Doc for Programing AA
If you wrote a good one, share it with us !
m0e
Post by m0e » 24 Aug 2007 03:27
Dear All,
Does anybody can provide Documentation for Programing Automatic Attendant. I have read the doc, but I can not understand until I have some example. If there is someone can post it would be great for our knowledge.
knightr1der
Re: Doc for Programing AA
Post by knightr1der » 24 Aug 2007 05:28
Please post what you want the AA to do
EG,
Main menu(A) option 1 = XXXX, 2 = YYYY 3 = new menu(B)
Menu B option 1 = ZZZZ
XXXX = 1 set
YYYY = vm
zzzz = group parallel
etc...
History repeats itself - because no one listens the first time!
ACSE List
- Rel 9.x Corp
- IP Advanced
- CCD Expert
- OmniTouch CC Premium R8.x
Post by vad » 24 Aug 2007 05:56
AA on PBX or on Voice Mail (4635/4645)?
rotonpur_DUP
Post by rotonpur_DUP » 30 Aug 2007 10:02
If it's OXE, i CAN TELL YOU SOMETHING AS I KNOW VERY SIMPLY. CREATE AN ACCESS POINT, TREE AND LEAF .CONFIGURE THE LEAF AND SPECIFY THEM FOR A TREE AND SPECIFY TREE TO AN ACCESS POINT. CREATE A PREFIX TO REACH THAT ACCESS POINT THROUGH A TRUNK GROUP.
Post by cavagnaro » 31 Aug 2007 00:30
rotonpur, as you know capital letter are like yelling on the internet world, so please be carefull when you make a post.
rotonpur_DUP
Post by rotonpur_DUP » 31 Aug 2007 05:52
Thank you Mr. Cavagnaro, i didn't know that, and I was in hurry while i was writting that so even i noticed i didn't made that correct , thought that it's ok if it can express only what i want to mean. I will be carefull about that in future.
katyusha
Post by katyusha » 16 Sep 2007 07:16
I have some documents for configuring A.A. but who can tell me how to upload file.
Post by cavagnaro » 16 Sep 2007 23:20
Just go to pastebin section....
kabersystem
Post by kabersystem » 26 Mar 2017 03:54
I also need a programming guide for utomatic attendant. The guy who installed the licence had a document but he didn't want to share with us.
I had few questions , if it is possible, but he said no, it is not possible and no comments.
Thank you.
Mihaela
Post by cavagnaro » 26 Mar 2017 15:08
Download system documentation, it is available here
Return to “Documentation”
