Temperature
Mhunter1993
Temperature
Post by Mhunter1993 » 31 Aug 2016 17:12
Is it possible to monitor the temperature of a 6860 switch. I'm using Omnivista 2500 NMS yet the switch itself seems incapable of showing the temperature. This doesn't seem to be a problem on 6450 switch.
Re: Temperature
Post by silvio » 01 Sep 2016 14:36
At CLI it works - so it will also work in cli of OV.
6860E> show temperature
Chassis/Device | Current |  Range  | Danger | Thresh |  Status
 1/CMMA            53       15-81      81       86     UNDER THRESHOLD
Mhunter1993
Re: Temperature
Post by Mhunter1993 » 01 Sep 2016 15:00
It seems that the temperature can be showed and monitored through the Omnivista yet, I cant change the threshold through the Omnivista server. Also it doesn't display the temperature or the threshold at the webview.
Thanks for your help Silvio
