Name not display
A H323 and SIP forum only !
Re: Name not display
and your avaya is SEPLOS OR SIPDEV
mdhussainvlr
Post by mdhussainvlr »
SEPLOS
mdhussainvlr
I configured as SIP extension
mdhussainvlr
Call from AVAYA set to AVAVYA set
INVITE sip:3550@192.168.30.254 SIP/2.0
From: <sip:3542@192.168.30.254>;tag=386d89b3-194ee82f6o3h5v3a2d2t615145126m3k5n3l334e4c56_F3542192.168.30.246
To: <sip:3550@192.168.30.254>
Call-ID: 9_386d89b36a3a138313o1z1p443n6o4i643r4c6f60562g2g419_I3542192.168.30.246
CSeq: 9 INVITE
Max-Forwards: 70
From first invite message from OXE it’s not sending the name in traces
Any idea ?
The one who sends the invite is the set, not OXE. So ask Avaya guys how.to change that in the Avaya set.
OXE is just the gateway
mdhussainvlr
If that is the case then I can able to see the name while making outgoing calls from SIP extension also when you receive an incoming call from Noe or SIP phone and further you put the Call on hold after resume back you can see the name ?
Sir, you have the extensions and logs, we don't have magic balls available to see your environment.
As said you are testing non validated sets so it's up to you to test and validate.
If you want help you need to post logs
mdhussainvlr
mdhussainvlr
Ok I will share the logs
mdhussainvlr
The role of the CPU is MAIN
Application software identity
R12.0-m1.403-22-a-ae-c0s1
Business identification: R12.0
Release:
DELIVERY m1.403
Patch identification: 22
Dynamic patch identification: a
Country: ae
Cpu: c0s1
ACD VERSION
release : 11
bug_fixing : 3
protocol_id : 92
version_dy_hr_stat : 12
-> Wrong CPU-Id
* 26 remaining day(s) to fix this issue *
(1)qcs>
(1)qcs>
(1)qcs>
(1)qcs>
(1)qcs> motortrace 3
motortrace (v6.0.0) verbosity = e037b524
sipmotor trace-level set 3 (All traces).
motortrace (v6.0.0) verbosity = e037b524 after
(1)qcs> traced
** UNIX-trace-daemon started ... (static user group No 1) **
traced started ...
1537987927 -> Wed Sep 26 22:52:04 2018 Degraded mode activated : No
Wed Sep 26 22:52:04 2018 -------------------------------------------
1537987946 -> Wed Sep 26 22:52:26 2018 [ipc_thread] Normal case : evt 10752
Wed Sep 26 22:52:26 2018 [ipc_thread] IPC Thread : Ipc reception 7298.
Wed Sep 26 22:52:26 2018 [ipc_thread] IPC Thread : TCL thread signaled.
Wed Sep 26 22:52:26 2018 [exec_ipc] in 7290.
Wed Sep 26 22:52:26 2018 [display_ipc_in] ------------ Begin ---------------
Wed Sep 26 22:52:26 2018 neqt : 1646 Id : 1
Wed Sep 26 22:52:26 2018 INVITE
Wed Sep 26 22:52:26 2018 REQUEST URI : <> 3505@test:5060 ; user=phone
Wed Sep 26 22:52:26 2018 FROM : <Abdullah> 3502@192.168.30.254:5060 ; user=phone
Wed Sep 26 22:52:26 2018 TO : <3505> 3505@192.168.30.254:5060 ; user=phone
Wed Sep 26 22:52:26 2018 CAC : 0
Wed Sep 26 22:52:26 2018 neqt CAC : -1
Wed Sep 26 22:52:26 2018 CAC-CSBU info : UNKNOWN
Wed Sep 26 22:52:26 2018 CLIR : 0
Wed Sep 26 22:52:26 2018 SDP :
Wed Sep 26 22:52:26 2018 ADDRESS : 192.168.30.29 :32514
Wed Sep 26 22:52:26 2018 ALGOS :
Wed Sep 26 22:52:26 2018 PCMA
Wed Sep 26 22:52:26 2018 101
Wed Sep 26 22:52:26 2018 DIRECTION : SEND & RECEIVE
Wed Sep 26 22:52:26 2018 video index : 0
Wed Sep 26 22:52:26 2018 crypto index : 0
Wed Sep 26 22:52:26 2018 N_GW_EXT : 1000
Wed Sep 26 22:52:26 2018 [display_ipc_in] ------------- End ----------------
Wed Sep 26 22:52:26 2018 [CMotorCallManager::onIncomingEvent] an event 10752 arrived on the eqt 1646 1.
Wed Sep 26 22:52:26 2018 [CMotorCallManager::onIncomingEvent] New Call created.
Wed Sep 26 22:52:26 2018 [CMotorCallManager::callFactory].
Wed Sep 26 22:52:26 2018 116d [CCall::CCall] resources number: 1
1537987946 -> Wed Sep 26 22:52:26 2018 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R12.0 m1.403.2
2.a
Wed Sep 26 22:52:26 2018 [CMotorCallManager::callFactory]=851cb40.
Wed Sep 26 22:52:26 2018 [CMotorCallManager::insertCallwithEqt] CMotorCall 1646 inserted.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::inviteBuildAurlRFCWithBelongingDomain]-->extGw=-1
Wed Sep 26 22:52:26 2018 116e[CMotorCall::sipUriType] sip Uri.
Wed Sep 26 22:52:26 2018 [quoteString] => "Abdullah"
Wed Sep 26 22:52:26 2018 116e[CMotorCall::inviteBuildFromAssertedId] no P_Asserted_Identity
Wed Sep 26 22:52:26 2018 [quoteString] => "3505"
Wed Sep 26 22:52:26 2018 116e[CMotorCall::setFilterUsedMode] To be traced = 0
Wed Sep 26 22:52:26 2018 [CMotorCallManager::onIncomingEvent] seplos station.
Wed Sep 26 22:52:26 2018 [CMotorCallManager::onIncomingEvent] state = INITIAL_STATE.
Wed Sep 26 22:52:26 2018 [onIncomingEvent] INVITE arrived.
Wed Sep 26 22:52:26 2018 [receiveInviteEvent] Call: eqt: 1646 INITIAL_STATE received an event.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::emitInviteMessage] begin. size=652 call_type: 1
Wed Sep 26 22:52:26 2018 116e[CMotorCall::getUserType] extGw=1000.
Wed Sep 26 22:52:26 2018 [isUserInDico] found in the dictionnary.
Wed Sep 26 22:52:26 2018 [isAddrInDico] seplos station OK
Wed Sep 26 22:52:26 2018 [getNeqtSeplosStation] stat=13 digit=4 app=0 com=0 data=1 term=159.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::getUserType] Request URI is seplos station crypto=0.
1537987946 -> Wed Sep 26 22:52:26 2018 116e[CMotorCall::getUserType] extGw=1000.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::emitInviteMessage] m_crypted FALSE
Wed Sep 26 22:52:26 2018 116e[CMotorCall::inviteBuildAurlRFCWithBelongingDomain]-->extGw=1000
Wed Sep 26 22:52:26 2018 116e[CMotorCall::emitInviteMessage] From: "Abdullah" <sip:3502@192.168.30.254;user=phone>
Wed Sep 26 22:52:26 2018 116e[CMotorCall::emitInviteMessage] reqUri :sip:3505@test;user=phone
Wed Sep 26 22:52:26 2018 116e[CMotorCall::emitInviteMessage]-->SIP_INFO_allowed=1 allow_update=1
Wed Sep 26 22:52:26 2018 116e[CMotorCall::emitInviteMessage] To: "3505" <sip:3505@192.168.30.254;user=phone>
Wed Sep 26 22:52:26 2018 am_I_PCS SCSWorking : NO
Wed Sep 26 22:52:26 2018 check_PCSstate
Wed Sep 26 22:52:26 2018 check_PCSstate stat of PCS is : -1
Wed Sep 26 22:52:26 2018 116e[CMotorCall::inviteBuildContact] trunk_number=30 extGw =1000.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::inviteBuildContact] userinfo : 3502
Wed Sep 26 22:52:26 2018 116e[CMotorCall::buildContactInvite] Contact: sip:3502@192.168.30.254
1537987946 -> Wed Sep 26 22:52:26 2018 116e[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh RE
INVITE
Wed Sep 26 22:52:26 2018 116e[CMotorCall::inviteBuildSessionTimer] uacGatewayMode=1 uacRefresher=1.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::makeRequestSdpAudio] Begin sdp.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::appendAudioAttributToMedia] Direction: 0.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::appendAudioAttributToMedia] format 101
Wed Sep 26 22:52:26 2018 116e[CMotorCall::setAudioMediaToSdp] crypto index3=0 clearMediaLine=0.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::setAudioMediaToSdp] 1 appendMediaDescription ok.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::setAudioMediaToSdp] Connection address: 192.168.30.29.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::makeRequestSdpAudio] audio end.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::emitInviteMessage] The sdp build.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::new_determineTargetsForTheRequest] is Responsible For This URI.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::new_determineTargets] pcszNameToFind_1=3505.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::makeInitialMotorRequest] nb contacts=1.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::makeInitialMotorRequest] *pcszNameToFind : 3505
Wed Sep 26 22:52:26 2018 [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::makeInitialMotorRequest] contact : sip:3505@192.168.30.246:46239;transport=tcp
;avaya-sc-enabled
1537987946 -> Wed Sep 26 22:52:26 2018 116e[CMotorCall::makeInitialMotorRequest] nb available licenses=2 .
Wed Sep 26 22:52:26 2018 116e[CMotorCall::makeInitialMotorRequest] req_Uri_OK=0 and pSipAddSpec->getHost()=192.168.30.24
6
Wed Sep 26 22:52:26 2018 116e[CMotorCall::makeInitialMotorRequest] contact nb=1
Wed Sep 26 22:52:26 2018 [CGWMngData::isMainServer] CPU is MAIN.
Wed Sep 26 22:52:26 2018 [CGWMngData::isMainServer] checkwith PCS = 0
Wed Sep 26 22:52:26 2018 116e[CMotorCall::isTLSProtRequiredForExtGw] =0.
