The NTP active server (x.x.x.x) changes.
rtabor
Post by rtabor »
I keep receiving this message on my switches is there a setting i should adjust or at least a way to suppress the log?
Re: The NTP active server (x.x.x.x) changes.
please check your configured servers with:
show configuration snapshot ntp
You should configure only one of them. But there is no problem with more than one....(beside the log).
Return to “OmniSwitch 6450”
