Unable to ping VLAN interface
eugene
Post by eugene »
Hi experts,
I'm a newbie to Alcatel switches.
I have 3x stacked OS6450. I configured VLAN 110 which spans across all 3 switches. The commands I ran on the PRIMARY switch are:
vlan 110 name "mgmt"
vlan 110 port default 1/2
vlan 110 port default 1/4
vlan 110 port default 2/2
vlan 110 port default 2/4
vlan 110 port default 3/2
vlan 110 port default 3/4
ip interface vlan-110 address 10.10.1.1/16 vlan 110
The vlan-110 interface was configured purely for switch management. After setting it up, I can neither ping it nor the hosts in the same VLAN.
-> ping 10.10.1.13 source-interface vlan-110
PING 10.10.1.13: 56 data bytes
The specified source IP interface is not UP
no answer from 10.10.1.13
On an independent (ie. not stacked) OS6900 switch, I did the same and I could ping the configured interface. I could only surmise that the stacking has done something to the network.
Any tips how to resolve this? Thanks in advance!
devnull
Re: Unable to ping VLAN interface
Post by devnull »
You should be able to ping devices in the same vlan, means all devices at 1/2, 1/4, 2/2, 2/4, 3/2, 3/4 should be able to reach each other and should be able to reach the management IP 10.10.1.1 (if they have a matching IP/Netmask).
Is your stack setup correct?
What is the output of
"show stack topology"
The Message "IP Interface is not up, hints, that no port with vlan 110 has a link, hence the interface stays down. If it is up you don't need the source-interface as it will always use the "nearest" interface towards the target
eugene
Post by eugene »
My apologies. I wasn't aware that the forum doesn't send email notifications.
I'm aware of that this should be the case. However, the interface isn't pingable after setting it up. The ports in VLAN 110 are active and working as expected.
This is the interface's config from "write terminal". After configuring it, the interface isn't pingable.
-> write terminal
! IP :
ip service all
ip interface "vlan-110" address 10.10.1.1 mask 255.255.0.0 vlan 110 local-proxy-arp primary ifindex 1
-> ping 10.10.1.1
PING 10.10.1.1: 56 data bytes
   [0         ] T
What is the output of"show stack topology"
-> show stack topology
                                         Link A  Link A          Link B  Link B
NI      Role      State   Saved  Link A  Remote  Remote  Link B  Remote  Remote
                          Slot   State   NI      Port    State   NI      Port
   1 PRIMARY     RUNNING    1    UP          2   StackB  UP          3   StackA
   2 SECONDARY   RUNNING    2    UP          3   StackB  UP          1   StackA
   3 IDLE        RUNNING    3    UP          1   StackB  UP          2   StackA
Disable "local-proxy-arp" at your ip-interface.
And please post the output of the following:
show vlan 110 port
show mac-address-table 110
show ip interface
best regards
eugene
Post by eugene »
Here you go. A thousand thanks for your help!
After reconfiguring the interface to remove proxy-arp. No idea how it got there.
-> ip interface vlan-110 address 10.10.1.1/16 vlan 110
-> show ip interface
Total 3 interfaces
             Name                   IP Address     Subnet Mask   Status Forward  Device
Loopback                         127.0.0.1       255.0.0.0           UP      NO Loopback
vlan-100                         10.0.1.1        255.255.0.0         UP     YES vlan 100
vlan-110                         10.10.1.1       255.255.0.0         UP     YES vlan 110
-> write terminal
! IP :
ip service all
ip interface "vlan-110" address 10.10.1.1 mask 255.255.0.0 vlan 110 ifindex 1
ip interface "vlan-100" address 10.0.1.1 mask 255.255.0.0 vlan 100 ifindex 2
-> show vlan 110 port
  port     type      status
  1/2     default     inactive
  1/4     default     inactive
  1/6     default     inactive
  1/8     default     inactive
  1/10    default   forwarding
  1/12    default   forwarding
  1/14    default   forwarding
  1/16    default   forwarding
  1/18    default   forwarding
  1/20    default   forwarding
  2/2     default   forwarding
  2/4     default     inactive
  2/6     default     inactive
  2/8     default     inactive
  2/10    default   forwarding
  2/12    default   forwarding
  2/14    default   forwarding
  2/16    default   forwarding
  2/18    default   forwarding
  2/20    default   forwarding
  3/2     default   forwarding
  3/4     default     inactive
  3/6     default     inactive
  3/8     default     inactive
  3/10    default     inactive
  3/12    default   forwarding
  3/14    default   forwarding
  3/16    default   forwarding
  3/18    default   forwarding
  3/20    default     inactive
->  show mac-address-table 110
Legend: Mac Address: * = address not valid
   Vlan      Mac Address          Type       Protocol    Operation    Interface
   110    d0:94:66:83:00:66        learned         ---      bridging      1/10
   110    d0:94:66:82:ea:2d        learned         ---      bridging      1/12
   110    d0:94:66:83:0b:35        learned         ---      bridging      1/14
   110    d0:94:66:82:fb:93        learned         ---      bridging      1/16
   110    d0:94:66:83:09:34        learned         ---      bridging      1/18
   110    d0:94:66:7d:4b:32        learned         ---      bridging      1/20
   110    00:e0:ec:4e:fa:5a        learned         ---      bridging      2/2
   110    d0:94:66:7d:32:b8        learned         ---      bridging      2/10
   110    d0:94:66:82:fd:cd        learned         ---      bridging      2/12
   110    d0:94:66:7d:81:7d        learned         ---      bridging      2/14
   110    d0:94:66:83:0c:e6        learned         ---      bridging      2/16
   110    14:02:ec:33:a9:7c        learned         ---      bridging      3/2
   110    1c:98:ec:15:69:04        learned         ---      bridging      3/12
   110    1c:98:ec:16:11:a0        learned         ---      bridging      3/14
   110    1c:98:ec:15:39:e4        learned         ---      bridging      3/16
   110    1c:98:ec:16:11:e4        learned         ---      bridging      3/18
Total number of Valid MAC addresses above = 16
eugene
Post by eugene »
I forgot to mention that I still cannot ping the interface. Removing proxy-arp didn't change anything :P
Can you ping in the other direction - from a computer to the switch (all in the same vlan)? Can you find your devices within the mac-table and arp-table (show arp) within the correct vlan?
Have you checked your clients: firewall, are there other interfaces like wlan, VMware or VPN (if yes disable them)....?
Are this behavior for all the clients and ip interfaces the same?
Put the output also for "show arp" and all the config "show configuration snapshot".
eugene
Post by eugene »
This is hardly a good answer but the vlan interface worked after a hard reset of all the switches in the stack. What I did was:
  1. Disconnect all stacking cables
  2. Reboot all switches
  3. On each switch, run
    rm /flash/working/boot.cfg
    rm /flash/certified/boot.cfg
  4. Reboot the switches and reconnect the stacking cables
I had the luxury of fixing switches not in production, so this isn't a solution for everyone. I suspect that the source of my problems was using the switches out of the box. I had crazy problems with the OS6900 ootb as well, and I fixed it by wiping out the default config and anything that's auto-configured.
Thanks for your solution. I prefer allways to do an update also at brand new switches.
For the OS6900/OS6860 there are some posts how to disable autofabric functions. Most people didn't understand how the lot of build-in autoconfigs are work and so its better to disable all of them.
Return to “OmniSwitch 6450”
