Automatic failover from LAN to SIM??
masterdaniel007
Post by masterdaniel007 » 10 Feb 2015 00:54
Hi All,
I have configured LAN interface as well as the SIM interface on 5720. While using these interfaces individually I can ping internet. I want to achieve H.A.i.e when LAN goes down it should switch to SIM card for connectivity. For that i have given two default routes as follows:-
1) route 0.0.0.0 0.0.0.0 192.168.1.1
2) route 0.0.0.0 0.0.0.0 ppp1 distance 10
but when i remove the lan interface to test this setup, it does not failover to pp1 interface(sim card interface)!!!
Please provide your help for the same.
escala14
Re: Automatic failover from LAN to SIM??
Post by escala14 » 23 Jun 2016 02:01
Config>feature wrr-backup-wan
pair 1 primary interface ethernet0/0 secondary interface cellular1/1
stabilization-time 60s
enable
Backup WRR>
This works if physical link connection is unplug or the end device is power-off(not port shutdown)
Return to “OmniAccess ESR 5720”
