stacking of 6860
jagzeer
stacking of 6860
Post by jagzeer »
Hi, guys
Just curious if we can form virtual chassis with same model of 6860 but different ports.
Let say OS6860E-48 and OS6860E-P24 stack together. The other switch not POE capable and diff ports.
Based on the guide "A virtual chassis cannot contain a mix of different families of switches (i.e OS6900 and OS6860)." Although I havent tried mixing 6860 switches to form a stack.
For 6900 it was mentioned that it is supported as long all switch in 6900 family.
"all models Omniswitch 6900 (x20, x40, T20, T40, Q32 and X72) can form a VC up to six units with any combinaiton of models.
Just not sure though of the 6860 support the same thing and if there will also be no issue.
devnull
Re: stacking of 6860
Post by devnull »
Yes you can.
You can mix in a VC different devicetyps of the same Series. (same as in Stacks of 6450, .. ..)
So no problem with mixing PoE and non PoE.
I am not 100% sure with "E" Modells if you utilize features of the "E" Modell - Application Monitoring/DPI? than some restrictions may apply.
I had stacks of 6860-U28 and 6860-48 as well as PoE and Non PoE versions.
jagzeer
Post by jagzeer »
I see. Thanks for the info devnull.
