Static Route to Null
mouthpiec
Post by mouthpiec » 31 May 2018 14:05
I need to advertise a static IP through BGP, but for this to work I need to have a static route for this IP address.
Is there a way to make a route to null or blackhole?
I tried route towards 127.0.0.1 and also towards the IP interface configure on the switch but I am getting an error that I cannot route towards an interface that exists on the switch.
Any help?
benny
Re: Static Route to Null
Post by benny » 01 Jun 2018 03:36
Starting AOS >= 7.3.4.236.R02 (and later) you should be able to use this command to create a black hole route:
-> ip static-route 2.2.2.2/32 interface Loopback metric 1
Benny
mouthpiec
Post by mouthpiec » 01 Jun 2018 07:23
thanks Benny.
Will try it out.
mouthpiec
Post by mouthpiec » 01 Jun 2018 11:17
worked great Benny!
thanks again
