Trouble making and recieving calls on SIP
A H323 and SIP forum only !
alcatelguru
Re: Trouble making and recieving calls on SIP
Post by alcatelguru »
The COS is 31 and all the values are set to 1.Any idea ?
What do you mean that everything is 1? External discriminator? If you put this Public CoS to an extension, can he dial out?
alcatelguru
I can do the test tmrw at the site.But at this time i can only test incoming calls by dialing from my mobile.Why isn't the incoming call not going thru?.I have checked all the values for discriminator.Also thanks for the changes made to the ARS.I shall update you once i am at site.
alcatelboy
Post by alcatelboy »
your sip trunk call id is 290083900?
i can call the number 437407840 to be test ?
AQPS ACFE ACSE
alcatelguru
The SIP number to call is 61-2-90083901
where 3901 is extension
The number 437407840 is my mobile number that I was trying to call.
alcatelguru
New traces for reference.
Calling extension:3903
Calling number:0290083901
Also external number called from 0283066276 to 0290083901
OUTBOUND TRACES
1225088853 -> [quoteString] => "290083903"
1225088853 -> 1126[CMotorCall::inviteBuildAurlWithBelongingDomain] P-Asserted-Id
entity: "290083903" <sip:290083903@125.254.25.4>
1225088853 -> 1126[CMotorCall::emitInviteMessage] From: "290083903" <sip:2900839
03@125.254.25.4>
1225088853 -> 1126[CMotorCall::emitInviteMessage] reqUri :sip:0290083901@125.254
.25.4;user=phone
1225088853 -> 1126[CMotorCall::inviteBuildSupportedHeader] Invite directed to ex
ternal gw : 0
1225088853 -> 1126[CMotorCall::emitInviteMessage] Request Uri : sip:0290083901@1
25.254.25.4;user=phone
1225088853 -> 1126[CMotorCall::emitInviteMessage] To: <sip:0290083901@125.254.2
5.4;user=phone>
1225088853 -> 1126[CMotorCall::emitInviteMessage] Contact: sip:203.36.12.10
1225088853 -> 1126[CMotorCall::makeRequestSdp] Begin sdp : v=0
o=OXE 1225088853 1225088853 IN IP4 203.36.12.10
s=-
c=IN IP4 0.0.0.0
t=0 0
1225088853 -> 1126[CMotorCall::makeRequestSdp] Direction: 0.
1225088853 -> 1126[CMotorCall::makeResponseSdp] format 97
1225088853 -> 1126[CMotorCall::makeRequestSdp] Final sdp: v=0
s=abs
c=IN IP4 203.36.12.3
t=0 0
m=audio 32514 RTP/AVP 8 0 4 97
a=sendrecv
a=rtpmap:8 PCMA/8000
a=ptime:20
a=maxptime:30
a=rtpmap:0 PCMU/8000
a=ptime:20
a=maxptime:30
a=rtpmap:4 G723/8000
a=ptime:30
a=maxptime:30
a=rtpmap:97 telephone-event/8000
1225088853 -> 1126[CMotorCall::emitInviteMessage] The sdp build: .
1225088853 -> 1126[CMotorCall::new_determineTargetsForTheRequest] is not Respons
ible For This URI.
1225088853 -> 1126[CMotorCall::makeInitialMotorRequest] nb contacts=1.
1225088853 -> 1126[CMotorCall::makeInitialMotorRequest] *pcszNameToFind : 029008
3901
1225088853 -> 1126[CMotorCall::makeInitialMotorRequest]-->extGw=0
1225088853 -> 1126[CMotorCall::makeInitialMotorRequest] contact : sip:0290083901
@125.254.25.4;user=phone
1225088853 -> 1126[CMotorCall::makeInitialMotorRequest] nb available licenses=99
999 .
1225088853 -> 1126[CMotorCall::makeInitialMotorRequest] req_Uri_OK=0
1225088853 -> 1126[CMotorCall::makeInitialMotorRequest]-->pSipAddSpec->getHost()
=125.254.25.4
1225088853 -> 1126[CMotorCall::makeInitialMotorRequest] user= 0290083901
1225088853 -> [CGWMngData::isMainServer] CPU is MAIN.
