Switche OS6350 not showing in OMNIVISTA 2500 NMS even though I have configure SNMP in my access switch like this:-
! SNMP :
snmp security no security
snmp community map "default" user "test" on
snmp station 10.253.0.101 162 "test" v2 enable
Can some one help me???
Switches are not able to discover in OMNIVISTA 2500 NMS
Re: Switches are not able to discover in OMNIVISTA 2500 NMS
Have you created user named test?
Do "show user" and see if user named test has snmp enabled.
also you need for v2 the following:
And have you created within OV the community default and associated this snmp-setup to your ip-ranges (or direct to device)?
user test password not-important read-only all no auth
aaa authentication snmp local
Hi All,
Yes i created user named test and created within OV the community default and associated this snmp-setup to my IP-ranges!!!!
what can i do???!!!!
Please post "show user".
And try to use an other community than "default". Maybe this isn't a good idea.
Also I prefer to use snmpv3 - it is more easier to configure. In my cases it works always without any issues.
