Application Visibility
rnevola
Post by rnevola » 11 Dec 2017 11:49
Hi all
I am with problem for loading kit Application Visibility. Someone is witch same problem? See below.
Thanks advance
Re: Application Visibility
Post by silvio » 12 Dec 2017 09:32
what is the release at your switch(es) and in OV? For the actual releases (since more than one year) there is no need of any license. OV 4.2.1 hasn't this license (actual there is 4.2.2). I guess your "old" omnivista tries to load the licenses in actual switches - but they didn't know the licenses.
rnevola
Post by rnevola » 12 Dec 2017 12:24
I am using 4.2.2. Kit UApp - 2.1.4. Weird, because was working, but I made upgrade in my OV, and AppVisibility stopped.
Nevola
Post by silvio » 13 Dec 2017 06:29
Can you try to install a new OV (since today there is build92 for 4.2.2) instead of update. Otherwise you should open a SR.
rnevola
Post by rnevola » 13 Dec 2017 12:19
I solved I reset the switch, and it worked again.
Thanks !
Nevola
Post by silvio » 14 Dec 2017 02:43