1225088853 -> 1126 [CCall::makeGenericRequest] INVITE
1225088853 -> 1126 [CCall::getDialog] Confirmed Dialog is not found (ID = ;)
1225088853 -> 1126 [CCall::getDialog] Returning Initial Dialog Client
1225088853 -> 1526 [CDialog::createRequest]
1225088853 -> 1526 [CDialog::buildServicesForAllRequest]
1225088853 -> 1526 [CDialog::createInviteRequest]
1225088853 -> 2124 [CTransaction::changeState] STATE CHANGED TO INITIAL
1225088853 -> 2124 [CTransaction::changeState] notifying the parent dialog
1225088853 -> 1526 [CDialog::onTransactionState(pTrans = 2124, previousState = T
erminated, currentState = Initial, reason = None]
1225088853 -> 49 [CRequest::CRequest] Creation of a request
1225088853 -> 49 [CMessage::send] sip_sendMessage (125.254.25.4:5060)
1225088853 -> SEND MESSAGE TO NETWORK (125.254.25.4:5060 [UDP]) (BUFF LEN = 876)
INVITE sip:0290083901@125.254.25.4;user=phone SIP/2.0
Supported: replaces,100rel
User-Agent: ABS GW v5.1.0
P-Asserted-Identity: "290083903" <sip:290083903@125.254.25.4>
Content-Type: application/sdp
To: <sip:0290083901@125.254.25.4;user=phone>
From: "290083903" <sip:290083903@125.254.25.4>;tag=8629f1bc5373fddeed487f555c611
508
Call-ID: c17a10169709eabe07c606b3f1bbbec4@203.36.12.10
CSeq: 968417036 INVITE
Via: SIP/2.0/UDP 203.36.12.10;branch=z9hG4bKf7553e6d1a1811b30951a785fec60049
Max-Forwards: 70
Content-Length: 315
v=0
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=ptime:20
a=maxptime:30
a=ptime:30
a=maxptime:30
1225088853 -> 2124 [CTransInitialState::createRequest] Transaction changes to Ca
lling state
1225088853 -> 2124 [CTransaction::changeState] STATE CHANGED TO CALLING
1225088853 -> 1526 [CDialog::onTransactionState(pTrans = 2124, previousState = I
nitial, currentState = Calling, reason = Request creation]
1225088853 -> 2124 [CTransaction::startTimer] Timer A is started (delay = 500 ms
1225088853 -> 2124 [CTransaction::startTimer] Timer B is started (delay = 32000
ms)
1225088853 -> [---*--- SESSION-TIMER ---*---] New CSessionTimerContext from requ
est (Client, UA)
1225088853 -> [---*--- SESSION-TIMER ---*---] Update CSessionTimerContext (refre
sh creation)
1225088853 -> 1126[CMotorCall::makeInitialMotorRequest] nb contact=1.
1225088853 -> [CForkedBranch::CForkedBranch] context = 0x839e13c.
1225088853 -> 1126[CMotorCall::branchAllocation] built branch number=1.
1225088853 -> [onIncomingEvent] CallID must be inserted.
1225088853 -> [onIncomingEvent] CallID inserted.
1225088853 -> RECEIVE MESSAGE FROM NETWORK (125.254.25.4:50195 [UDP])
SIP/2.0 100 Trying
508
Content-Length: 0
1225088853 -> [CIOCom::receiveResponse] CResponse 47 ref=1
1225088853 -> [CDispatcher::onIncomingResponse]
1225088853 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1225088853 -> 102 [CCallManager::onIncomingResponse]
1225088853 -> 1126 [CCall::receiveResponse] 100
1225088853 -> 1126 [CCall::receiveResponse]Trying to find the right dialog
1225088853 -> 1126 [CCall::getDialog] Confirmed Dialog is not found (ID = 8629f1
bc5373fddeed487f555c611508;)
1225088853 -> 1126 [CCall::receiveResponse]One dialog found
1225088853 -> 1526 [CDialog::receiveResponse]
1225088853 -> 2124 [CTransCallingState::receiveResponse] Provisional : Transacti
on changes to Proceeding state
1225088853 -> 2124 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
1225088853 -> 1526 [CDialog::onTransactionState(pTrans = 2124, previousState = C
alling, currentState = Proceeding, reason = 1xx response reception]
1225088853 -> 2124 [CTransaction::freeTimerToken] Timer A is freed
1225088853 -> 2124 [CTransaction::freeTimerToken] Timer B is freed
1225088853 -> 1126[CMotorCall::searchForkedBranch]pForkedBranch=0x839e5b8.
1225088853 -> [receiveInformationalMessage] Call: c17a10169709eabe07c606b3f1bbbe
c4@203.36.12.10 eqt: 1036 PROCEEDING_STATE received a message.
