Configuration OmniTouch 8118&8128
Everything about the PWT, IBS, RBS, DECT..
yoganza_88
Post by yoganza_88 » 31 Jul 2011 23:17
I have problem with my OmniTouch 8118 and 8128,
the topology
Omni Access 4038 (Wireless Control ) <---------- Switch ( OmniSwitch 6850 P24) -------->Call Server (R9.0) & Media Gateway
The OmniTouch when i scan the wireless, the OmniTouch detect the wireless SSID but can't connect ( NO Network).
How to configure the OmniTouch 8118 and 8128?
yoganza_88
Re: Configuration OmniTouch 8118&8128
Post by yoganza_88 » 01 Aug 2011 05:15
any one help me...
Konstantinos.E
Post by Konstantinos.E » 01 Aug 2011 06:29
hi
when it scans the network press 400222.configure ipadress ssid and so on...
Alca_holic
PabloR
Post by PabloR » 28 Nov 2012 09:04
I have the same problem
I have a customer with new 8128 MIPT and AP105. The customer dial 40022 to enter the admin menu, He scans all channels and he select the network.
when he select the network and put the correct key, the 8128 stay remains in search mode.
The user is configurated in the CS with set type Mobile IPTouch. We have also configured the Mac
We tested with static IP and DHCP.
Any idea?
Konstantinos.E
Post by Konstantinos.E » 28 Nov 2012 10:14
hi
check the ssid, passphrase,encryption,choose static config,manual config of tftp and tftp download.
Alca_holic
PabloR
Post by PabloR » 28 Nov 2012 10:57
do you refer all the configuration in the 8128 terminal?
thx
PabloR
Post by PabloR » 29 Nov 2012 07:15
RESOLVED!
We needed to put tftp configuration.
Thx guy!
ademuynck
Post by ademuynck » 03 Dec 2012 13:53
PabloR wrote:RESOLVED!
Thx guy!
Can you explain what you mean by "put tftp configuration" ?
wagnerboccaldi
Post by wagnerboccaldi » 01 Apr 2014 09:24
hello... I'm facing the same problem here... I have configured the phone but it is still showing the 'no network' message. Can any one help me? Thanks in advance
serskine
Post by serskine » 11 Jul 2015 09:12
Does anyone know the default user and password for accessing the logs via a web browser?
Return to “Wireless configuration and sets”
