Switch came with R8.4.1 but already it is having default advanced routing licenses
But sales team given me the license for ADV routing but right now I have generated the licenses for the same switch is it possible to de activate and we can use the same activation code for other serial numbers ?
Is it possible to de activate the activation code for already license generated switch
Re: Is it possible to de activate the activation code for already license generated switch
Is it possible to use the licenses for future ???
Because all switches came with latest release
not realy. Since half a year the advanced license is activated for free with the actual AOS. You can only use this lic for already installed switches with older releases. But also if you update this switches to the 8.4.1R3 or 8.5.1 the license will be activated automaticly.
