OTC IPHONE and OTBE R2
jpissot
Post by jpissot »
I am installing a OTBE R2.0. I have to install OTCv PC and OTC ON Iphone. OTCv PC works fine.
I have some questions for OTC Iphone :
1- For OTC for Iphone, I know that I have to add a reverse proxy (Nginx in my case) but I don't know why? Can you explain me its purpose?
2- Can I use OTC Iphone without reverse proxy, only configuring ports redirection on the firewall.
3- How I configure the reverse proxy knowing that the public FQDN of my customer is different that the internal FQDN?
3- To access to the OTBE in mode 3G/4G with OTC application, can I replace the public FQDN by the public IP address?
Thank you for your help.
Re: OTC IPHONE and OTBE R2
If it is there is because is needed. Read Deployment documentation. Reverse Proxy is a must for NAT environments
Return to “OpenTouch Conversation”
