTask): usbBulkDevInit() returned OK
usbCbiUfiDevInit() returned OK
CBI Class Driver Successfully Initialized
System Configuration
BSP Ver: 1.2/1.1.01 Creation date: May 9 2014, 05:22:44
CHIP : MV88F6281 Rev 2
CPU : ARM926 (Rev 1)
BOARD : DB-98DX4122-48G (0x7)
CLOCKs : tClk = 200 MHz, sysClk = 320 MHz
pClk = 800 MHz
NAT_SUPPORT = Disabled
VFP_SUPPORT = Disabled
Target Name: vxTarget
Attaching network interface lo0... done.
Write Protecting exception Vectors
Write protecting KFos .text sections (0x100000 to 0x527000) 1063 pages
Adding 11965 symbols for standalone.
Boot parameters are:
'flash(0,0)cmm:default e=10.4.50.165:ff000000 g=10.4.50.5 u=admin pw=switch cb=9600 cp=none cs=1 cw=8 cm=modemControlOff'
AOS kernel version: 6.6.4.244.R01
VxWorks (for DB-98DX4122-48G BE MMU ARCH 5) version VxWorks5.5.1
KERNEL: WIND version 2.6
Made on May 9 2014, 05:22:44.
Copyright Wind River Systems, Inc., 1984-2006
CPU: DB-98DX4122-48G BE MMU ARCH 5. Processor #0.
Memory Size: 256 MBytes. BSP version 1.2/1.1.01.
Portions of code copyrighted by Alcatel Internetworking, Inc. 1994-2014. All Rights reserved
Portions of code copyrighted by Apptitude, Inc. 1997-1999. All Rights reserved
Portions of code copyrighted by Free Software Foundation, Inc. 1989,1991. All rights reserved
Portions of code copyrighted by The OpenLDAP Foundation 1999-2000. All rights reserved
Portions of code copyrighted by Theodore T'so 1994,1995,1996,1997,1998,1999. All Rights reserved
Portions of code copyrighted by RSA Security, Inc. All Rights reserved
Portions of code developed by the Carnegie-Mellon University.
The current date and time is:
Coordinated Universal Time (UTC): SUN DEC 31 01:00:13 2000
Local time: SUN DEC 31 01:00:13 2000 UTC
Starting dynamic software load from '/flash/certified/'...
FIPS_text_start() returns NULL
SUN DEC 31 01:00:23 : SYSTEM (75) info message:
+++ Switch Logging device '/dev/console' enabled for output
SUN DEC 31 01:00:23 : CSM-CHASSIS (103) info message:
+++ == CSM == === Chassis Supervision Starting Up ===
sysStartWatchdog() Starting watchdog timer to INTERRUPT after 240 secs.
SUN DEC 31 01:00:31 : CSM-CHASSIS (103) info message:
+++ == CSM == APP MONITORING ON
+++ == CSM == ===== THIS STACK(1) IS PRIMARY =====
SUN DEC 31 01:00:43 : HSM-CHASSIS (101) info message:
+++ T1:Ni Insertion detected on slot 1
+++ ==== HSM === Power Supply 1 is OPERATIONAL
SUN DEC 31 01:01:01 : WEB (69) info message:
+++ WebView SSL/RSA file-based certificate set-up successful!
CMM-NI IPC blocked - EOIC Not Recvd
SUN DEC 31 01:01:07 : CCM-CHASSIS (100) info message:
+++ === CCM === csCcmEoicFunc: send CCM_CSM_EOIC OK
SUN DEC 31 01:01:07 : REMOTE_CONFIG (125) info message:
+++ Automatic Remote configuartion Initiated
SUN DEC 31 01:01:09 : CSM-CHASSIS (103) info message:
+++ == CSM == CMM startup completed
SUN DEC 31 01:01:09 : CLI (67) info message:
+++ Starting new CLI console session
login :
Successfully sent the I2C read message to NISUP!!
SUN DEC 31 01:01:19 : INTERFACE (6) info message:
+++ NIs are ready
SUN DEC 31 01:01:50 : REMOTE_CONFIG (125) error message:
+++ DHCP Response for vlan 1 not received in 30s.
SUN DEC 31 01:01:50 : REMOTE_CONFIG (125) info message:
+++ Starting the DHCP Client on vlan 127
SUN DEC 31 01:02:20 : REMOTE_CONFIG (125) error message:
+++ DHCP Response for vlan 127 not received in 30s.