SIP/2.0 404 Not Found
Supported: 100rel
To: <sip:0290083901@125.254.25.4;user=phone>;tag=3434077854-727855
508
P-Asserted-Identity:"290083903"<sip:290083903@125.254.25.4>
Allow: INVITE, BYE, OPTIONS, CANCEL, ACK, REGISTER, NOTIFY, INFO, REFER, SUBSCRI
BE, PRACK
Contact: <sip:0290083901@125.254.25.4:5060;user=phone>
Call-Info: <sip:125.254.25.4>;method="NOTIFY;Event=telephone-event;Duration=1000
Content-Length: 0
1225088853 -> [CIOCom::receiveResponse] CResponse 48 ref=1
1225088853 -> 1126 [CCall::receiveResponse] 404
bc5373fddeed487f555c611508;3434077854-727855)
1225088853 -> 47 [~CResponse] resp(100) c17a10169709eabe07c606b3f1bbbec4@203.36.
12.10 968417036 INVITE
1225088853 -> 2124 [CTransProceedingState::receiveResponse] Final : Transaction
changes to Completed state
1225088853 -> 2124 [CTransaction::changeState] STATE CHANGED TO COMPLETED
1225088853 -> 1526 [CDialog::onTransactionState(pTrans = 2124, previousState = P
roceeding, currentState = Completed, reason = Final resp reception]
1225088853 -> 4A [CRequest::CRequest] Creation of a request
1225088853 -> 4A [CMessage::send] sip_sendMessage (125.254.25.4:5060)
1225088853 -> SEND MESSAGE TO NETWORK (125.254.25.4:5060 [UDP]) (BUFF LEN = 381)
ACK sip:0290083901@125.254.25.4;user=phone SIP/2.0
508
CSeq: 968417036 ACK
Content-Length: 0
1225088853 -> 2124 [CTransaction::startTimer] Timer D is started (delay = 32451
ms)
1225088853 -> 1526 [CDialog::updateRouteSet] there are 0 record-route headers
1225088853 -> [CForkedBranch::setFinalResponse] pResponse=0x839d740.
1225088853 -> [CForkedBranch::setFinalResponse] response=404.
1225088853 -> 1126[CMotorCall::responseToInviteOrCancel] no response to the CH m
_cancelSent=0.
1225088853 -> 1126[CMotorCall::responseToInviteOrCancel] all responses are recei
ved 1.
1225088853 -> 1126[CMotorCall::responseToInviteOrCancel] call chooseBestResponse
1225088853 -> 1126[CMotorCall::chooseBestResponse] pForkedBranch=0x839e5b8 iResp
onseCode=2000.
1225088853 -> [CForkedBranch::getResponseCode] response=404.
1225088853 -> 1126[CMotorCall::chooseBestResponse] last iResponseCode=404.
1225088853 -> 1126[CMotorCall::chooseBestResponse] next branch.
1225088853 -> 1126[CMotorCall::responseToInviteOrCancel] inviteResponse => updat
e the lastInviteContext.
1225088853 -> [receiveRequestFailureMessage] Call: c17a10169709eabe07c606b3f1bbb
ec4@203.36.12.10 eqt: 1036 PROCEEDING_STATE received a message.
1225088853 -> 1126[CMotorCall::emitEventToMonitel] content size (lginfo): 652
1225088853 -> 1126[CMotorCall::emitEventToMonitel] CAC = 0 eqtCAC = -1
1225088853 -> [ipc_thread] IPC Thread : Ipc reception.
1225088853 -> [ipc_thread] IPC Thread : TCL thread signaled.
1225088853 -> 1126[CMotorCall::emitEventToMonitel] Event sent on eqt : 1036
1225088853 -> [display_ipc_out] ------------ Begin ---------------
1225088853 -> REQUEST FAILURE
1225088853 -> xx : 4
1225088853 -> RELATIVE REQUEST : INVITE
1225088853 -> [display_ipc_out] ------------- End ----------------
1225088853 -> 1126[CMotorCall::onReceiveResponse] INVITE case => cancelAllCancel
ableForkedBranch.
1225088853 -> 1126[CMotorCall::cancelAllCancelableForkedBranch] nb branch=1.
1225088853 -> [exec_ipc] in.
1225088853 -> [display_ipc_in] ------------ Begin ---------------
1225088853 -> neqt : 1036
1225088853 -> SIP EQT RELEASED
1225088853 -> [display_ipc_in] ------------- End ----------------
1225088853 -> [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the
eqt 1036.
1225088853 -> [CMotorCallManager::onIncomingEvent] The call with eqt: 1036 has r
eleased its equipment.
