Copy Config via Usb?
Cyberurmel
Post by Cyberurmel » 09 Apr 2018 05:40
hi all,
sorry for that probably simple question. But somehow i stuck on this.
I have a Switch 6450 for replacement another same model. We use Omnivista - so i can copy all config from the backup.
I copied all files from usb to the switch. but then? I made a wr mem and then i saw the old boot.cfg again in the Folder..
think its pretty simple ..can someone help?
thanks a lot
Re: Copy Config via Usb?
Post by silvio » 09 Apr 2018 07:40
after copy the boot.cfg to working you have to reload from working (reload working no rollback-timeout) without saving anything.
Cyberurmel
Post by Cyberurmel » 09 Apr 2018 08:04
Hi Silvio,
thanks a lot... but just for understanding - is there everything stored in the boot.cfg? Such as vlan Settings, snmp,name etc?
Thanks for short answer
Best Regards
Cyb
Post by silvio » 09 Apr 2018 09:27
all config is stored in the boot.cfg (you can look into the file - it is a text-file). Only users (with password and the rights) are in the usertable.
devnull
Post by devnull » 09 Apr 2018 10:57
To add to Silvio: banners are also in seperate files.
Cyberurmel
Post by Cyberurmel » 11 Apr 2018 03:28
Thanks you both,
it worked fine. As i should copy the Banners and the users also. Saw that too late :)
greets
Cyb
Return to “OmniSwitch 6450”