Wed Sep 26 22:52:26 2018 116e [CCall::makeGenericRequest] INVITE
Wed Sep 26 22:52:26 2018 116e [CCall::getDialog] Confirmed Dialog is not found (ID = ;)
Wed Sep 26 22:52:26 2018 116e [CCall::getDialog] Initial Dialog Client not found
Wed Sep 26 22:52:26 2018 158d [CDialog::createRequest]
Wed Sep 26 22:52:26 2018 158d [CDialog::buildServicesForAllRequest]
Wed Sep 26 22:52:26 2018 158d [CDialog::createInviteRequest]
Wed Sep 26 22:52:26 2018 2119 [CTransaction::changeState] STATE CHANGED TO INITIAL
Wed Sep 26 22:52:26 2018 2119 [CTransaction::changeState] notifying the parent dialog
Wed Sep 26 22:52:26 2018 158d [CDialog::onTransactionState(pTrans = 2119, previousState = Terminated, currentState = Ini
tial, reason = None]
Wed Sep 26 22:52:26 2018 16B [CRequest::CRequest] Creation of a request
Wed Sep 26 22:52:26 2018 16B [CMessage::send] sip_sendMessage (192.168.30.246:46239)
Wed Sep 26 22:52:26 2018 SEND MESSAGE TO NETWORK (192.168.30.246:46239 [TCP]) (BUFF LEN = 943)
INVITE sip:3505@192.168.30.246:46239;transport=TCP;avaya-sc-enabled SIP/2.0
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE, INFO
Supported: replaces,timer,path
User-Agent: OmniPCX Enterprise R12.0 m1.403.22.a
Session-Expires: 1800;refresher=uac
Min-SE: 900
Content-Type: application/sdp
From: "Abdullah" <sip:3502@192.168.30.254;user=phone>;tag=7a0a5e4a013dbfa2eca0e1decdcb0620
Contact: <sip:3502@192.168.30.254;transport=TCP>
Call-ID: 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254
CSeq: 1734490965 INVITE
Via: SIP/2.0/TCP 192.168.30.254;branch=z9hG4bKc7028ed3f0b66ba55d603cc0df8c4786
Max-Forwards: 70
Content-Length: 219
v=0
o=OXE 1537987946 1537987946 IN IP4 192.168.30.254
s=abs
c=IN IP4 192.168.30.29
t=0 0
m=audio 32514 RTP/AVP 8 101
a=sendrecv
a=rtpmap:8 PCMA/8000
a=ptime:20
a=maxptime:30
a=rtpmap:101 telephone-event/8000
1537987946 -> Wed Sep 26 22:52:26 2018 TCP Message: Create ByteArray Object
Wed Sep 26 22:52:26 2018 sip_sendToNetwork tcp Port =46239
Wed Sep 26 22:52:26 2018 16B [CMessage::onSendSuccess]
Wed Sep 26 22:52:26 2018 2119 [CTransaction::onSendSuccess] CMessage 16B send Success
Wed Sep 26 22:52:26 2018 158d [CDialog::onSendSuccess]
Wed Sep 26 22:52:26 2018 2119 [CTransInitialState::createRequest] Transaction changes to Calling state
Wed Sep 26 22:52:26 2018 2119 [CTransaction::changeState] STATE CHANGED TO CALLING
Wed Sep 26 22:52:26 2018 158d [CDialog::onTransactionState(pTrans = 2119, previousState = Initial, currentState = Callin
g, reason = Request creation]
Wed Sep 26 22:52:26 2018 2119 [CTransaction::startTimer] Timer B is started (delay = 4000 ms)
Wed Sep 26 22:52:26 2018 158d [CDialog::getTransactionByCSeq] CSeq = 1734490965
Wed Sep 26 22:52:26 2018 158d [CDialog::addTransaction] added transaction 2119 with branch z9hG4bKc7028ed3f0b66ba55d603c
c0df8c4786, with CSeq 1734490965
Wed Sep 26 22:52:26 2018 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Client, UA)
Wed Sep 26 22:52:26 2018 [CSessionTimerContext::updateSupported] Request timer supported
Wed Sep 26 22:52:26 2018 [CSessionTimerContext::updateMinSE] Min-SE updated : 900
Wed Sep 26 22:52:26 2018 [CSessionTimerContext::updateSessionExpires] Refresher updated : i
Wed Sep 26 22:52:26 2018 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
1537987946 -> Wed Sep 26 22:52:26 2018 [CForkedBranch::CForkedBranch] context = 0x851d0f8.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::branchAllocation] pForkedBranch = 0x8520f38 and the branch number is.
Wed Sep 26 22:52:26 2018 116e[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Wed Sep 26 22:52:26 2018 NOE-SIP : StandByCallCreation not sent to twin CS
Wed Sep 26 22:52:26 2018 [onIncomingEvent] CallID must be inserted.
Wed Sep 26 22:52:26 2018 [onIncomingEvent] CallID inserted.
Wed Sep 26 22:52:26 2018 [exec_ipc] in end 7290.
Wed Sep 26 22:52:26 2018 RECEIVE MESSAGE FROM NETWORK (192.168.30.246:46239 [TCP])
SIP/2.0 100 Trying
User-Agent: Avaya one-X Deskphone 7.0.1.4.6 (6)
Content-Length: 0
Wed Sep 26 22:52:26 2018 [CIOCom::receiveResponse] CResponse 19E ref=1
Wed Sep 26 22:52:26 2018 [CDispatcher::processResponseFromManagerIndex] start at index 0
Wed Sep 26 22:52:26 2018 102 [CCallManager::onIncomingResponse]
Wed Sep 26 22:52:26 2018 116e [CCall::receiveResponse] 100
Wed Sep 26 22:52:26 2018 116e [CCall::getDialog] Confirmed Dialog is not found (ID = 7a0a5e4a013dbfa2eca0e1decdcb0620;)
1537987946 -> Wed Sep 26 22:52:26 2018 116e [CCall::getDialog] Returning Initial Dialog Client
Wed Sep 26 22:52:26 2018 158d [CDialog::receiveResponse]
Wed Sep 26 22:52:26 2018 2119 [CTransCallingState::receiveResponse] Provisional : Transaction changes to Proceeding stat
e
Wed Sep 26 22:52:26 2018 2119 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
Wed Sep 26 22:52:26 2018 158d [CDialog::onTransactionState(pTrans = 2119, previousState = Calling, currentState = Procee
ding, reason = 1xx response reception]
Wed Sep 26 22:52:26 2018 2119 [CTransaction::freeTimerToken] Timer B is freed
Wed Sep 26 22:52:26 2018 116e[CMotorCall::searchForkedBranch]pForkedBranch=0x8520f38.
Wed Sep 26 22:52:26 2018 [receiveInformationalMessage] Call: 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 eqt: 1646 P
ROCEEDING_STATE received a message.
Wed Sep 26 22:52:26 2018 [receiveInformationalMessage] setting COLP to true in preferred
Wed Sep 26 22:52:26 2018 [receiveInformationalMessage] 0 AlertInfo header(s) found
Wed Sep 26 22:52:26 2018 [CPoceedingState::receiveInformationalMessage]-->nof of PEM hdrs 0
Wed Sep 26 22:52:26 2018 [receiveInformationalMessage] No P-Early-Media header received
Wed Sep 26 22:52:26 2018 [receiveInformationalMessage] is in the else part of SDP not present
SIP/2.0 180 Ringing
To: <sip:3505@192.168.30.254;user=phone>;tag=386dc5fd-3e1c97943r71215n4r5v5ax61r1841o312q1m536j_T3505192.168.30.246
Allow: INVITE,ACK,BYE,CANCEL,SUBSCRIBE,NOTIFY,MESSAGE,REFER,INFO,PRACK,PUBLISH,UPDATE
Contact: <sip:3505@192.168.30.246:46239;transport=tcp>
Accept-Language: en
Content-Length: 0
1537987946 -> Wed Sep 26 22:52:26 2018 [CIOCom::receiveResponse] CResponse 19F ref=1
Wed Sep 26 22:52:26 2018 116e [CCall::receiveResponse] 180
Wed Sep 26 22:52:26 2018 116e [CCall::getDialog] Confirmed Dialog is not found (ID = 7a0a5e4a013dbfa2eca0e1decdcb0620;38
6dc5fd-3e1c97943r71215n4r5v5ax61r1841o312q1m536j_T3505192.168.30.246)
Wed Sep 26 22:52:26 2018 19E [~CResponse] resp(100) 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 1734490965 INVITE
Wed Sep 26 22:52:26 2018 158d [CDialog::updateRouteSet] there are 0 record-route headers
1537987947 -> Wed Sep 26 22:52:26 2018 [methodAllowedByDistant] INFO allowed by distant.
Wed Sep 26 22:52:26 2018 116e[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Wed Sep 26 22:52:26 2018 116e[emitEventToMonitel] CAC = 0 eqtCAC = -1
Wed Sep 26 22:52:26 2018 116e[emitEventToMonitel] cacUsed=0 eqtCac=-1
Wed Sep 26 22:52:26 2018 116e[emitEventToMonitel] displayIPCMessageOut
Wed Sep 26 22:52:26 2018 ** SEPLOS **
Wed Sep 26 22:52:26 2018 [sendLgEvtSip] seplos Event sent on eqt : 1646 Id :1
Wed Sep 26 22:52:26 2018 [display_ipc_out] ------------ Begin ---------------
Wed Sep 26 22:52:26 2018 Id : 1
Wed Sep 26 22:52:26 2018 INFORMATIONAL
Wed Sep 26 22:52:26 2018 xx : 80
Wed Sep 26 22:52:26 2018 RELATIVE REQUEST : INVITE
Wed Sep 26 22:52:26 2018 Allow Update : 0
Wed Sep 26 22:52:26 2018 [display_ipc_out] ------------- End ----------------
1537987950 -> main.trace.timer = 480mn
1537987952 -> Wed Sep 26 22:52:32 2018 RECEIVE MESSAGE FROM NETWORK (192.168.30.246:46239 [TCP])
SIP/2.0 200 OK
Supported: 100rel,eventlist,feature-ref,replaces,tdialog
Accept-Language: en
Content-Length: 249
v=0
o=sip:3505@192.168.30.246 1 25 IN IP4 192.168.30.246
s=sip:3505@192.168.30.246
c=IN IP4 192.168.30.246
b=TIAS:1920000
t=0 0
m=audio 5004 RTP/AVP 8 101
b=TIAS:64000
a=ptime:20
a=rtpmap:8 PCMA/8000/1
a=rtpmap:101 telephone-event/8000/1
Wed Sep 26 22:52:32 2018 [CIOCom::receiveResponse] CResponse 1A0 ref=1
Wed Sep 26 22:52:32 2018 [CDispatcher::processResponseFromManagerIndex] start at index 0
Wed Sep 26 22:52:32 2018 102 [CCallManager::onIncomingResponse]
Wed Sep 26 22:52:32 2018 116e [CCall::receiveResponse] 200
Wed Sep 26 22:52:32 2018 116e [CCall::getDialog] Confirmed Dialog is not found (ID = 7a0a5e4a013dbfa2eca0e1decdcb0620;38
1537987952 -> Wed Sep 26 22:52:32 2018 116e [CCall::getDialog] Returning Initial Dialog Client
Wed Sep 26 22:52:32 2018 158d [CDialog::receiveResponse]
Wed Sep 26 22:52:32 2018 158d [CDialog::receiveResponse] create a CONFIRMED dialog
Wed Sep 26 22:52:32 2018 158e [CDialog::CDialog] look for the transaction #0, transaction key = z9hG4bKc7028ed3f0b66ba55
d603cc0df8c4786
Wed Sep 26 22:52:32 2018 158e [CDialog::CDialog] copy the transaction #0, transaction key = z9hG4bKc7028ed3f0b66ba55d603
cc0df8c4786
Wed Sep 26 22:52:32 2018 211a [CTransaction::CTransaction] Transaction is cloned in 4 state
Wed Sep 26 22:52:32 2018 158e [CDialog::addTransaction] added transaction 211a with branch z9hG4bKc7028ed3f0b66ba55d603c
Wed Sep 26 22:52:32 2018 158e [CDialog::startDialogTTL]
Wed Sep 26 22:52:32 2018 158e [CDialog::receiveResponse]
Wed Sep 26 22:52:32 2018 211a [CTransProceedingState::receiveResponse] Final : Transaction changes to Completed state
Wed Sep 26 22:52:32 2018 211a [CTransaction::changeState] STATE CHANGED TO COMPLETED
Wed Sep 26 22:52:32 2018 211a [CTransaction::changeState] notifying the parent dialog
Wed Sep 26 22:52:32 2018 158e [CDialog::onTransactionState(pTrans = 211a, previousState = Proceeding, currentState = Com
pleted, reason = Final resp reception]
Wed Sep 26 22:52:32 2018 211a [CTransCompletedState::enterInState] Final(!UDP) : INVITE Client Transaction changes to Te
rminated state
Wed Sep 26 22:52:32 2018 211a [CTransaction::changeState] STATE CHANGED TO TERMINATED
1537987952 -> Wed Sep 26 22:52:32 2018 211a [CTransaction::changeState] no transaction state, terminated reason : Timer
D fires
Wed Sep 26 22:52:32 2018 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from response (Client, UA
Wed Sep 26 22:52:32 2018 [CSessionTimerContext::updateSupported] Request timer supported
Wed Sep 26 22:52:32 2018 [CSessionTimerContext::updateMinSE] Min-SE updated : 900
Wed Sep 26 22:52:32 2018 [CSessionTimerContext::updateSessionExpires] Refresher updated : i
Wed Sep 26 22:52:32 2018 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
Wed Sep 26 22:52:32 2018 [CSessionTimerContext::startTimers] Start session timer expiration : 1800000
Wed Sep 26 22:52:32 2018 [CSessionTimerContext::startTimers] Start session timer will expires : 900000
Wed Sep 26 22:52:32 2018 [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
Wed Sep 26 22:52:32 2018 158e [CDialog::updateRouteSet] there are 0 record-route headers
Wed Sep 26 22:52:32 2018 116e [CCall::insertInDialogMap] added dialog #158e with the key 7a0a5e4a013dbfa2eca0e1decdcb062
0;386dc5fd-3e1c97943r71215n4r5v5ax61r1841o312q1m536j_T3505192.168.30.246
Wed Sep 26 22:52:32 2018 158d [CDialog::getTransactionByCSeq] CSeq = 1734490966
Wed Sep 26 22:52:32 2018 158d [CDialog::updateRouteSet] there are 0 record-route headers
Wed Sep 26 22:52:32 2018 116e[CMotorCall::searchForkedBranch]pForkedBranch=0x8520f38.
