CLI commands 6860 vs 6850
Locked
mouthpiec
Post by mouthpiec »
I have a couple of 6850 routers which need to be replaced with 6860 routers.
Is there a doc showing config mappings/difference since the commands are different?
David_Klancar
Re: CLI commands 6860 vs 6850
Post by David_Klancar »
Hi Mouthpiec!
I've never seen one, basically you need to transcode R6 commands to R7/8 commands... Can I help you with that?
David
mouthpiec
Post by mouthpiec »
hi david,
till now i am managing :) but it takes a lot of time.
I thought there is a sort of mapping somewhere. If I get stuck somewhere I will let you know.
thanks for getting back to me
priyanjan
Post by priyanjan »
mouthpiec wrote:Hi,
6850 and 6860 are switches !!! Not much different though. Same commands and same configuration file can be updated as long as ports are same !!!
Sent from my Nexus 6P using Tapatalk
Here you will find the most changing of commands from R6 (6850) to R7/R8 (6900/6860 etc.)
http://dokuwiki.alu4u.com/doku.php?id=a ... _cli_delta
mouthpiec
Post by mouthpiec »
silvio wrote: 15 Jan 2018 06:58 Here you will find the most changing of commands from R6 (6850) to R7/R8 (6900/6860 etc.)
Thanks Silvio ... this is exactly what I was asking for!
Locked
