Lanpower active is not show in the configuration
resorte
Post by resorte »
hello
Somebody know why in some devices if active lanpower with "lanpower start 1" or desactive "lanpower stop 1" AOS don´t display the advice that say if the daughter module is on or off. Even if the module is on, you can't see the line "lanpower start 1" in the configuration snapshot. You can see that is on because the status command.
I have this issue in a OS6350-P48 release 6.7.1.146.R01 GA, and in a OS6350-P24 release 6.7.2.49 R01 GA. But I have other P48 with the same release 6.7.1.146 and this device not show this issue.
Some idea?
Re: Lanpower active is not show in the configuration
If I remember correctly there where a known issue with this behavior. Best way will be an update to the newest release 6.7.2.112.R03_MR and test again.
resorte
Post by resorte »
ok, I guess is the best too, I doubted it because the same version work right in other sw.
Return to “OmniSwitch 6350”
