Changing web certificate
asalgueiro
Post by asalgueiro »
Hi guys,
I'm just finishing a OmniVista 4.3R1 installation, and my customer asked me if the web certificate can be changed to a new one signed-in by a internal CA.
After reading the documentation I can not understand how to generate the *.csr file to be signed by CA, the only information in the pdf file (OV2500_NMS-E_4.3.R1_Installation_and_UpgradeGuide_RevB.pdf) is:
"Update OmniVista Web Server SSL Certificate
To update the OmniVista Web Server SSL Certificate, you must first generate a *.crt and *.key file and use an SFTP Client to upload the files to the VA. Make sure the destination directory is “keys”
Any ideas ?
Thanks,
André
asalgueiro
Re: Changing web certificate
Hi guys,
I believe that I found the answer:
https://alcatel-lucent-enterprise.secur ... 000kEmI&q=
If you want to use windows to generate a csr/key file, you can check this guide:
https://www.youtube.com/watch?v=EQ36w0snsdE
I hope this helps someone.
André
