quick howto - asterisk by ooh323 trunk to OXE
A H323 and SIP forum only !
krzysioD
Post by krzysioD » 07 Oct 2014 07:10
Anyone has some quick-steps, as i'm stuck:
one number from asterisk by sip trunk coming to OXE need to put by h323 trunk.
small mg common hw on oxe, ip trunk group (other than sip) created, in astersisk - peer for oxe configured, but - tcpdump says that MG board does not answer for tcp/1720:
13:09:40.051334 IP asteriskbox.12037 > 192.168.200.2.1720: Flags [S], seq 131762021, win 5840, options [mss 1460,sackOK,TS val 250251573 ecr 0,nop,wscale 6], length 0.
Re: quick howto - asterisk by ooh323 trunk to OXE
Post by tot3nkopf » 07 Oct 2014 08:31
See this:
viewtopic.php?f=227&t=14231
Cav will hunt you down :lol: :lol: :lol:
krzysioD
Post by krzysioD » 07 Oct 2014 09:03
Well, as for SIP, i do know that :)
but config of GD board for h323 is not mentioned there (or am i blind?) :(
Post by cavagnaro » 07 Oct 2014 09:55
Who invoked my name? lol
Nahh...coming from Krzys he must be searched already :D
Post by tot3nkopf » 07 Oct 2014 10:46
krzysioD wrote: but config of GD board for h323 is not mentioned there (or am i blind?) :(
What config on GD?
The only thing that you need to do on the GD1 and GD2 is to configure the No of compressors for Gateway. For GD3 just need to check if you have unassigned compressors left (you can only define the number of compressors allocated to IP devices).
Do you want to use a gatekeeper?
krzysioD
Post by krzysioD » 07 Oct 2014 15:13
gd - access on ip trunk group, but this is iirc only for abc-ip and vpn hop overflow.
heh, guys, im getting OLD!
krzysioD
Post by krzysioD » 07 Oct 2014 15:16
                                      ┌─Consult/Modify: Board──────────────────────────────────────────────┐
                                      │             Node Number (reserved) : 101                           │
                                      │                      Shelf Address : 7                             │
                                      │                      Board Address : 0                             │
                                      │                     Interface Type + GD                            │
                                      │                      Virtual board + NO                            │
                                      │                      Serial number : --------------                │
                                      │                        Usage State + Busy                          │
                                      │                  Operational State + Enabled                       │
                                      │                 Main/Standby State + Main (Master)                 │
                                      │      Number Of Sets Being Connect. : 1                             │
                                      │                            Country + Default                       │
                                      │              Incidents Teleservice + YES                           │
                                      │               GD/GA Daughter Board + MADA3                         │
                                      │      Nb of Compressors for Gateway : 8                             │
                                      │   Nb of Compressors for IP Devices : 8                             │
                                      │       Number of N part conferences : 1                             │
                                      │                        Zone Paging + YES                           │
                                      │            Use of volume in system + YES                           │
                                      │                 Local volume (dB)  : 0                             │
                                      │                 AFU daughter board + NO                            │
                                      │               AFU Directory Number : --------                      │
                                      │                         eMG rescue + NO                            │
                                      │                      e-RMA feature + NO                            │
                            ┌─Consult/Modify: Ethernet Parameters───────────────────────────────────────────────────┐
                            │              Shelf - Board Address : 7-0                                              │
                            │                   Board IP Address : 192.168.200.2                                    │
                            │                         NetMask IP : 255.255.255.248                                  │
                            │         Default Gateway IP Address : 192.168.200.1                                    │
                            │              IP Quality of service : 0                                                │
                            │          Cryptographic box address : -----------------------------------------------  │
                            │             Board Ethernet Address : 00:80:9F:38:58:46                                │
                            │       Interworking with Gatekeeper + NO                                               │
                            │                      Gatekeeper Id : -1                                               │
                            │   Numb. of sig. channels IP Phones : 0                                                │
                            │   Numb. of sig. channels inter ACT : 0                                                │
                            │                   IP Domain Number : 4                                                │
                            │             E164 Number List Index : 0                                                │
                            │                  Gateway H323 name : --------------------------------                 │
krzysioD
Post by krzysioD » 07 Oct 2014 15:26
We don't need no gatekeeper :)
krzysioD
Post by krzysioD » 08 Oct 2014 06:03
Going to kill it guys again :) now only no B channel:
| (515622:000002) Concatenated-Physical-Event :
| long: 94  desti: 0  source: 0  cryst: 7  cpl: 0  us: 0  term: 0  type a5
| tei: 0  >>>>  message received : SETUP [05]    Call ref :  00 0c
|                               SENDING COMPLETE
| IE:[18] CHANNEL (l=1)  a3 -> T2 : Any B channel
| IE:[28] DISPLAY (l=10)  `223566712`
| IE:[6c] CALLING_NUMBER (l=11)  ->  01  80  Num : 223566712
| IE:[70] CALLED_NUMBER (l=4)  ->  81  Num : 301
| [97] Locking shift. codeset : 7
| IE:[06] EI_IP_PAYLOADS (l=1) -> G711a Ece 0 Vad 0
| IE:[0a] EI_RTP_INFO (l=30)
|    -> stop_packet=0 stop_rtp=0 h323=1 wc=0 rf=0 udp=0 rqm=0
|    -> Transm_Bande=0 detection_Q23=1
|    -> Port RTP     = 17566, IPv4 :   194.  152.   46.  182.