1537987952 -> Wed Sep 26 22:52:32 2018 [CForkedBranch::setFinalResponse] response=200.
Wed Sep 26 22:52:32 2018 116e[CMotorCall::responseToInviteOrCancel] call chooseBestResponse.
Wed Sep 26 22:52:32 2018 116e[CMotorCall::chooseBestResponse] pForkedBranch=0x8520f38 iResponseCode=2000.
Wed Sep 26 22:52:32 2018 116e[CMotorCall::chooseBestResponse] last iResponseCode=200.
Wed Sep 26 22:52:32 2018 [CForkedBranch::setFinalResponse] pResponse=0x851d3c8.
Wed Sep 26 22:52:32 2018 116e[CMotorCall::chooseBestResponse] next branch.
Wed Sep 26 22:52:32 2018 116e[CMotorCall::responseToInviteOrCancel] inviteResponse => update the lastInviteContext.
Wed Sep 26 22:52:32 2018 116e[CMotorCall::updateTransportfromlastInviteContext] lasInviteContext Start
Wed Sep 26 22:52:32 2018 116e[CMotorCall::updateTransportfromlastInviteContext] lasInviteContext updated with TCP
Wed Sep 26 22:52:32 2018 [receiveSuccessfulMessage] Call: 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 eqt: 1646 PROC
Wed Sep 26 22:52:32 2018 116e[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Wed Sep 26 22:52:32 2018 116e[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=1 uacRefresher=1.
Wed Sep 26 22:52:32 2018 [decodeACACALU] no header.
Wed Sep 26 22:52:32 2018 [receiveSuccessfulMessage] setting COLP to true in preferred
Wed Sep 26 22:52:32 2018 [checkSdpValidity] Sdp contains 1 media description(s).
Wed Sep 26 22:52:32 2018 [checkSdpValidity] without video control.
1537987952 -> Wed Sep 26 22:52:32 2018 [checkSdpValidity] Media 0 type 1 contains 2 formats.
Wed Sep 26 22:52:32 2018 [checkSdpValidity] media audio.
Wed Sep 26 22:52:32 2018 [checkSdpValidity] Format : 8.
Wed Sep 26 22:52:32 2018 [checkSdpValidity] return false.
Wed Sep 26 22:52:32 2018 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Wed Sep 26 22:52:32 2018 [convertSdpIntoTsdp] No Direction in the session part.
Wed Sep 26 22:52:32 2018 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
Wed Sep 26 22:52:32 2018 [convertSdpIntoTsdp] new media analyzed=0 sdp_index=0 count=1.
Wed Sep 26 22:52:32 2018 [audioMediaSentToCH] media AUDIO detected (previous crypto=0).
Wed Sep 26 22:52:32 2018 [convertCryptoInfoInFile] clearMediaLine2: 0.
Wed Sep 26 22:52:32 2018 [convertAudioMedia] The audio media contains 2 format(s).
Wed Sep 26 22:52:32 2018 [convertAudioMedia] Format 0 is 8 opt syst G711=0.
Wed Sep 26 22:52:32 2018 [convertAudioMedia] Format is PCMA.
Wed Sep 26 22:52:32 2018 [convertAudioMedia] Format 1 is 101 opt syst G711=0.
Wed Sep 26 22:52:32 2018 [convertAudioMedia] 101.
Wed Sep 26 22:52:32 2018 [convertAudioMedia] Format is DTMF:101.
Wed Sep 26 22:52:32 2018 [convertAudioMedia] invalid Direction in this media part.
Wed Sep 26 22:52:32 2018 [convertAudioMedia] Connection address retrieved in sdp: 192.168.30.246.
Wed Sep 26 22:52:32 2018 [convertIPStrIntoTuipv] 192.168.30.246 => 192.168.30.246
Wed Sep 26 22:52:32 2018 [audioMediaSentToCH] sdp index=0.
Wed Sep 26 22:52:32 2018 [display_sdp] address =192.168.30.246
1537987952 -> Wed Sep 26 22:52:32 2018 [display_sdp] codecs =0.
Wed Sep 26 22:52:32 2018 [display_sdp] codecs =101.
Wed Sep 26 22:52:32 2018 [display_sdp] direction=0.
Wed Sep 26 22:52:32 2018 [convertSdpIntoTsdp] ok.
Wed Sep 26 22:52:32 2018 [convertSdpIntoTsdp] 5-crypto_info=0xbffff2bc crypto_index=0 clear media=1
Wed Sep 26 22:52:32 2018 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
Wed Sep 26 22:52:32 2018 [convertSdpIntoTsdp] 3-crypto_info=0xbffff2bc crypto_index=0 clear media=1
Wed Sep 26 22:52:32 2018 [methodAllowedByDistant] INFO allowed by distant.
Wed Sep 26 22:52:32 2018 116e[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Wed Sep 26 22:52:32 2018 116e[emitEventToMonitel] CAC = 0 eqtCAC = -1
Wed Sep 26 22:52:32 2018 116e[emitEventToMonitel] cacUsed=0 eqtCac=-1
Wed Sep 26 22:52:32 2018 116e[emitEventToMonitel] displayIPCMessageOut
Wed Sep 26 22:52:32 2018 ** SEPLOS **
Wed Sep 26 22:52:32 2018 [sendLgEvtSip] seplos Event sent on eqt : 1646 Id :1
Wed Sep 26 22:52:32 2018 [display_ipc_out] ------------ Begin ---------------
Wed Sep 26 22:52:32 2018 Id : 1
Wed Sep 26 22:52:32 2018 SUCCESSFUL
Wed Sep 26 22:52:32 2018 xx : 0
Wed Sep 26 22:52:32 2018 RELATIVE REQUEST : INVITE
Wed Sep 26 22:52:32 2018 CAC-CSBU info : UNKNOWN
Wed Sep 26 22:52:32 2018 CLIR : 0
Wed Sep 26 22:52:32 2018 COLP : 0
Wed Sep 26 22:52:32 2018 SDP :
Wed Sep 26 22:52:32 2018 ADDRESS : 192.168.30.246 :5004
Wed Sep 26 22:52:32 2018 ALGOS :
Wed Sep 26 22:52:32 2018 PCMA
1537987952 -> Wed Sep 26 22:52:32 2018 101
Wed Sep 26 22:52:32 2018 DIRECTION : SEND & RECEIVE
Wed Sep 26 22:52:32 2018 video index : 0
Wed Sep 26 22:52:32 2018 crypto index : 0
Wed Sep 26 22:52:32 2018 [display_ipc_out] ------------- End ----------------
Wed Sep 26 22:52:32 2018 [ipc_thread] Normal case : evt 10754
Wed Sep 26 22:52:32 2018 [ipc_thread] IPC Thread : Ipc reception 7298.
Wed Sep 26 22:52:32 2018 [ipc_thread] IPC Thread : TCL thread signaled.
Wed Sep 26 22:52:32 2018 116e[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Wed Sep 26 22:52:32 2018 116e[CMotorCall::onReceiveResponse] retrans=0, status=200 extGw=1000.
Wed Sep 26 22:52:32 2018 116e[CMotorCall::onReceiveResponse] INVITE case => cancelAllCancelableForkedBranch.
Wed Sep 26 22:52:32 2018 116e[CMotorCall::cancelAllCancelableForkedBranch] nb branch=1.
Wed Sep 26 22:52:32 2018 116e[CMotorCall::cancelAllCancelableForkedBranch] retrans=0.
Wed Sep 26 22:52:32 2018 [exec_ipc] in 7290.
Wed Sep 26 22:52:32 2018 [display_ipc_in] ------------ Begin ---------------
Wed Sep 26 22:52:32 2018 neqt : 1646 Id : 1
Wed Sep 26 22:52:32 2018 ACK
Wed Sep 26 22:52:32 2018 [display_ipc_in] ------------- End ----------------
Wed Sep 26 22:52:32 2018 [CMotorCallManager::onIncomingEvent] an event 10754 arrived on the eqt 1646 1.
Wed Sep 26 22:52:32 2018 [CMotorCallManager::onIncomingEvent] seplos station.
Wed Sep 26 22:52:32 2018 [CMotorCallManager::onIncomingEvent] state = ACCEPTED_STATE.
Wed Sep 26 22:52:32 2018 [onIncomingEvent] ACK arrived.
1537987952 -> Wed Sep 26 22:52:32 2018 [receiveAckEvent] Call: 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 eqt: 1646
ACCEPTED_STATE received an event.
Wed Sep 26 22:52:32 2018 116e[CMotorCall::emitAckMessage]
Wed Sep 26 22:52:32 2018 116e[CMotorCall::emitAckMessage] SDP ok.
Wed Sep 26 22:52:32 2018 116e [CCall::makeGenericRequest] ACK
Wed Sep 26 22:52:32 2018 116e [CCall::getDialog] Confirmed Dialog found
Wed Sep 26 22:52:32 2018 158e [CDialog::createRequest]
Wed Sep 26 22:52:32 2018 158e [CDialog::buildServicesForAllRequest]
Wed Sep 26 22:52:32 2018 158e [CDialog::createAckRequest]
Wed Sep 26 22:52:32 2018 158e [CDialog::createAckRequest], previous trans 211a is found
Wed Sep 26 22:52:32 2018 158e [CDialog::createAckRequest], previous trans 211a is client
Wed Sep 26 22:52:32 2018 16C [CRequest::CRequest] Creation of a request
Wed Sep 26 22:52:32 2018 158e [CDialog::buildServicesForAck]
Wed Sep 26 22:52:32 2018 Protocol taken from reqUriProtocol TCP
Wed Sep 26 22:52:32 2018 16C [CMessage::send] sip_sendMessage (192.168.30.246:46239)
Wed Sep 26 22:52:32 2018 SEND MESSAGE TO NETWORK (192.168.30.246:46239 [TCP]) (BUFF LEN = 565)
ACK sip:3505@192.168.30.246:46239;transport=tcp SIP/2.0
CSeq: 1734490965 ACK
Via: SIP/2.0/TCP 192.168.30.254;branch=z9hG4bKc254d8330068de3faf7cf8e3b529b6ba
Max-Forwards: 70
Content-Length: 0
1537987955 -> Wed Sep 26 22:52:32 2018 TCP Message: Create ByteArray Object
Wed Sep 26 22:52:32 2018 sip_sendToNetwork tcp Port =46239
Wed Sep 26 22:52:32 2018 16C [CMessage::onSendSuccess]
Wed Sep 26 22:52:32 2018 158e [CDialog::onSendSuccess]
Wed Sep 26 22:52:32 2018 158e [CDialog::createAckRequest] successful INVITE is terminated after the ACK is sent
Wed Sep 26 22:52:32 2018 [receiveAckEvent] continue with session Timer
Wed Sep 26 22:52:32 2018 [exec_ipc] in end 7290.
