Unable to create OT user in OTMS
mathankumarct
Post by mathankumarct » 08 Jan 2017 03:52
Hi All,
I installed an new OTMS and configured all the mandatory parameters including OT and OXE profiles.
When i try to create the OT user via 8770-->User tab, i am getting below error
[11:40:17 AM] > Partial failure: Partial success: The user is created in the OT node cudotms01; But failed to create the corresponding user in the OXE node cudoxe01. Error from the OXE: error during createconfigEx is null.
anyone know this error? please help me if you know the solution to solve this.
Thanks..
Rgrds,
Mathan
rolfo333
Re: Unable to create OT user in OTMS
Post by rolfo333 » 11 Jan 2017 08:35
Hello Mathan,
is your SIP trunk including the External Gateways configured alright?
For Conversation Users you should have a profile on OXE which is a SIP device using the correct external gateway.
Just a guess, I did not find this error message anywhere in the Technical Knowledge Base of ALE so far.
Br
rolfo
mathankumarct
Post by mathankumarct » 05 Feb 2017 08:16
The issue is solved by deleting and recreating the OXE node in 8770 configuration.
this is not the solution. but, this solved the issue.
Rgrds,
Mathan
morio
Post by morio » 22 Oct 2017 13:30
yea i face the same issue on a OTMS as well. ALE tech team advised to delete the OXE tree and create again. then it worked out fine.
Return to “OTMS - OpenTouch Multimedia Services”