|    -> Port RTCP SR = 17567, IPv4 :   194.  152.   46.  182.
|    -> Port RTCP RR = 17567, IPv4 :   194.  152.   46.  182.
|    -> Port Fax     = 0, IPv4 :     0.    0.    0.    0.
| (515622:000004) 1052: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 29  desti: 0  source: 15  cryst: 7  cpl: 0  us: 8  term: 0  type a5
| tei: 0  <<<<  message sent : CALL PROC (02)  Call ref :  80 0c
| [9f] Non-locking shift. codeset : 7
| IE:[07] EI_IP_QOS (l=3) b8 a0 00
| IE:[18] CHANNEL (l=3)  a8 83 81 -> T2 : No B channel
| (515622:000005) 1052: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22  desti: 0  source: 15  cryst: 7  cpl: 0  us: 8  term: 0  type a5
| tei: 0  <<<<  message sent : DISCONNECT [45]  Call ref :  80 0c
| IE:[08] CAUSE (l=2) 81 9b -> [9b] DESTINATION OUT OF ORDER
| (515622:000006) 1052: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 55  desti: 0  source: 15  cryst: 7  cpl: 0  us: 8  term: 0  type a5
| tei: 0  <<<<  message sent : FACILITY [62]  Call ref :  80 0c
| IE:[06] EI_IP_PAYLOADS (l=1) -> G711a Ece 1 Vad 0
|    -> stop_packet=0 stop_rtp=0 h323=0 wc=0 rf=0 udp=0 rqm=0
|    -> Transm_Bande=1 detection_Q23=1 dtmf_payload=96
|    -> Port RTP     = 32632, IPv4 :   192.  168.  200.   10.
|    -> Port RTCP SR = 32633, IPv4 :   192.  168.  200.   10.
|    -> Port RTCP RR = 32633, IPv4 :   192.  168.  200.   10.
|    -> Port Fax     = 32635, IPv4 :   192.  168.  200.   10.
| (515624:000008) Concatenated-Physical-Event :
| long: 22  desti: 0  source: 0  cryst: 7  cpl: 0  us: 0  term: 0  type a5
| tei: 0  >>>>  message received : RELEASE [4d]   Call ref :  00 0c
| IE:[08] CAUSE (l=2) 81 90 -> [90] NORMAL CALL CLEARING
| (515624:000009) 1052: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0  <<<<  message sent : REL COMP [5a]  Call ref :  80 0c
| (515624:000010) Concatenated-Physical-Event :
| tei: 0  >>>>  message received : REL COMP [5a]  Call ref :  00 0c
| IE:[08] CAUSE (l=2) 81 e5 -> [e5] MESSAGE NOT COMPATIBLE WITH CALL STATE
| (515633:000011) Concatenated-Physical-Event :
| tei: 0  >>>>  message received : SETUP [05]    Call ref :  00 0d
|                               SENDING COMPLETE
|    -> Port RTP     = 12306, IPv4 :   194.  152.   46.  182.
|    -> Port RTCP SR = 12307, IPv4 :   194.  152.   46.  182.
