Dear,
I am a beginner in the OT, and I have a problem, I have already installed the application, but when trying to deployment 8088, the same resets after step 3, after reset on the display the following message is displayed.
Could not retrieve the following files:
https://ipserver/dmictouch/config.mac.xml and $ {ENETCFG_SIP_FILE}
I sincerely looked in the documentation and found no solution.
I would like a response from the gentlemen who have more experience, thank you very much already.
att,
Adriano Santos
Deployment 8088 deskphone
- cavagnaro
Re: Deployment 8088 deskphone
Search forum. You have to declare your phone so it creates a xml file for your device.
Okay, but when trying to sign the certificate with the 8088, but the device's display shows the information that the set was not declared as a signing device, it is not accepted? Can I just use 8082?
You must declare in webadmin the mac of the signing device
Gesendet von meinem A0001 mit Tapatalk
ACFE OXE R11.1 | ACSE OpenTouch R2.0 | ACSE 8770 R2.5
Re: Deployment
I am having trouble signing the certificate in version 2.3, when trying to sign with 8082 appears the message that the device is not enabled to sign the certificate, someone knows how to resolve this failure.
Doublezero gave the answer...
Check systemdocs step by step and it will work.