1537987956 -> Wed Sep 26 22:52:36 2018 RECEIVE MESSAGE FROM NETWORK (192.168.30.246:46239 [TCP])
INVITE sip:3502@192.168.30.254;transport=tcp SIP/2.0
From: "3505" <sip:3505@192.168.30.254>;tag=386dc5fd-3e1c97943r71215n4r5v5ax61r1841o312q1m536j_T3505192.168.30.246
To: "Abdullah" <sip:3502@192.168.30.254>;tag=7a0a5e4a013dbfa2eca0e1decdcb0620
CSeq: 25 INVITE
Max-Forwards: 70
Via: SIP/2.0/TCP 192.168.30.246:46239;branch=z9hG4bK18_386dc606c2dfdbb4f6c1t5j1k5d6u5n31533a3q632l2g6i4x_ReI3505192.168.
30.246
Reason: avaya-action;cause=1;text="Hold"
Content-Length: 399
v=0
o=sip:3505@192.168.30.246 1 26 IN IP4 192.168.30.246
b=TIAS:1920000
t=0 0
m=audio 5004 RTP/AVP 9 0 8 110 18 101
b=TIAS:64000
a=sendonly
a=rtpmap:9 G722/8000/1
a=rtpmap:0 PCMU/8000/1
a=rtpmap:110 G726-32/8000/1
a=rtpmap:18 G729/8000/1
a=fmtp:18 annexb=yes
a=maxptime:60
Wed Sep 26 22:52:36 2018 [CIOCom::receiveRequest] optimisation value 1
Wed Sep 26 22:52:36 2018 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.30.254 test
1537987956 -> Wed Sep 26 22:52:36 2018 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Wed Sep 26 22:52:36 2018 16D [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Wed Sep 26 22:52:36 2018 [CIOCom::receiveRequest] Received CRequest 16D ref=1
Wed Sep 26 22:52:36 2018 [CIOCom::receiveRequest] alias param11 is received
Wed Sep 26 22:52:36 2018 [CDispatcher::onIncomingRequest()]
Wed Sep 26 22:52:36 2018 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Wed Sep 26 22:52:36 2018 102 [CCallManager::onIncomingRequest()]
Wed Sep 26 22:52:36 2018 116e [CCall::receiveRequest] INVITE
Wed Sep 26 22:52:36 2018 116e [CCall::getDialog] Confirmed Dialog found
Wed Sep 26 22:52:36 2018 158e [CDialog::receiveRequest]
Wed Sep 26 22:52:36 2018 158e [CDialog::receiveInviteRequest]
Wed Sep 26 22:52:36 2018 211b [CTransaction::changeState] STATE CHANGED TO INITIAL
Wed Sep 26 22:52:36 2018 211b [CTransaction::changeState] notifying the parent dialog
Wed Sep 26 22:52:36 2018 158e [CDialog::onTransactionState(pTrans = 211b, previousState = Terminated, currentState = Ini
Wed Sep 26 22:52:36 2018 211b [CTransInitialState::receiveRequest] Transaction changes to Proceeding state
Wed Sep 26 22:52:36 2018 211b [CTransaction::changeState] STATE CHANGED TO PROCEEDING
Wed Sep 26 22:52:36 2018 158e [CDialog::onTransactionState(pTrans = 211b, previousState = Initial, currentState = Procee
ding, reason = Request reception]
1537987956 -> Wed Sep 26 22:52:36 2018 211b [CTransProceedingState::createResponse] CResponse 1A1 ref=1
Wed Sep 26 22:52:36 2018 1A1 [CMessage::send] sip_sendMessage (192.168.30.246:46239)
Wed Sep 26 22:52:36 2018 SEND MESSAGE TO NETWORK (192.168.30.246:46239 [TCP]) (BUFF LEN = 438)
SIP/2.0 100 Trying
CSeq: 25 INVITE
30.246
Content-Length: 0
Wed Sep 26 22:52:36 2018 TCP Message: Create ByteArray Object
Wed Sep 26 22:52:36 2018 sip_sendToNetwork tcp Port =46239
Wed Sep 26 22:52:36 2018 1A1 [CMessage::onSendSuccess]
Wed Sep 26 22:52:36 2018 211b [CTransaction::onSendSuccess] CMessage 1A1 send Success
Wed Sep 26 22:52:36 2018 158e [CDialog::onSendSuccess]
Wed Sep 26 22:52:36 2018 158e [CDialog::receiveInviteRequest] a new Server INVITE transaction is in progress
Wed Sep 26 22:52:36 2018 [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh recept
ion)
Wed Sep 26 22:52:36 2018 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
Wed Sep 26 22:52:36 2018 158e [CDialog::addTransaction] added transaction 211b with branch z9hG4bK18_386dc606c2dfdbb4f6c
1t5j1k5d6u5n31533a3q632l2g6i4x_ReI3505192.168.30.246, with CSeq 25
1537987956 -> Wed Sep 26 22:52:36 2018 116e [CCall::receiveRequest] iErrorCode=488.
Wed Sep 26 22:52:36 2018 116e [CCall::checkAuthentication] INVITE
Wed Sep 26 22:52:36 2018 116e[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Wed Sep 26 22:52:36 2018 116e[CMotorCall::controlAuthentication] ---*--- END-02 ---*--- Control authentication
Wed Sep 26 22:52:36 2018 116e [CCall::controlAuthentication] need auth =0
Wed Sep 26 22:52:36 2018 116e [CCall::checkAuthentication] AUTHENT=0
Wed Sep 26 22:52:36 2018 116e [CCall::checkAuthentication] iRetValue=0
Wed Sep 26 22:52:36 2018 116e [CCall::receiveRequest] extGw=-1.
Wed Sep 26 22:52:36 2018 116e [CCall::receiveRequest] External Authentication by WS is in progress ...
Wed Sep 26 22:52:36 2018 116e[CMotorCall::onReceiveRequest] request received.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::onReceiveRequest] s=1 d=0 v=0 o=0.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::onReceiveRequest] request for gateway.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::onReceiveRequest] state = COMPLETED_STATE.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::methodInviteReceived] nb available licenses=2 .
Wed Sep 26 22:52:36 2018 [isUserInDico] found in the dictionnary.
Wed Sep 26 22:52:36 2018 [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::compareDialogFromContext] same Dialog
Wed Sep 26 22:52:36 2018 116e[CMotorCall::methodInviteReceived] Invite => update the inviteContext.
Wed Sep 26 22:52:36 2018 [CForkedBranch::CForkedBranch] context = 0x851d0f8.
1537987956 -> Wed Sep 26 22:52:36 2018 116e[CMotorCall::methodInviteReceived] reqUri stored: sip:3505@192.168.30.246:462
39;transport=tcp
Wed Sep 26 22:52:36 2018 116e[CMotorCall::methodInviteReceived] cacUsed = 0 before.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::methodInviteReceived] returnStat = 0 before.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::methodInviteReceived] cacUsed = 0 after.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::methodInviteReceived] CAC = 0
Wed Sep 26 22:52:36 2018 [receiveInviteMessage] Call: 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 eqt: 1646 COMPLETE
D_STATE received a message.
Wed Sep 26 22:52:36 2018 [receiveInviteMessage] INFO present in Allow header
Wed Sep 26 22:52:36 2018 [receiveInviteMessage] Allow_INFO_received=TRUE
Wed Sep 26 22:52:36 2018 [checkSdpValidity] Sdp contains 1 media description(s).
Wed Sep 26 22:52:36 2018 [checkSdpValidity] without video control.
Wed Sep 26 22:52:36 2018 [checkSdpValidity] Media 0 type 1 contains 6 formats.
Wed Sep 26 22:52:36 2018 [checkSdpValidity] media audio.
Wed Sep 26 22:52:36 2018 [checkSdpValidity] Format : 9.
Wed Sep 26 22:52:36 2018 [checkSdpValidity] Format : 0.
Wed Sep 26 22:52:36 2018 [checkSdpValidity] Format : 8.
Wed Sep 26 22:52:36 2018 [checkSdpValidity] return false.
Wed Sep 26 22:52:36 2018 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Wed Sep 26 22:52:36 2018 [convertSdpIntoTsdp] No Direction in the session part.
Wed Sep 26 22:52:36 2018 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
1537987956 -> Wed Sep 26 22:52:36 2018 [convertSdpIntoTsdp] new media analyzed=0 sdp_index=0 count=1.
Wed Sep 26 22:52:36 2018 [audioMediaSentToCH] media AUDIO detected (previous crypto=0).
Wed Sep 26 22:52:36 2018 [convertCryptoInfoInFile] clearMediaLine2: 0.
Wed Sep 26 22:52:36 2018 [convertAudioMedia] The audio media contains 6 format(s).
Wed Sep 26 22:52:36 2018 [convertAudioMedia] Format 0 is 9 opt syst G711=0.
Wed Sep 26 22:52:36 2018 [convertAudioMedia] Format 1 is 0 opt syst G711=0.
Wed Sep 26 22:52:36 2018 [convertAudioMedia] Format 2 is 8 opt syst G711=0.
Wed Sep 26 22:52:36 2018 [convertAudioMedia] Format is PCMA.
Wed Sep 26 22:52:36 2018 [convertAudioMedia] Format 3 is 110 opt syst G711=0.
Wed Sep 26 22:52:36 2018 [convertAudioMedia] 110.
Wed Sep 26 22:52:36 2018 [convertAudioMedia] Format 4 is 18 opt syst G711=0.
Wed Sep 26 22:52:36 2018 [convertAudioMedia] Format is G729.
Wed Sep 26 22:52:36 2018 [convertAudioMedia] Format 5 is 101 opt syst G711=0.
Wed Sep 26 22:52:36 2018 [convertAudioMedia] 101.
Wed Sep 26 22:52:36 2018 [convertAudioMedia] Format is DTMF:101.
Wed Sep 26 22:52:36 2018 [convertAudioMedia] Direction is sendonly.
Wed Sep 26 22:52:36 2018 [convertAudioMedia] Connection address retrieved in sdp: 192.168.30.246.
Wed Sep 26 22:52:36 2018 [convertIPStrIntoTuipv] 192.168.30.246 => 192.168.30.246
Wed Sep 26 22:52:36 2018 [audioMediaSentToCH] sdp index=0.
Wed Sep 26 22:52:36 2018 [display_sdp] address =192.168.30.246
Wed Sep 26 22:52:36 2018 [display_sdp] codecs =0.
Wed Sep 26 22:52:36 2018 [display_sdp] codecs =17.
1537987956 -> Wed Sep 26 22:52:36 2018 [display_sdp] codecs =101.
Wed Sep 26 22:52:36 2018 [display_sdp] direction=1.
Wed Sep 26 22:52:36 2018 [convertSdpIntoTsdp] ok.