|    -> Port RTCP RR = 12307, IPv4 :   194.  152.   46.  182.
| (515633:000013) 1052: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0  <<<<  message sent : CALL PROC (02)  Call ref :  80 0d
| (515633:000014) 1052: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0  <<<<  message sent : DISCONNECT [45]  Call ref :  80 0d
| (515633:000015) 1052: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0  <<<<  message sent : FACILITY [62]  Call ref :  80 0d
|    -> Port RTP     = 32656, IPv4 :   192.  168.  200.   10.
|    -> Port RTCP SR = 32657, IPv4 :   192.  168.  200.   10.
|    -> Port RTCP RR = 32657, IPv4 :   192.  168.  200.   10.
|    -> Port Fax     = 32659, IPv4 :   192.  168.  200.   10.
| (515634:000017) Concatenated-Physical-Event :
| tei: 0  >>>>  message received : RELEASE [4d]   Call ref :  00 0d
| (515634:000018) 1052: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0  <<<<  message sent : REL COMP [5a]  Call ref :  80 0d
| (515634:000019) Concatenated-Physical-Event :
| tei: 0  >>>>  message received : REL COMP [5a]  Call ref :  00 0d
also on digital extension on oxe:
| (521517:000002) 1052: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 78  desti: 0  source: 15  cryst: 7  cpl: 0  us: 8  term: 0  type a5
| tei: 0  <<<<  message sent : CONNECT (07)  Call ref :  80 0f
| IE:[28] DISPLAY (l=13)  `Reception Desk`
| IE:[06] EI_IP_PAYLOADS (l=2) : (COMP/ECE/VAD)   -> G711a/1/0  G723/1/0
|    -> Port RTP     = 32712, IPv4 :   192.  168.  200.    2.
|    -> Port RTCP SR = 32713, IPv4 :   192.  168.  200.    2.
|    -> Port RTCP RR = 32713, IPv4 :   192.  168.  200.    2.
|    -> Port Fax     = 32715, IPv4 :   192.  168.  200.    2.
| IE:[4c] CONNECTED_NUMBER (l=5)  ->  00  81  Num : 300
| (521517:000004) 1052: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0  <<<<  message sent : FACILITY [62]  Call ref :  80 0f
| (521518:000006) Concatenated-Physical-Event :
| long: 18  desti: 0  source: 0  cryst: 7  cpl: 0  us: 0  term: 0  type a5
| tei: 0  >>>>  message received : CONNECT ACK (0f)  Call ref :  00 0f
| (521533:000007) Concatenated-Physical-Event :
| long: 51  desti: 0  source: 0  cryst: 7  cpl: 0  us: 0  term: 0  type a5
| tei: 0  >>>>  message received : FACILITY [62]  Call ref :  00 0f
|    -> stop_packet=0 stop_rtp=0 h323=1 wc=0 rf=1 udp=0 rqm=0
|    -> Port RTP     = 12678, IPv4 :   194.  152.   46.  182.
|    -> Port RTCP SR = 12679, IPv4 :   194.  152.   46.  182.
|    -> Port RTCP RR = 12679, IPv4 :   194.  152.   46.  182.
| (521533:000008) 1052: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0  <<<<  message sent : DISCONNECT [45]  Call ref :  80 0f
| (521534:000009) Concatenated-Physical-Event :
| tei: 0  >>>>  message received : RELEASE [4d]   Call ref :  00 0f
| (521534:000010) 1052: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0  <<<<  message sent : REL COMP [5a]  Call ref :  80 0f
and how do i read this:
08/10/14 12:01:09 001001M|000/00/0/000|=4:6000=Direct RTP flow with H323 IP device IMPOSSIBLE : 1191, 194.152.46.182
08/10/14 12:05:27 001001M|000/00/0/000|=4:6000=Direct RTP flow with H323 IP device IMPOSSIBLE : 1191, 194.152.46.182
08/10/14 12:11:17 001001M|000/00/0/000|=4:6000=Direct RTP flow with H323 IP device IMPOSSIBLE : 1191, 194.152.46.182
Post by cavagnaro » 08 Oct 2014 10:39
Ahh old traces of logs. I have seen that and assumed that ALU were too lazy to make new messages and used old ones...that saved me a lot of time. As sais, no RTP, is the important part.
Return to “H323 / Sip”
