Lanpower system reset. failed
Mohammadlinux
Post by Mohammadlinux » 26 Jul 2018 05:52
I have problem with os6350-p24.when in use "lanpower start 1" command i received this message.
+++ Device Fail devFail ff devFailOld f8 prv label 0 temp disc 0 alrm 0 int 0
+++ Lanpower system reset. failed
SUN DEC 31 01:03:37 : LANPOWER (108) error message:
+++ lpStateMachine: Error in State 2. Stopping Daughter Module!
SUN DEC 31 01:03:37 : LANPOWER (108) info message:
+++ NI Shutting down daughter module!
+++ Shutting down daughter module in slot 1!
and this is "show microcode" command
Package Release Size Description
KF3base.img 6.7.1.146.R01 15731120 Alcatel-Lucent Base Software
KF3os.img 6.7.1.146.R01 2651652 Alcatel-Lucent OS
KF3eni.img 6.7.1.146.R01 6414930 Alcatel-Lucent NI software
KF3secu.img 6.7.1.146.R01 589990 Alcatel-Lucent Security Management
what dose that mean?!
Re: Lanpower system reset. failed
Post by silvio » 26 Jul 2018 14:18
If I remember correctly than there was a problem in software. Make an update to the newest AOS 6.7.2R04 include FPGA and UBoot.
Mohammadlinux
Post by Mohammadlinux » 07 Aug 2018 02:47
Thank you.
How can i get the last version ?
Post by silvio » 08 Aug 2018 12:41
from the business partner portal. But if you haven't access you have to ask your distributer/seller of the switches.
Return to “OmniSwitch 6350”
