SIP External Gateway OXE with Vono
A H323 and SIP forum only !
giovanni.attolini
Post by giovanni.attolini » 18 Jul 2013 11:31
Hi for all,
Here in Brazil we have a VoIP provider called Vono. I am trying to put in operation a SIP Ext. Gateway with this VoIP provider and I discovered that to make this functional I need to send the username in "From" field, something like:
Is that possible in OXE today? Can I translate an internal number to a name? Can I assign this configuration to all calls made from that specific Ext. Gateway?
From docs I understood that is only possible to translate an internal user number to an external number using "DID numbering translator" and "Numbering PLan Description NPD".
Thanks for all
Giovanni A. Attolini
Brunno
Re: SIP External Gateway OXE with Vono
Post by Brunno » 14 Apr 2014 15:06
Boa tarde Giovanni,
evoluiu em algo?
Acho que não é possível. =/
Acredito que a única forma seria usando um SBC Da Audiocodes pois ela faz tradução de tudo em Sip.
Att
Brunno
ACSE Opentouch R1.1
ACSE OXE 10.1
giovanni.attolini
Post by giovanni.attolini » 14 Apr 2014 15:58
Dae Bruno,
Não evoluiu, acabamos trocando a operadora no cliente. Tentei conversar com os técnicos da Vono mas sem sucesso então optei pela troca e o cliente aceitou.
Without evolution, we change the voip provider. I tried to talk with provider technicians but without success, so my solution was changing the voip provider under customer approval.
Post by haroun » 15 Apr 2014 03:49
we need mr Ronaldo Google to translate lol
alisongroove
Post by alisongroove » 05 Feb 2016 06:31
Srs , sei que não é a aplicação recomendável, soou meio como "gambiarra", mais efetuei essa instalação utilizando um OXO no lugar do SBC e integrando via SIP com o Enterprise, funciona bem.
Post by cavagnaro » 05 Feb 2016 08:07
Next time also include english please.
He says that he used an OXO instead of an SBC (no clue how they compare) and worked.
Return to “H323 / Sip”