Wed Sep 26 22:52:36 2018 [convertSdpIntoTsdp] 5-crypto_info=0xbfffefec crypto_index=0 clear media=1
Wed Sep 26 22:52:36 2018 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
Wed Sep 26 22:52:36 2018 [convertSdpIntoTsdp] 3-crypto_info=0xbfffefec crypto_index=0 clear media=1
Wed Sep 26 22:52:36 2018 116e[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Wed Sep 26 22:52:36 2018 116e[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=0 uacRefresher=0.
Wed Sep 26 22:52:36 2018 116e[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Wed Sep 26 22:52:36 2018 116e[emitEventToMonitel] CAC = 0 eqtCAC = -1
Wed Sep 26 22:52:36 2018 116e[emitEventToMonitel] cacUsed=0 eqtCac=-1
Wed Sep 26 22:52:36 2018 116e[emitEventToMonitel] displayIPCMessageOut
Wed Sep 26 22:52:36 2018 ** SEPLOS **
Wed Sep 26 22:52:36 2018 [sendLgEvtSip] seplos Event sent on eqt : 1646 Id :1
Wed Sep 26 22:52:36 2018 [display_ipc_out] ------------ Begin ---------------
Wed Sep 26 22:52:36 2018 Id : 1
Wed Sep 26 22:52:36 2018 RE_INVITE
Wed Sep 26 22:52:36 2018 SDP :
Wed Sep 26 22:52:36 2018 ADDRESS : 192.168.30.246 :5004
Wed Sep 26 22:52:36 2018 ALGOS :
Wed Sep 26 22:52:36 2018 PCMA
Wed Sep 26 22:52:36 2018 G729
Wed Sep 26 22:52:36 2018 101
Wed Sep 26 22:52:36 2018 DIRECTION : SEND ONLY
1537987956 -> Wed Sep 26 22:52:36 2018 video index : 0
Wed Sep 26 22:52:36 2018 crypto index : 0
Wed Sep 26 22:52:36 2018 [display_ipc_out] ------------- End ----------------
Wed Sep 26 22:52:36 2018 [ipc_thread] Normal case : evt 10765
Wed Sep 26 22:52:36 2018 [ipc_thread] IPC Thread : Ipc reception 7298.
Wed Sep 26 22:52:36 2018 [ipc_thread] IPC Thread : TCL thread signaled.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Wed Sep 26 22:52:36 2018 [exec_ipc] in 7290.
Wed Sep 26 22:52:36 2018 [display_ipc_in] ------------ Begin ---------------
Wed Sep 26 22:52:36 2018 neqt : 1646 Id : 1
Wed Sep 26 22:52:36 2018 SUCCESSFUL
Wed Sep 26 22:52:36 2018 xx : 0
Wed Sep 26 22:52:36 2018 RELATIVE REQUEST : RE_INVITE
Wed Sep 26 22:52:36 2018 CLIR : 0
Wed Sep 26 22:52:36 2018 COLP : 1
Wed Sep 26 22:52:36 2018 CAC-CSBU info : UNKNOWN
Wed Sep 26 22:52:36 2018 ADDRESS : 192.168.30.29 :32514
Wed Sep 26 22:52:36 2018 DIRECTION : RECEIVE ONLY
Wed Sep 26 22:52:36 2018 [display_ipc_in] ------------- End ----------------
Wed Sep 26 22:52:36 2018 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 1646 1.
Wed Sep 26 22:52:36 2018 [CMotorCallManager::onIncomingEvent] seplos station.
Wed Sep 26 22:52:36 2018 [CMotorCallManager::onIncomingEvent] state = MODIFICATION_PROCEEDING_STATE.
1537987956 -> Wed Sep 26 22:52:36 2018 [onIncomingEvent] SUCCESSFUL arrived.
Wed Sep 26 22:52:36 2018 [onIncomingEvent] relative_request = 10753
Wed Sep 26 22:52:36 2018 [receiveSuccessfulEvent] Call: 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 eqt: 1646 MODIFI
CATION_PROCEEDING_STATE received an event.
Wed Sep 26 22:52:36 2018 [quoteString] => "Abdullah"
Wed Sep 26 22:52:36 2018 116e[CMotorCall::isTLSProtRequiredForExtGw] =0.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::emitSuccessfulMessage] P-Asserted-Identity: "Abdullah" <sip:3502@192.168.30.25
4;user=phone>
Wed Sep 26 22:52:36 2018 0[CMotorCall::emitSuccessfulMessage] isIpDect=-1073745924
Wed Sep 26 22:52:36 2018 116e[CMotorCall::emitSuccessfulMessage] uacGatewayMode=0 uacRefresher=0.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::makeResponseSdpAudioOld] Audio media.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::appendAudioAttributToMedia] Direction: 2.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::appendAudioAttributToMedia] format 101
Wed Sep 26 22:52:36 2018 116e[CMotorCall::makeResponseSdpAudio] fromSdp.getMediaDesciprionCount :1
Wed Sep 26 22:52:36 2018 [sameCodec] accepted Format : 8.
Wed Sep 26 22:52:36 2018 [sameCodec] requested Format : 9.
Wed Sep 26 22:52:36 2018 [sameCodec] requested Format : 0.
Wed Sep 26 22:52:36 2018 [sameCodec] requested Format : 8.
Wed Sep 26 22:52:36 2018 [sameCodec] same Format.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::mediaAccepted] Media accepted: m=audio 32514 RTP/AVP 8 101
a=recvonly
a=ptime:20
a=maxptime:30
1537987956 -> Wed Sep 26 22:52:36 2018 116e[CMotorCall::makeResponseSdpAudio] no crypto line, media accepted=0.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::makeResponseSdpAudioOld] Final Sdp.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::emitSuccesfulMessage] Answer sdp.
Wed Sep 26 22:52:36 2018 [removeAudioMediaPortNull] media no=0.
Wed Sep 26 22:52:36 2018 116e [CCall::makeGenericResponse] 200
Wed Sep 26 22:52:36 2018 158e [CDialog::createResponse] 200
Wed Sep 26 22:52:36 2018 211b [CTransProceedingState::createResponse] CResponse 1A2 ref=1
Wed Sep 26 22:52:36 2018 1A2 [CMessage::send] sip_sendMessage (192.168.30.246:46239)
Wed Sep 26 22:52:36 2018 SEND MESSAGE TO NETWORK (192.168.30.246:46239 [TCP]) (BUFF LEN = 1015)
SIP/2.0 200 OK
Supported: replaces,timer,path,100rel
Session-Expires: 1800;refresher=uas
P-Asserted-Identity: "Abdullah" <sip:3502@192.168.30.254;user=phone>
CSeq: 25 INVITE
30.246
Content-Length: 219
v=0
o=OXE 1537987946 1537987947 IN IP4 192.168.30.254
s=abs
t=0 0
a=recvonly
a=ptime:20
a=maxptime:30
1537987956 -> Wed Sep 26 22:52:36 2018 TCP Message: Create ByteArray Object
Wed Sep 26 22:52:36 2018 1A2 [CMessage::onSendSuccess]
Wed Sep 26 22:52:36 2018 211b [CTransaction::onSendSuccess] CMessage 1A2 send Success
Wed Sep 26 22:52:36 2018 1A1 [~CResponse] resp(100) 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 25 INVITE
Wed Sep 26 22:52:36 2018 211b [CTransProceedingState::createResponse] Final : Transaction changes to Completed state
Wed Sep 26 22:52:36 2018 211b [CTransaction::changeState] STATE CHANGED TO COMPLETED
Wed Sep 26 22:52:36 2018 158e [CDialog::onTransactionState(pTrans = 211b, previousState = Proceeding, currentState = Com
pleted, reason = Final resp creation]
Wed Sep 26 22:52:36 2018 211b [CTransaction::startTimer] Timer G is started (delay = 500 ms)
Wed Sep 26 22:52:36 2018 211b [CTransaction::startTimer] Timer H is started (delay = 32000 ms)
Wed Sep 26 22:52:36 2018 158e [CDialog::updateRouteSet] there are 0 record-route headers
Wed Sep 26 22:52:36 2018 [CSessionTimerContext::updateAfterResponseRefreshCreation] Update CSessionTimerContext (respons
e refresh creation)
Wed Sep 26 22:52:36 2018 [CSessionTimerContext::updateSessionExpires] Refresher updated : i
Wed Sep 26 22:52:36 2018 [CSessionTimerContext::startTimers] Start session timer expiration : 1800000
1537987956 -> Wed Sep 26 22:52:36 2018 [CSessionTimerContext::startTimers] Start session timer will expires : 900000
Wed Sep 26 22:52:36 2018 [exec_ipc] in end 7290.
ACK sip:3502@192.168.30.254;transport=tcp SIP/2.0
CSeq: 25 ACK
Max-Forwards: 70
Via: SIP/2.0/TCP 192.168.30.246:46239;branch=z9hG4bK2a5e920_386dc6067e562d29644c395i5q1zu54406z3i1j1g1d6a3x651o_A3505192
.168.30.246
Content-Length: 0
Wed Sep 26 22:52:36 2018 16E [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Wed Sep 26 22:52:36 2018 [CIOCom::receiveRequest] Received CRequest 16E ref=1
1537987956 -> Wed Sep 26 22:52:36 2018 102 [CCallManager::onIncomingRequest()]
Wed Sep 26 22:52:36 2018 116e [CCall::receiveRequest] ACK
Wed Sep 26 22:52:36 2018 158e [CDialog::receiveAckRequest]
Wed Sep 26 22:52:36 2018 158e [CDialog::getTransactionByCSeq] CSeq = 25
Wed Sep 26 22:52:36 2018 211b [CTransaction::changeState] STATE CHANGED TO TERMINATED
Wed Sep 26 22:52:36 2018 211b [CTransaction::freeTimerToken] Timer G is freed
Wed Sep 26 22:52:36 2018 211b [CTransaction::freeTimerToken] Timer H is freed
Wed Sep 26 22:52:36 2018 211b [CTransaction::changeState] no transaction state, terminated reason : Request reception
Wed Sep 26 22:52:36 2018 158e [CDialog::receiveAckRequest] the INVITE request is terminated
Wed Sep 26 22:52:36 2018 116e [CCall::checkAuthentication] ACK
Wed Sep 26 22:52:36 2018 116e[CMotorCall::controlAuthentication] ---*--- END-03 ---*--- Control authentication
1537987956 -> Wed Sep 26 22:52:36 2018 116e[CMotorCall::onReceiveRequest] request received.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::onReceiveRequest] state = MODIFICATION_PROCEEDING_STATE.
Wed Sep 26 22:52:36 2018 116e[CMotorCall::methodAckReceived] Ack => update the inviteContext.
Wed Sep 26 22:52:36 2018 [receiveAckMessage] Call: 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 eqt: 1646 MODIFICATIO
N_PROCEEDING_STATE received a message.
