Stack with 2 OS6450-10
tchup
Post by tchup »
I can not to stack 2 switchs OS6450-10 with connector SFP (ports : sw1/11 and sw2/12)
Ports sw1/11 and sw2/12 are down :
sw1 :
stack set slot 1 mode stackable
reload
after reload :
-> show stack status
Redundant cable status  : not present
Tokens used             : 1
Tokens available        : 31
-> show stack topology
                                         Link A  Link A          Link B  Link B
NI      Role      State   Saved  Link A  Remote  Remote  Link B  Remote  Remote
                          Slot   State   NI      Port    State   NI      Port
   1 PRIMARY     RUNNING    1    DOWN        0        0  DOWN        0        0
-> show stacking interfaces
 Slot/Port  1/11 :
          Operational Status     : down,
          Last Time Link Changed : FRI DEC 01 01:18:06 ,
          Number of Status Change: 0,
          Type                   : Stacking,
 Slot/Port  1/12 :
          Type                   : Stacking,
-> show ni
Module in slot 1
  Model Name:                    OS6450-10,
  Description:                   8 10/100/1000 + 2 Combo + 2 5G STK/UPLINK,
  Part Number:                   903770-90,
  Hardware Revision:             03,
  Manufacture Date:              JAN 25 2019,
  Firmware Version:              ,
  Admin Status:                  POWER ON,
  Operational Status:            UP,
  Power Consumption:             22,
  Power Control Checksum:        0x4cec,
  CPU Model Type   :             ARM926 (Rev 1),
  ASIC - Physical 1:             MV88F6281 Rev 2,
  FPGA - Physical 1:             006/00,
  UBOOT Version :                n/a,
  UBOOT-miniboot Version :       6.7.1.54.R02,
  POE SW Version :               n/a
  GBIC  11
        ALU Model Name:                SFP-GIG-T,
        ALU Model Number:              903431-90,
        Hardware Revision:             A,
        Manufacture Date:              190328,
        Laser Wave Length:             n/a,
        DDM Capable:                   No,
-> show stack mode
NI      Role      State   Running        Saved
                          Mode           Mode
   1 PRIMARY     RUNNING    stackable     stackable
sw2 :
stack set slot 1 saved-slot 2
reload
after reload :
Tokens used             : 1
   2 PRIMARY     RUNNING    2    DOWN        0        0  DOWN        0        0
 Slot/Port  2/11 :
          Last Time Link Changed : FRI DEC 01 03:42:48 ,
          Type                   : Stacking,
 Slot/Port  2/12 :
          Type                   : Stacking,
-> show ni
Module in slot 2
  Firmware Version:              ,
  Power Control Checksum:        0xbde1,
  GBIC  12
        DDM Capable:                   No,
-> show stack mode
                          Mode           Mode
   2 PRIMARY     RUNNING    stackable     stackable
Thanks for helping
Re: Stack with 2 OS6450-10
Do you use a DAC (direct attached copper cable) for it? Because for this 10port-models the stacking speed is 5G only this direct cable are working.
tchup
Post by tchup »
no just connectors + RJ45 !
there is no specific cable on the datasheet
tchup
Post by tchup »
I found this :
https://www.al-enterprise.com/-/media/a ... eet-en.pdf
OS6450S-CBL-60 = 60 cm long SFP+ direct stacking cable for OS6450 24- and 48-port models
but not for 10 ports models... :?
I will test
this cable works too for 10port-models. You have to use the stacking ports 11 and 12 (SFP).
tchup
Post by tchup »
i don't understand
the stack now works with OS6450S-CBL-60 and command line "stack set slot 1 mode stackable"
with the command "stack set slot 1 mode stackable" you change the function of the ports 11 and 12 from normal uplink to stack (stk A and stk B). Only this ports are possible for stacking. Because it works now you have done this correctly.
Return to “OmniSwitch 6450”
