enable sip snooping
sb0526
enable sip snooping
Post by sb0526 » 24 Oct 2017 05:11
dear sir
i want enable the sip snooping in OS6860E follow command
-> sip-snooping admin-state enable
ERROR: Cannot be enabled as qos phones is already enabled
Please wait...
what issue in this error?
Re: enable sip snooping
Post by silvio » 25 Oct 2017 12:03
you can check with "show qos config" - qos phones is enabled per default.
You can disable with "no qos phone"