Wed Sep 26 22:52:36 2018 ACK
Wed Sep 26 22:52:36 2018 [CModification_ProceedingState::receiveAckMessage]Successful_Msg_Sent is FALSE
1537987958 -> Wed Sep 26 22:52:36 2018 [CModification_ProceedingState::receiveAckMessage] continue with session Timer
Wed Sep 26 22:52:36 2018 16E [~CRequest] req 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 25 ACK
Wed Sep 26 22:52:37 2018 [CTransaction::notifyDialog]
Wed Sep 26 22:52:37 2018 [CTransaction::notifyDialog] notify parent dialog
Wed Sep 26 22:52:37 2018 158e [CDialog::onTransactionState(pTrans = 211a, previousState = null, currentState = Terminate
d, reason = Timer D fires]
Wed Sep 26 22:52:37 2018 211A [~CTransaction] transaction 1734490965 INVITE
Wed Sep 26 22:52:38 2018 RECEIVE MESSAGE FROM NETWORK (192.168.30.246:46239 [TCP])
CSeq: 26 INVITE
Max-Forwards: 70
Via: SIP/2.0/TCP 192.168.30.246:46239;branch=z9hG4bK18_386dc6086b2cc0513u146i69u2l5mi286k1l376o6n391f262e_ReI3505192.168
.30.246
Reason: avaya-action;cause=7;text="Unhold"
Content-Length: 387
v=0
o=sip:3505@192.168.30.246 1 27 IN IP4 192.168.30.246
b=TIAS:1920000
t=0 0
b=TIAS:64000
a=maxptime:60
1537987958 -> Wed Sep 26 22:52:38 2018 [CIOCom::receiveRequest] optimisation value 1
Wed Sep 26 22:52:38 2018 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.30.254 test
Wed Sep 26 22:52:38 2018 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Wed Sep 26 22:52:38 2018 16F [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Wed Sep 26 22:52:38 2018 [CIOCom::receiveRequest] Received CRequest 16F ref=1
Wed Sep 26 22:52:38 2018 [CIOCom::receiveRequest] alias param11 is received
Wed Sep 26 22:52:38 2018 [CDispatcher::onIncomingRequest()]
Wed Sep 26 22:52:38 2018 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Wed Sep 26 22:52:38 2018 102 [CCallManager::onIncomingRequest()]
Wed Sep 26 22:52:38 2018 116e [CCall::receiveRequest] INVITE
Wed Sep 26 22:52:38 2018 116e [CCall::getDialog] Confirmed Dialog found
Wed Sep 26 22:52:38 2018 158e [CDialog::receiveRequest]
Wed Sep 26 22:52:38 2018 158e [CDialog::receiveInviteRequest]
Wed Sep 26 22:52:38 2018 211c [CTransaction::changeState] STATE CHANGED TO INITIAL
Wed Sep 26 22:52:38 2018 211c [CTransaction::changeState] notifying the parent dialog
Wed Sep 26 22:52:38 2018 158e [CDialog::onTransactionState(pTrans = 211c, previousState = Terminated, currentState = Ini
Wed Sep 26 22:52:38 2018 211c [CTransInitialState::receiveRequest] Transaction changes to Proceeding state
Wed Sep 26 22:52:38 2018 211c [CTransaction::changeState] STATE CHANGED TO PROCEEDING
1537987958 -> Wed Sep 26 22:52:38 2018 158e [CDialog::onTransactionState(pTrans = 211c, previousState = Initial, current
State = Proceeding, reason = Request reception]
Wed Sep 26 22:52:38 2018 211c [CTransProceedingState::createResponse] CResponse 1A3 ref=1
Wed Sep 26 22:52:38 2018 1A3 [CMessage::send] sip_sendMessage (192.168.30.246:46239)
Wed Sep 26 22:52:38 2018 SEND MESSAGE TO NETWORK (192.168.30.246:46239 [TCP]) (BUFF LEN = 439)
SIP/2.0 100 Trying
CSeq: 26 INVITE
.30.246
Content-Length: 0
Wed Sep 26 22:52:38 2018 TCP Message: Create ByteArray Object
Wed Sep 26 22:52:38 2018 sip_sendToNetwork tcp Port =46239
Wed Sep 26 22:52:38 2018 1A3 [CMessage::onSendSuccess]
Wed Sep 26 22:52:38 2018 211c [CTransaction::onSendSuccess] CMessage 1A3 send Success
Wed Sep 26 22:52:38 2018 158e [CDialog::onSendSuccess]
Wed Sep 26 22:52:38 2018 158e [CDialog::receiveInviteRequest] a new Server INVITE transaction is in progress
Wed Sep 26 22:52:38 2018 [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh recept
ion)
1537987958 -> Wed Sep 26 22:52:38 2018 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
Wed Sep 26 22:52:38 2018 158e [CDialog::addTransaction] added transaction 211c with branch z9hG4bK18_386dc6086b2cc0513u1
46i69u2l5mi286k1l376o6n391f262e_ReI3505192.168.30.246, with CSeq 26
Wed Sep 26 22:52:38 2018 116e [CCall::receiveRequest] iErrorCode=488.
Wed Sep 26 22:52:38 2018 116e [CCall::checkAuthentication] INVITE
Wed Sep 26 22:52:38 2018 116e[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Wed Sep 26 22:52:38 2018 116e[CMotorCall::controlAuthentication] ---*--- END-02 ---*--- Control authentication
Wed Sep 26 22:52:38 2018 116e [CCall::controlAuthentication] need auth =0
Wed Sep 26 22:52:38 2018 116e [CCall::checkAuthentication] AUTHENT=0
Wed Sep 26 22:52:38 2018 116e [CCall::checkAuthentication] iRetValue=0
Wed Sep 26 22:52:38 2018 116e [CCall::receiveRequest] extGw=-1.
Wed Sep 26 22:52:38 2018 116e [CCall::receiveRequest] External Authentication by WS is in progress ...
Wed Sep 26 22:52:38 2018 116e[CMotorCall::onReceiveRequest] request received.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::onReceiveRequest] s=1 d=0 v=0 o=0.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::onReceiveRequest] request for gateway.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::onReceiveRequest] state = COMPLETED_STATE.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::methodInviteReceived] nb available licenses=2 .
Wed Sep 26 22:52:38 2018 [isUserInDico] found in the dictionnary.
1537987958 -> Wed Sep 26 22:52:38 2018 [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::compareDialogFromContext] same Dialog
Wed Sep 26 22:52:38 2018 116e[CMotorCall::methodInviteReceived] Invite => update the inviteContext.
Wed Sep 26 22:52:38 2018 [CForkedBranch::CForkedBranch] context = 0x851d0f8.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::methodInviteReceived] reqUri stored: sip:3505@192.168.30.246:46239;transport=t
cp
Wed Sep 26 22:52:38 2018 116e[CMotorCall::methodInviteReceived] cacUsed = 0 before.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::methodInviteReceived] returnStat = 0 before.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::methodInviteReceived] cacUsed = 0 after.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::methodInviteReceived] CAC = 0
Wed Sep 26 22:52:38 2018 [receiveInviteMessage] Call: 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 eqt: 1646 COMPLETE
Wed Sep 26 22:52:38 2018 [receiveInviteMessage] INFO present in Allow header
Wed Sep 26 22:52:38 2018 [receiveInviteMessage] Allow_INFO_received=TRUE
Wed Sep 26 22:52:38 2018 [checkSdpValidity] Sdp contains 1 media description(s).
Wed Sep 26 22:52:38 2018 [checkSdpValidity] without video control.
Wed Sep 26 22:52:38 2018 [checkSdpValidity] Media 0 type 1 contains 6 formats.
Wed Sep 26 22:52:38 2018 [checkSdpValidity] media audio.
Wed Sep 26 22:52:38 2018 [checkSdpValidity] Format : 9.
Wed Sep 26 22:52:38 2018 [checkSdpValidity] Format : 0.
Wed Sep 26 22:52:38 2018 [checkSdpValidity] Format : 8.
1537987958 -> Wed Sep 26 22:52:38 2018 [checkSdpValidity] return false.
Wed Sep 26 22:52:38 2018 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Wed Sep 26 22:52:38 2018 [convertSdpIntoTsdp] No Direction in the session part.
Wed Sep 26 22:52:38 2018 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
Wed Sep 26 22:52:38 2018 [convertSdpIntoTsdp] new media analyzed=0 sdp_index=0 count=1.
Wed Sep 26 22:52:38 2018 [audioMediaSentToCH] media AUDIO detected (previous crypto=0).
Wed Sep 26 22:52:38 2018 [convertCryptoInfoInFile] clearMediaLine2: 0.
Wed Sep 26 22:52:38 2018 [convertAudioMedia] The audio media contains 6 format(s).
Wed Sep 26 22:52:38 2018 [convertAudioMedia] Format 0 is 9 opt syst G711=0.
Wed Sep 26 22:52:38 2018 [convertAudioMedia] Format 1 is 0 opt syst G711=0.
Wed Sep 26 22:52:38 2018 [convertAudioMedia] Format 2 is 8 opt syst G711=0.
Wed Sep 26 22:52:38 2018 [convertAudioMedia] Format is PCMA.
Wed Sep 26 22:52:38 2018 [convertAudioMedia] Format 3 is 110 opt syst G711=0.
Wed Sep 26 22:52:38 2018 [convertAudioMedia] 110.
Wed Sep 26 22:52:38 2018 [convertAudioMedia] Format 4 is 18 opt syst G711=0.
Wed Sep 26 22:52:38 2018 [convertAudioMedia] Format is G729.
Wed Sep 26 22:52:38 2018 [convertAudioMedia] Format 5 is 101 opt syst G711=0.
Wed Sep 26 22:52:38 2018 [convertAudioMedia] 101.
Wed Sep 26 22:52:38 2018 [convertAudioMedia] Format is DTMF:101.
Wed Sep 26 22:52:38 2018 [convertAudioMedia] invalid Direction in this media part.
Wed Sep 26 22:52:38 2018 [convertAudioMedia] Connection address retrieved in sdp: 192.168.30.246.
1537987958 -> Wed Sep 26 22:52:38 2018 [convertIPStrIntoTuipv] 192.168.30.246 => 192.168.30.246
Wed Sep 26 22:52:38 2018 [audioMediaSentToCH] sdp index=0.
Wed Sep 26 22:52:38 2018 [display_sdp] address =192.168.30.246
Wed Sep 26 22:52:38 2018 [display_sdp] codecs =0.
Wed Sep 26 22:52:38 2018 [display_sdp] codecs =17.
Wed Sep 26 22:52:38 2018 [display_sdp] codecs =101.
Wed Sep 26 22:52:38 2018 [display_sdp] direction=0.
Wed Sep 26 22:52:38 2018 [convertSdpIntoTsdp] ok.
Wed Sep 26 22:52:38 2018 [convertSdpIntoTsdp] 5-crypto_info=0xbfffefec crypto_index=0 clear media=1
Wed Sep 26 22:52:38 2018 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
Wed Sep 26 22:52:38 2018 [convertSdpIntoTsdp] 3-crypto_info=0xbfffefec crypto_index=0 clear media=1
Wed Sep 26 22:52:38 2018 116e[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Wed Sep 26 22:52:38 2018 116e[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=0 uacRefresher=0.
Wed Sep 26 22:52:38 2018 116e[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Wed Sep 26 22:52:38 2018 116e[emitEventToMonitel] CAC = 0 eqtCAC = -1
Wed Sep 26 22:52:38 2018 116e[emitEventToMonitel] cacUsed=0 eqtCac=-1
Wed Sep 26 22:52:38 2018 116e[emitEventToMonitel] displayIPCMessageOut
Wed Sep 26 22:52:38 2018 ** SEPLOS **
Wed Sep 26 22:52:38 2018 [sendLgEvtSip] seplos Event sent on eqt : 1646 Id :1
Wed Sep 26 22:52:38 2018 [display_ipc_out] ------------ Begin ---------------
Wed Sep 26 22:52:38 2018 Id : 1
1537987958 -> Wed Sep 26 22:52:38 2018 RE_INVITE
Wed Sep 26 22:52:38 2018 SDP :
Wed Sep 26 22:52:38 2018 ADDRESS : 192.168.30.246 :5004
Wed Sep 26 22:52:38 2018 ALGOS :
Wed Sep 26 22:52:38 2018 PCMA
Wed Sep 26 22:52:38 2018 G729
Wed Sep 26 22:52:38 2018 101
Wed Sep 26 22:52:38 2018 DIRECTION : SEND & RECEIVE
Wed Sep 26 22:52:38 2018 video index : 0
Wed Sep 26 22:52:38 2018 crypto index : 0
Wed Sep 26 22:52:38 2018 [display_ipc_out] ------------- End ----------------
Wed Sep 26 22:52:38 2018 [ipc_thread] Normal case : evt 10765
Wed Sep 26 22:52:38 2018 [ipc_thread] IPC Thread : Ipc reception 7298.
