Console Port Connection
shijad007
Post by shijad007 » 09 Mar 2018 09:56
I have recently brought a Alcatel OS6350-P10 switch. I want to configure this switch through console port. I have a DB9 connector which I have got with the switch and a RJ-45 cable. How to I connect my PC to console port? Also tell me which type of RJ-45 cable I should use to access console port(Straight through, Crossover or Rollover). Please help.
devnull
Re: Console Port Connection
Post by devnull » 15 Mar 2018 04:57
Never used a 6350 for all others it was
DB9@PC + Alcatel Adapter DB9-RJ45 (provided with switch) + normal Ethernet Cable
Setting 9600/8/n/1
But: would'nt it be easier to read the manual or try the different cables instead of spamming every board you find?
Return to “OmniSwitch 6350”
