Firmware upgrade
alcomint
Firmware upgrade
Post by alcomint » 06 Sep 2016 05:47
Hi all,
What is the procedure to upgrade the firmware at 6860/6860E, how many files do I required?
I have only Uom.img but in software.lsm it tell about other files as well such as
Primary-site: file:Udiag.img, 41312164
Primary-site: file:Uos.img, 212309712
Primary-site: file:u-boot.8.1.1.R01.664.tar.gz, 588730
Can you please guide me through ?
Best Regards,
MicahNguyen
Re: Firmware upgrade
Post by MicahNguyen » 06 Sep 2016 06:24
Only one file and put it inside /flash/working
Then reload 6860E from working.
Do synchronization between /flash/working and /flash/certified after reloaded
Done
MicahNguyen
Done
alcomint
Post by alcomint » 06 Sep 2016 06:47
How to do reload from working?
can you please list the commands, first time I am touching 6860 box.
I have this error as well
OS6860e-U28-> copy flash-synchro
ERROR: Attempt to copy working to cert w/flash synchr failed
Post by silvio » 07 Sep 2016 01:41
copy flash-synchro is for synchr within a VC/Stack to the other chassis.
you need: copy running certified
Best way is to use: write memory flash-synchro
In switch management guide all is written.
Post by silvio » 07 Sep 2016 01:42
> reload from working no rollback-timeout ist the command