Wed Sep 26 22:52:38 2018 [ipc_thread] IPC Thread : TCL thread signaled.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Wed Sep 26 22:52:38 2018 [exec_ipc] in 7290.
Wed Sep 26 22:52:38 2018 [display_ipc_in] ------------ Begin ---------------
Wed Sep 26 22:52:38 2018 neqt : 1646 Id : 1
Wed Sep 26 22:52:38 2018 SUCCESSFUL
Wed Sep 26 22:52:38 2018 xx : 0
Wed Sep 26 22:52:38 2018 RELATIVE REQUEST : RE_INVITE
Wed Sep 26 22:52:38 2018 CLIR : 0
Wed Sep 26 22:52:38 2018 COLP : 1
Wed Sep 26 22:52:38 2018 CAC-CSBU info : UNKNOWN
Wed Sep 26 22:52:38 2018 ADDRESS : 192.168.30.29 :32514
1537987958 -> Wed Sep 26 22:52:38 2018 [display_ipc_in] ------------- End ----------------
Wed Sep 26 22:52:38 2018 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 1646 1.
Wed Sep 26 22:52:38 2018 [CMotorCallManager::onIncomingEvent] seplos station.
Wed Sep 26 22:52:38 2018 [CMotorCallManager::onIncomingEvent] state = MODIFICATION_PROCEEDING_STATE.
Wed Sep 26 22:52:38 2018 [onIncomingEvent] SUCCESSFUL arrived.
Wed Sep 26 22:52:38 2018 [onIncomingEvent] relative_request = 10753
Wed Sep 26 22:52:38 2018 [receiveSuccessfulEvent] Call: 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 eqt: 1646 MODIFI
Wed Sep 26 22:52:38 2018 [quoteString] => "Abdullah"
Wed Sep 26 22:52:38 2018 116e[CMotorCall::isTLSProtRequiredForExtGw] =0.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::emitSuccessfulMessage] P-Asserted-Identity: "Abdullah" <sip:3502@192.168.30.25
4;user=phone>
Wed Sep 26 22:52:38 2018 0[CMotorCall::emitSuccessfulMessage] isIpDect=-1073745924
Wed Sep 26 22:52:38 2018 116e[CMotorCall::emitSuccessfulMessage] uacGatewayMode=0 uacRefresher=0.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::makeResponseSdpAudioOld] Audio media.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::appendAudioAttributToMedia] Direction: 0.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::appendAudioAttributToMedia] format 101
Wed Sep 26 22:52:38 2018 116e[CMotorCall::makeResponseSdpAudio] fromSdp.getMediaDesciprionCount :1
Wed Sep 26 22:52:38 2018 [sameCodec] accepted Format : 8.
Wed Sep 26 22:52:38 2018 [sameCodec] requested Format : 9.
1537987958 -> Wed Sep 26 22:52:38 2018 [sameCodec] requested Format : 0.
Wed Sep 26 22:52:38 2018 [sameCodec] requested Format : 8.
Wed Sep 26 22:52:38 2018 [sameCodec] same Format.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::mediaAccepted] Media accepted: m=audio 32514 RTP/AVP 8 101
a=sendrecv
a=ptime:20
a=maxptime:30
Wed Sep 26 22:52:38 2018 116e[CMotorCall::makeResponseSdpAudio] no crypto line, media accepted=0.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::makeResponseSdpAudioOld] Final Sdp.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::emitSuccesfulMessage] Answer sdp.
Wed Sep 26 22:52:38 2018 [removeAudioMediaPortNull] media no=0.
Wed Sep 26 22:52:38 2018 116e [CCall::makeGenericResponse] 200
Wed Sep 26 22:52:38 2018 158e [CDialog::createResponse] 200
Wed Sep 26 22:52:38 2018 211c [CTransProceedingState::createResponse] CResponse 1A4 ref=1
Wed Sep 26 22:52:38 2018 1A4 [CMessage::send] sip_sendMessage (192.168.30.246:46239)
Wed Sep 26 22:52:38 2018 SEND MESSAGE TO NETWORK (192.168.30.246:46239 [TCP]) (BUFF LEN = 1016)
SIP/2.0 200 OK
CSeq: 26 INVITE
.30.246
Content-Length: 219
v=0
o=OXE 1537987946 1537987948 IN IP4 192.168.30.254
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
1537987958 -> Wed Sep 26 22:52:38 2018 TCP Message: Create ByteArray Object
Wed Sep 26 22:52:38 2018 1A4 [CMessage::onSendSuccess]
Wed Sep 26 22:52:38 2018 211c [CTransaction::onSendSuccess] CMessage 1A4 send Success
Wed Sep 26 22:52:38 2018 1A3 [~CResponse] resp(100) 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 26 INVITE
Wed Sep 26 22:52:38 2018 211c [CTransProceedingState::createResponse] Final : Transaction changes to Completed state
Wed Sep 26 22:52:38 2018 211c [CTransaction::changeState] STATE CHANGED TO COMPLETED
Wed Sep 26 22:52:38 2018 158e [CDialog::onTransactionState(pTrans = 211c, previousState = Proceeding, currentState = Com
Wed Sep 26 22:52:38 2018 211c [CTransaction::startTimer] Timer G is started (delay = 500 ms)
Wed Sep 26 22:52:38 2018 211c [CTransaction::startTimer] Timer H is started (delay = 32000 ms)
Wed Sep 26 22:52:38 2018 158e [CDialog::updateRouteSet] there are 0 record-route headers
Wed Sep 26 22:52:38 2018 [CSessionTimerContext::updateAfterResponseRefreshCreation] Update CSessionTimerContext (respons
e refresh creation)
Wed Sep 26 22:52:38 2018 [CSessionTimerContext::updateSessionExpires] Refresher updated : i
Wed Sep 26 22:52:38 2018 [CSessionTimerContext::startTimers] Start session timer expiration : 1800000
1537987958 -> Wed Sep 26 22:52:38 2018 [CSessionTimerContext::startTimers] Start session timer will expires : 900000
Wed Sep 26 22:52:38 2018 [exec_ipc] in end 7290.
CSeq: 26 ACK
Max-Forwards: 70
Via: SIP/2.0/TCP 192.168.30.246:46239;branch=z9hG4bK2a5e920_386dc609-7d47a91ep4f4k1k2q3h4oi403x4y446f3r6e494p4z_A3505192
.168.30.246
Content-Length: 0
Wed Sep 26 22:52:38 2018 170 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Wed Sep 26 22:52:38 2018 [CIOCom::receiveRequest] Received CRequest 170 ref=1
1537987958 -> Wed Sep 26 22:52:38 2018 102 [CCallManager::onIncomingRequest()]
Wed Sep 26 22:52:38 2018 116e [CCall::receiveRequest] ACK
Wed Sep 26 22:52:38 2018 158e [CDialog::receiveAckRequest]
Wed Sep 26 22:52:38 2018 158e [CDialog::getTransactionByCSeq] CSeq = 26
Wed Sep 26 22:52:38 2018 211c [CTransaction::changeState] STATE CHANGED TO TERMINATED
Wed Sep 26 22:52:38 2018 211c [CTransaction::freeTimerToken] Timer G is freed
Wed Sep 26 22:52:38 2018 211c [CTransaction::freeTimerToken] Timer H is freed
Wed Sep 26 22:52:38 2018 211c [CTransaction::changeState] no transaction state, terminated reason : Request reception
Wed Sep 26 22:52:38 2018 158e [CDialog::receiveAckRequest] the INVITE request is terminated
Wed Sep 26 22:52:38 2018 116e [CCall::checkAuthentication] ACK
Wed Sep 26 22:52:38 2018 116e[CMotorCall::controlAuthentication] ---*--- END-03 ---*--- Control authentication
1537987958 -> Wed Sep 26 22:52:38 2018 116e[CMotorCall::onReceiveRequest] request received.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::onReceiveRequest] state = MODIFICATION_PROCEEDING_STATE.
Wed Sep 26 22:52:38 2018 116e[CMotorCall::methodAckReceived] Ack => update the inviteContext.
Wed Sep 26 22:52:38 2018 [receiveAckMessage] Call: 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 eqt: 1646 MODIFICATIO
Wed Sep 26 22:52:38 2018 ACK
Wed Sep 26 22:52:38 2018 [CModification_ProceedingState::receiveAckMessage]Successful_Msg_Sent is FALSE
1537987959 -> Wed Sep 26 22:52:38 2018 [CModification_ProceedingState::receiveAckMessage] continue with session Timer
Wed Sep 26 22:52:38 2018 170 [~CRequest] req 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 26 ACK
1537987961 -> Wed Sep 26 22:52:41 2018 RECEIVE MESSAGE FROM NETWORK (192.168.30.246:46239 [TCP])
BYE sip:3502@192.168.30.254;transport=tcp SIP/2.0
CSeq: 27 BYE
Max-Forwards: 70
Via: SIP/2.0/TCP 192.168.30.246:46239;branch=z9hG4bK2a6dc00_386dc60b-281bbb98455n4z1o4q5d37o3o1r315q6q2l5e2h3i6b_B350519
2.168.30.246
Content-Length: 0
Wed Sep 26 22:52:41 2018 [CIOCom::receiveRequest] optimisation value 1
Wed Sep 26 22:52:41 2018 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.30.254 test
Wed Sep 26 22:52:41 2018 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Wed Sep 26 22:52:41 2018 171 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Wed Sep 26 22:52:41 2018 [CIOCom::receiveRequest] Received CRequest 171 ref=1
Wed Sep 26 22:52:41 2018 [CIOCom::receiveRequest] alias param11 is received
Wed Sep 26 22:52:41 2018 [CDispatcher::onIncomingRequest()]
Wed Sep 26 22:52:41 2018 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Wed Sep 26 22:52:41 2018 102 [CCallManager::onIncomingRequest()]
Wed Sep 26 22:52:41 2018 116e [CCall::receiveRequest] BYE
1537987961 -> Wed Sep 26 22:52:41 2018 116e [CCall::getDialog] Confirmed Dialog found
Wed Sep 26 22:52:41 2018 158e [CDialog::receiveRequest]
Wed Sep 26 22:52:41 2018 158e [CDialog::receiveBasicRequest]
Wed Sep 26 22:52:41 2018 211d [CTransaction::changeState] STATE CHANGED TO INITIAL
Wed Sep 26 22:52:41 2018 211d [CTransaction::changeState] notifying the parent dialog
Wed Sep 26 22:52:41 2018 158e [CDialog::onTransactionState(pTrans = 211d, previousState = Terminated, currentState = Ini
Wed Sep 26 22:52:41 2018 211d [CTransInitialState::receiveRequest] Transaction changes to Trying state
Wed Sep 26 22:52:41 2018 211d [CTransaction::changeState] STATE CHANGED TO TRYING
Wed Sep 26 22:52:41 2018 158e [CDialog::onTransactionState(pTrans = 211d, previousState = Initial, currentState = Trying
Wed Sep 26 22:52:41 2018 158e [CDialog::addTransaction] added transaction 211d with branch z9hG4bK2a6dc00_386dc60b-281bb
b98455n4z1o4q5d37o3o1r315q6q2l5e2h3i6b_B3505192.168.30.246, with CSeq 27
Wed Sep 26 22:52:41 2018 [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
Wed Sep 26 22:52:41 2018 116e [CCall::receiveRequest] iErrorCode=488.
