H323 Trunking Alcatel OXE to Avaya IP Office
A H323 and SIP forum only !
rajansuruli15
Post by rajansuruli15 »
Hi everyone,
i am configuring H323 trunking between Alcatel OXE(common HW) to Avaya IP office.
1.Created TG with ISDN All countries, T2 specification as "IP"
2.Mapped to the GD3 card in TG third lvl.
3.created a prefix as professional TG siezer.
4.configured the avaya PBX number in direact speed dialing. Inside the call number is prefix+the avaya Pbx number and mentioned the avaya PBX IP also.
But i am getting below error. when i dial avaya PBX number.
(1)nic_pbx>
(1)nic_pbx> t3
--> Cleaning mtracer...
| 0 | ** | ** | * | ** | * | *** | 165 |
| 1 | ** | ** | * | ** | * | *** | 166 |
| 2 | ** | ** | * | ** | * | *** | 167 |
| 3 | | | | | | | |
| 4 | | | | | | | |
| 5 | | | | | | | |
| 6 | | | | | | | |
| 7 | | | | | | | |
Traces Analyser activated
mtracer started ...
(090849:000001) MTRACER host (192.168.15.1, nic_pbx), version: R9.1-i1.605-25-b-
ke-c82
(090849:000001) MTRACER num: 013, time: 2016/03/10 13:31:06, loss: 0%
| (090872:000002) 1299: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 70 desti: 0 source: 15 cryst: 2 cpl: 0 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 00 45
| [9f] Non-locking shift. codeset : 7
| [a2] EI_IP_TYPE_TERM
| IE:[05] EI_IP_INFOS (l=9) -> G723 Ece 1 Vad 0 Profil 2, IPv4 :10.13.16.30.
| IE:[06] EI_IP_PAYLOADS (l=1) -> G729 Ece 1 Vad 0
| IE:[07] EI_IP_QOS (l=3) b8 a0 00
| IE:[0a] EI_RTP_INFO (l=2)
| -> stop_packet=0 stop_rtp=0 h323=0 wc=0 rf=0 udp=1 rqm=0
| -> Transm_Bande=1 detection_Q23=1 dtmf_payload=96
| IE:[6c] CALLING_NUMBER (l=5) -> 01 81 Num : 253
| IE:[70] CALLED_NUMBER (l=4) -> 81 Num : 138
| IE:[7d] HLC (l=2) 91 81
| [a1] Sending complete
| (090873:000004) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 2 cpl: 0 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CALL PROC (02) Call ref : 80 45
| IE:[18] CHANNEL (l=2) a9 83 -> T2 : B channel
| (090873:000005) 1299: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 26 desti: 0 source: 15 cryst: 2 cpl: 0 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : STATUS [7d] Call ref : 00 45
| IE:[08] CAUSE (l=3) 81 e4 18 -> [e4] INVALID INFORMATION ELEMENT CONTENTS
| IE:[14] CALL_STATE (l=1) 01
| (090873:000006) Concatenated-Physical-Event :
| long: 24 desti: 0 source: 0 cryst: 2 cpl: 0 us: 0 term: 0 type a5
| tei: 0 >>>> message received : DISCONNECT [45] Call ref : 80 45
| IE:[08] CAUSE (l=4) 01 80 e5 7d -> [e5] MESSAGE NOT COMPATIBLE WITH CALL STATE
| (090873:000007) 1299: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 2 cpl: 0 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : RELEASE [4d] Call ref : 00 45
| IE:[08] CAUSE (l=2) 81 90 -> [90] NORMAL CALL CLEARING
| (090874:000008) Concatenated-Physical-Event :
| long: 23 desti: 0 source: 0 cryst: 2 cpl: 0 us: 0 term: 0 type a5
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 80 45
| IE:[08] CAUSE (l=3) 01 80 80 -> [80] UNKNOWN
(1)nic_pbx>
I ignored the ISDN msg setting in mgr/system also. But still not working.
Anyone give some suggestion to help me to close the issue.
Rajan K.S
sadim
Re: H323 Trunking Alcatel OXE to Avaya IP Office
Post by sadim »
On the IP trunk, is B Channel Choice set to True?
rajansuruli15
Hi sadim,
Thanks for the replay.
currently i configured "B" channel choice is "false". if i set B channel "True", getting Busy tone and in Trace showing "no B channel".
Rajan K.S
sadim
Post by sadim »
B channel choice must be set to true on a h323 cnx
Attach a trace with this configuration
Enviado do meu ALE-L21 através de Tapatalk
Strange message from Avaya B channel but without indication witch B channel.
sadim
Post by sadim »
Hello Vad,
My best guess is that this is due the missing of the channel (IE:[18] CHANNEL (l=3) a8 83 81 -> T2 : No B channel) in the setup msg that was sent by OXE.
Also, RTP and RTPC ports are missing on Setup, but once again, i believe that is due the fact that he has B Channel Choice at False,
He must provide a new trace with B Channel Choice at True.
Best Regards
rajansuruli15
Hello saidm & vlad,
Please fidn the below traces, when i configure "B channel Choice is True".
(1)nic_pbx> t3
| 3 | | | | | | | |
| 4 | | | | | | | |
| 5 | | | | | | | |
| 6 | | | | | | | |
| 7 | | | | | | | |
mtracer started ...
(369489:000001) MTRACER host (192.168.15.1, nic_pbx), version: R9.1-i1.605-25-b-
ke-c82
(369489:000001) MTRACER num: 017, time: 2016/03/15 12:22:19, loss: 0%
| (369516:000002) 1298: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 103 desti: 0 source: 15 cryst: 2 cpl: 0 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 00 61
| IE:[0a] EI_RTP_INFO (l=30)
| -> Port RTP = 32514, IPv4 : 192. 168. 1. 221.
| -> Port RTCP SR = 32515, IPv4 : 192. 168. 1. 221.
| -> Port RTCP RR = 32515, IPv4 : 192. 168. 1. 221.
| -> Port Fax = 0, IPv4 : 0. 0. 0. 0.
| (369517:000004) Concatenated-Physical-Event :
| long: 21 desti: 0 source: 0 cryst: 2 cpl: 0 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CALL PROC (02) Call ref : 80 61
| IE:[18] CHANNEL (l=1) a8 -> T2 : No B channel
| (369576:000005) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 80 61
| IE:[08] CAUSE (l=2) 81 83 -> [83] NO ROUTE TO DESTINATION
| (369576:000006) 1298: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 00 61
I am getting busy tone, when i dial the Avaya PBX extension number.
Sorry ..had little delay on uploading this trace..
please share your suggestions ...
Thanks & Regards,
Rajan K.S
sadim
Post by sadim »
Time to check in Avaya system, the reason of No Route to Destination.
138 is a Avaya internal Set, G729/G723 are ok for Avaya ?
rajansuruli15
hi,
Sorry for the delay replay. Avaya guy is saying that he added all the codecs available in the system.
And in our trace, its showing that "no B channel" is that normal...?
138 is a Avaya internal Set? As sadim asks, seems maybe to be a remote set over other network. Ask Avaya guys for their logs.
Return to “H323 / Sip”