SUN DEC 31 01:02:20 : REMOTE_CONFIG (125) info message:
SUN DEC 31 01:02:21 : IP-HELPER (22) error message:
+++ relayRecvAck: TFTP Server Name Option is NULL or greater than 64
+++ relayRecvAck: TFTP Boot File Name Option is NULL or greater than 64
SUN DEC 31 01:02:25 : IP-HELPER (22) error message:
SUN DEC 31 01:02:33 : IP-HELPER (22) error message:
SUN DEC 31 01:02:49 : IP-HELPER (22) error message:
SUN DEC 31 01:02:50 : REMOTE_CONFIG (125) error message:
SUN DEC 31 01:02:50 : REMOTE_CONFIG (125) info message:
login : admin
password :
Welcome to the Alcatel-Lucent OmniSwitch 6450
Software Version 6.6.4.244.R01 Service Release, May 09, 2014.
Copyright(c), 1994-2013 Alcatel-Lucent. All Rights reserved.
OmniSwitch(TM) is a trademark of Alcatel-Lucent registered
in the United States Patent and Trademark Office.
SUN DEC 31 01:02:56 : REMOTE_CONFIG (125) info message:
+++ User logged in via console, Automatic Remote configuration is aborted.
ls
Listing Directory /flash:
-rw 312 Dec 31 01:00 boot.params
drw 2048 Jan 1 2001 certified/
drw 2048 Jan 1 2001 working/
-rw 32 Dec 31 01:00 boot.slot.cfg
-rw 64000 Dec 31 01:03 swlog1.log
-rw 64000 Dec 31 01:28 swlog2.log
drw 2048 Dec 31 01:11 switch/
drw 2048 Dec 31 01:01 network/
-rw 207 Jan 1 2001 boot.cfg.1.err
-rw 20 Dec 31 01:11 installed
\0x0957948160 bytes free
-> ls /working/
Listing Directory /working/:
drw 2048 Jan 1 2001 ./
drw 2048 Dec 31 01:00 ../
-rw 705 Jun 10 2013 software.lsm
-rw 16231207 May 19 2014 KFbase.img
-rw 2327149 Jan 3 2001 KFdiag.img
-rw 5261945 May 19 2014 KFeni.img
-rw 2585572 May 19 2014 KFos.img
-rw 603721 May 19 2014 KFsecu.img
-> ls /certified/
Listing Directory /certified/:
-> ls
-> ls /switch/
Listing Directory /switch/:
drw 2048 Dec 31 01:11 ./
-rw 105613 Jan 1 2001 certs.pem
-rw 20 Dec 31 01:00 snmp.engine
-rw 0 Jan 1 2001 pre_banner.txt
drw 2048 Dec 31 01:11 avlan/
-rw 1732 Dec 31 01:11 label.txt
-rw 973 Nov 15 2014 wv-cert.pem
-rw 963 Nov 15 2014 wv-key.pem
-rw 23 Dec 31 01:02 dhcpClient.db
-rw 1732 Nov 15 2014 label.txt.bk
-> ls /network/
Listing Directory /network/:
drw 2048 Dec 31 01:01 ./
-rw 91392 Jan 1 2001 userTable5
-rw 12 Dec 31 01:00 lockoutSetting
-rw 33 Dec 31 01:01 policy.cfg
-rw 404 Dec 31 01:01 ssh_host_dsa_key
-rw 358 Dec 31 01:01 ssh_host_dsa_key.pub
-> login : ls
password :
SUN DEC 31 01:22:47 : SESSION (71) info message:
+++ [SES] Authentication failed: Session 0, access type Console
+++ [SES] Session 0, user "ls"
+++ [SES] Session 0, IP address 0.0.0.0
Authentication failure : Server temporarily unreachable, please try later
login : switch
password :
SUN DEC 31 01:22:54 : SESSION (71) info message:
+++ [SES] Session 0, user "switch"
login : admin
password :
-> ls
-rw 64000 Dec 31 01:22 swlog1.log
-> ls /certified/
-> ls /working/
-> ls
-> dir
-> cd..
ERROR: Invalid entry: "cd.."
-> cd/
ERROR: Invalid entry: "cd/"
-> dir
-> dir startup-config
-> ls /flash/
Listing Directory /flash/:
-> cd flash
ERROR: flash: no such directory
-> cd/flash
ERROR: Invalid entry: "cd/flash"
-> ls
-> ls /flash/
-> ls /flash/certified/
Listing Directory /flash/certified/:
-> ls /flash/working/
Listing Directory /flash/working/:
-> login :