Wed Sep 26 22:52:41 2018 116e [CCall::checkAuthentication] BYE
Wed Sep 26 22:52:41 2018 116e[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Wed Sep 26 22:52:41 2018 116e[CMotorCall::controlAuthentication] ---*--- END-03 ---*--- Control authentication
1537987961 -> Wed Sep 26 22:52:41 2018 116e [CCall::controlAuthentication] need auth =0
Wed Sep 26 22:52:41 2018 116e [CCall::checkAuthentication] AUTHENT=0
Wed Sep 26 22:52:41 2018 116e [CCall::checkAuthentication] iRetValue=0
Wed Sep 26 22:52:41 2018 116e [CCall::receiveRequest] extGw=-1.
Wed Sep 26 22:52:41 2018 116e [CCall::receiveRequest] External Authentication by WS is in progress ...
Wed Sep 26 22:52:41 2018 116e[CMotorCall::onReceiveRequest] request received.
Wed Sep 26 22:52:41 2018 116e[CMotorCall::onReceiveRequest] s=1 d=0 v=0 o=0.
Wed Sep 26 22:52:41 2018 116e[CMotorCall::onReceiveRequest] request for gateway.
Wed Sep 26 22:52:41 2018 116e[CMotorCall::onReceiveRequest] state = COMPLETED_STATE.
Wed Sep 26 22:52:41 2018 [receiveByeMessage] Call: 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 eqt: 1646 COMPLETED_S
Wed Sep 26 22:52:41 2018 116e[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Wed Sep 26 22:52:41 2018 116e[emitEventToMonitel] CAC = 0 eqtCAC = -1
Wed Sep 26 22:52:41 2018 116e[emitEventToMonitel] cacUsed=0 eqtCac=-1
Wed Sep 26 22:52:41 2018 116e[emitEventToMonitel] displayIPCMessageOut
Wed Sep 26 22:52:41 2018 ** SEPLOS **
Wed Sep 26 22:52:41 2018 [sendLgEvtSip] seplos Event sent on eqt : 1646 Id :1
Wed Sep 26 22:52:41 2018 [display_ipc_out] ------------ Begin ---------------
Wed Sep 26 22:52:41 2018 Id : 1
Wed Sep 26 22:52:41 2018 BYE
Wed Sep 26 22:52:41 2018 [display_ipc_out] ------------- End ----------------
Wed Sep 26 22:52:41 2018 [ipc_thread] Normal case : evt 10765
1537987961 -> Wed Sep 26 22:52:41 2018 [ipc_thread] IPC Thread : Ipc reception 7298.
Wed Sep 26 22:52:41 2018 [ipc_thread] IPC Thread : TCL thread signaled.
Wed Sep 26 22:52:41 2018 116e[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Wed Sep 26 22:52:41 2018 [exec_ipc] in 7290.
Wed Sep 26 22:52:41 2018 [display_ipc_in] ------------ Begin ---------------
Wed Sep 26 22:52:41 2018 neqt : 1646 Id : 1
Wed Sep 26 22:52:41 2018 SUCCESSFUL
Wed Sep 26 22:52:41 2018 xx : 0
Wed Sep 26 22:52:41 2018 RELATIVE REQUEST : BYE
Wed Sep 26 22:52:41 2018 CLIR : 0
Wed Sep 26 22:52:41 2018 COLP : 0
Wed Sep 26 22:52:41 2018 CAC-CSBU info : UNKNOWN
Wed Sep 26 22:52:41 2018 [display_ipc_in] ------------- End ----------------
Wed Sep 26 22:52:41 2018 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 1646 1.
Wed Sep 26 22:52:41 2018 [CMotorCallManager::onIncomingEvent] seplos station.
Wed Sep 26 22:52:41 2018 [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
Wed Sep 26 22:52:41 2018 [onIncomingEvent] SUCCESSFUL arrived.
Wed Sep 26 22:52:41 2018 [onIncomingEvent] relative_request = 10755
Wed Sep 26 22:52:41 2018 [receiveSuccessfulEvent] Call: 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 eqt: 1646 TERMIN
ATED_STATE received an event.
Wed Sep 26 22:52:41 2018 0[CMotorCall::emitSuccessfulMessage] isIpDect=-1073745924
Wed Sep 26 22:52:41 2018 158e [CCall::findFirstServerTrans]
Wed Sep 26 22:52:41 2018 158e [CCallLeg::findFirstOpenServerTrans] Current Request in transactionMapByBranch
1537987961 -> Wed Sep 26 22:52:41 2018 116e [CCall::makeGenericResponse] 200
Wed Sep 26 22:52:41 2018 158e [CDialog::createResponse] 200
Wed Sep 26 22:52:41 2018 211d [CTransTryingState::createResponse] CResponse 1A5 ref=1
Wed Sep 26 22:52:41 2018 1A5 [CMessage::send] sip_sendMessage (192.168.30.246:46239)
Wed Sep 26 22:52:41 2018 SEND MESSAGE TO NETWORK (192.168.30.246:46239 [TCP]) (BUFF LEN = 609)
SIP/2.0 200 OK
CSeq: 27 BYE
2.168.30.246
Content-Length: 0
Wed Sep 26 22:52:41 2018 TCP Message: Create ByteArray Object
Wed Sep 26 22:52:41 2018 sip_sendToNetwork tcp Port =46239
Wed Sep 26 22:52:41 2018 1A5 [CMessage::onSendSuccess]
Wed Sep 26 22:52:41 2018 211d [CTransaction::onSendSuccess] CMessage 1A5 send Success
Wed Sep 26 22:52:41 2018 158e [CDialog::onSendSuccess]
Wed Sep 26 22:52:41 2018 211d [CTransTryingState::createResponse] Final : Transaction changes to Completed state
1537987961 -> Wed Sep 26 22:52:41 2018 211d [CTransaction::changeState] STATE CHANGED TO COMPLETED
Wed Sep 26 22:52:41 2018 158e [CDialog::onTransactionState(pTrans = 211d, previousState = Trying, currentState = Complet
Wed Sep 26 22:52:41 2018 211d [CTransCompletedState::enterInState] Final(!UDP) : BASIC Client Transaction changes to Ter
minated state
Wed Sep 26 22:52:41 2018 211d [CTransaction::changeState] STATE CHANGED TO TERMINATED
Wed Sep 26 22:52:41 2018 211d [CTransaction::changeState] no transaction state, terminated reason : Timer J fires
Wed Sep 26 22:52:41 2018 158e [CDialog::updateRouteSet] there are 0 record-route headers
Wed Sep 26 22:52:41 2018 [exec_ipc] in end 7290.
Wed Sep 26 22:52:41 2018 [ipc_thread] Normal case : evt 10773
Wed Sep 26 22:52:41 2018 SIP EQT RELEASED
Wed Sep 26 22:52:41 2018 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1646 1.
Wed Sep 26 22:52:41 2018 [CMotorCallManager::onIncomingEvent] The call with eqt: 1646 has released its equipment.
1537987961 -> Wed Sep 26 22:52:41 2018 [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
Wed Sep 26 22:52:41 2018 116e[CMotorCall::unRegister] Remove eqt : 1646 diag : 1 from the map.
Wed Sep 26 22:52:41 2018 [CMotorCallManager::eraseCallwithEqt] erase 1646 1.
Wed Sep 26 22:52:41 2018 [CMotorCallManager::onIncomingEvent] killSession.
Wed Sep 26 22:52:41 2018 116e [CCall::killSession]
Wed Sep 26 22:52:41 2018 2119 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Wed Sep 26 22:52:41 2018 2119 [CTransaction::changeState] no transaction state, terminated reason : None
Wed Sep 26 22:52:41 2018 158e [CDialog::removeSubscriptionTimer]
Wed Sep 26 22:52:41 2018 116e [CCall::killSession] notifying the call manager
Wed Sep 26 22:52:41 2018 102 [CCallManager::onCallClosed]
Wed Sep 26 22:52:41 2018 102 [CCallManager::onCallClosed()] Call 116e closed. Removing call 139578176 from the maps
Wed Sep 26 22:52:41 2018 [CMotorCallManager::onNotifyCallClosed] Call : 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254
is closed.
Wed Sep 26 22:52:41 2018 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
Wed Sep 26 22:52:41 2018 102 [CCallManager::onCallClosed] pCall added in the Garbage List
Wed Sep 26 22:52:41 2018 [CTransaction::notifyDialog]
Wed Sep 26 22:52:41 2018 [CTransaction::notifyDialog] notify parent dialog
Wed Sep 26 22:52:41 2018 158e [CDialog::onTransactionState(pTrans = 211d, previousState = null, currentState = Terminate
d, reason = Timer J fires]
1537987962 -> Wed Sep 26 22:52:41 2018 116e [CCall::onDialogClosed]
Wed Sep 26 22:52:41 2018 116e [CCall::onDialogClosed] not only initial *********
Wed Sep 26 22:52:41 2018 116e [CCall::onDialogClosed]: the dialog 158e is closed
Wed Sep 26 22:52:41 2018 116e [CCall::onDialogClosed] All the dialogs in the Call are closed
Wed Sep 26 22:52:41 2018 211D [~CTransaction] transaction 27 BYE
Wed Sep 26 22:52:41 2018 158e [CDialog::onTransactionState(pTrans = 211b, previousState = null, currentState = Terminate
d, reason = Request reception]
Wed Sep 26 22:52:41 2018 211B [~CTransaction] transaction 25 INVITE
Wed Sep 26 22:52:41 2018 1A2 [~CResponse] resp(200) 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 25 INVITE
Wed Sep 26 22:52:41 2018 16D [~CRequest] req 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 25 INVITE
Wed Sep 26 22:52:42 2018 102 [CCallManager::removeGarbage] at index i = 0
Wed Sep 26 22:52:42 2018 116e [CMotorCall::clear_subscription] no subscription managed
Wed Sep 26 22:52:42 2018 116e[CMotorCall::~CMotorCall] Call : 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 is being d
estructed.
Wed Sep 26 22:52:42 2018 116e [CCall::TestDegradedModeEnd] nb resources=-1
Wed Sep 26 22:52:42 2018 116e [CCall::~CCall]
Wed Sep 26 22:52:42 2018 116e [CCall::removeGarbage]
Wed Sep 26 22:52:42 2018 158e [CDialog::~CDialog]
Wed Sep 26 22:52:42 2018 211C [~CTransaction] transaction 26 INVITE
1537987963 -> Wed Sep 26 22:52:42 2018 1A4 [~CResponse] resp(200) 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 26 INV
ITE
Wed Sep 26 22:52:42 2018 16F [~CRequest] req 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 26 INVITE
Wed Sep 26 22:52:42 2018 158e [~CDialog] delete ack request # 0
Wed Sep 26 22:52:42 2018 158d [CDialog::~CDialog]
Wed Sep 26 22:52:42 2018 2119 [~CTransaction] transaction 1734490965 INVITE
Wed Sep 26 22:52:42 2018 19F [~CResponse] resp(180) 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 1734490965 INVITE
Wed Sep 26 22:52:42 2018 [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
Wed Sep 26 22:52:42 2018 16C [~CRequest] req 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 1734490965 ACK
Wed Sep 26 22:52:42 2018 1A0 [~CResponse] resp(200) 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 1734490965 INVITE
Wed Sep 26 22:52:42 2018 16B [~CRequest] req 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 1734490965 INVITE
Wed Sep 26 22:52:42 2018 1A5 [~CResponse] resp(200) 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 27 BYE
Wed Sep 26 22:52:42 2018 171 [~CRequest] req 01dd21072b66b55aea03bfa67e9ba88a@192.168.30.254 27 BYE
Return to “H323 / Sip”
