sip integration between two hotels
A H323 and SIP forum only !
HUSSAINQCS
Post by HUSSAINQCS » 13 Apr 2017 12:21
Can anybody share the feedback for the integration between two hotels through SIP
Scenario:
Hotel A(oxe)------doing installation at hotel
Hotel B(AVAYA)----- already running hotel
Operator Avaya console will be used for Both hotel PRI calls and for all internal and external calls
My concern is how the voice mail will work in this scenario ?
Also checked in Guest name & Room No have to display while oxe room user call to avaya console. so the operator have to find the call is coming from Hotel A
Whether all these features will work without any problem.
What are the suggestions??
Re: sip integration between two hotels
Post by cavagnaro » 13 Apr 2017 13:04
Where is the VM? Guess each pbx will handle its own unless using an external sip solution...
About identification you need to see both Avaya and Alcatel integration options. Need to run some tests there
tgn
Post by tgn » 13 Apr 2017 13:41
better to plan a sbc between the two systems (avaya/oxe) to handle/translate the sip protocol specialities.
regards...
HUSSAINQCS
Post by HUSSAINQCS » 14 Apr 2017 15:18
Can you tell what are the things are not working in SIP scenario between two multi vendor pabc
Post by cavagnaro » 15 Apr 2017 13:08
? Depends on each vendor... That is why they launch their integration guides, if there isn't none means no tests have been done yet and your experience will be a full test
Return to “H323 / Sip”
