Factory Reset without knowing the password
josefranciscolerena
Post by josefranciscolerena » 16 Dec 2016 05:38
I have a 6860 buy I don't know the password to access.
I need to do a factory reset
Thanks in advances
devnull
Re: Factory Reset without knowing the password
Post by devnull » 20 Dec 2016 02:51
Should be similar to to 6900, so you need TRescue on an USB (you can get that from support), break the boot sequence, "run rescue" and "setAdminPasswordDefault".
See also:
viewtopic.php?t=23506