1225088853 -> 1126[CMotorCall::unRegister] Remove eqt : 1036 from the map.
1225088853 -> [CMotorCallManager::eraseCallwithEqt] CMotorCall 1036 erased.
1225088853 -> [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
1225088853 -> [CMotorCallManager::onIncomingEvent] killSession.
1225088853 -> 1126 [CCall::killSession]
1225088853 -> 2124 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1225088853 -> 2124 [CTransaction::freeTimerToken] Timer D is freed
1225088853 -> 2124 [CTransaction::changeState] no transaction state
1225088853 -> 1126 [CCall::onKill Session Call manager close is called]
1225088853 -> 1126 [CCall::killSession] notifying the call manager
1225088853 -> 102 [CCallManager::onCallClosed]
1225088853 -> 102 [CCallManager::onCallClosed()] removing from the maps
1225088853 -> [CMotorCallManager::onNotifyCallClosed] Call : c17a10169709eabe07c
606b3f1bbbec4@203.36.12.10 is closed.
1225088853 -> [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1225088853 -> [CCall::onKill] set callmanager to null
1225088853 -> [CTransaction::notifyDialog]
1225088853 -> [CTransaction::notifyDialog] notify parent dialog
1225088853 -> 1526 [CDialog::onTransactionState(pTrans = 2124, previousState = n
ull, currentState = Terminated, reason = None]
1225088853 -> 1526 [CDialog::onTransactionState] dialog is terminated
1225088853 -> 1526 [CDialog::onTransactionState] onDialogClosed
1225088853 -> 1126 [CCall::onDialogClosed]
1225088853 -> 1126 [CCall::onDialogClosed] only initial *********
1225088853 -> 1126 [CCall::onDialogClosed] All the initial dialogs in the Call a
re closed
1225088853 -> 4A [~CRequest] req c17a10169709eabe07c606b3f1bbbec4@203.36.12.10 9
68417036 ACK
1225088854 -> 102 [CCallManager::removeGarbage] at index i = 0
1225088854 -> 1126[CMotorCall::~CMotorCall] Call : c17a10169709eabe07c606b3f1bbb
ec4@203.36.12.10 is being destructed.
1225088854 -> 48 [~CResponse] resp(404) c17a10169709eabe07c606b3f1bbbec4@203.36.
1225088854 -> 1126 [CCall::~CCall]
1225088854 -> 1126 [CCall::removeGarbage]
1225088854 -> 1526 [CDialog::~CDialog]
1225088854 -> [---*--- SESSION-TIMER ---*---] Free CSessionTimerContext
1225088854 -> 49 [~CRequest] req c17a10169709eabe07c606b3f1bbbec4@203.36.12.10 9
68417036 INVITE
INBOUND CALLS
1225088753 -> 1125 [CCall::receiveRequest] INVITE
1225088753 -> 1125 [CCall::getDialog] Confirmed Dialog is not found (ID = ;34340
77754-545230)
1225088753 -> 1125 [CCall::getDialog] Returning Initial Dialog Server
1225088753 -> 1525 [CDialog::receiveRequest]
1225088753 -> 1525 [CDialog::receiveInviteRequest]
1225088753 -> 2123 [CTransaction::changeState] STATE CHANGED TO INITIAL
1225088753 -> 2123 [CTransaction::changeState] notifying the parent dialog
1225088753 -> 1525 [CDialog::onTransactionState(pTrans = 2123, previousState = T
1225088753 -> 2123 [CTransInitialState::receiveRequest] Transaction changes to P
roceeding state
1225088753 -> 2123 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
1225088753 -> 1525 [CDialog::onTransactionState(pTrans = 2123, previousState = I
nitial, currentState = Proceeding, reason = Request reception]
1225088753 -> 2123 [CTransProceedingState::createResponse] CResponse 45 ref=1
1225088753 -> 45 [CMessage::send] sip_sendMessage (125.254.25.4:5060)
1225088753 -> SEND MESSAGE TO NETWORK (125.254.25.4:5060 [UDP]) (BUFF LEN = 332)
SIP/2.0 100 Trying
To: <sip:0290083901@203.194.24.28:5060;user=phone;transport=udp>
From: <sip:283066276@125.254.25.4>;tag=3434077754-545230
Call-ID: 1951982-3434077754-545220@MSX01-KENT-SYD.comindico.com.au
CSeq: 1 INVITE
Via: SIP/2.0/UDP 125.254.25.4:5060;branch=z9hG4bK4ab14647e37aa97f834f5e2f44c6ace
c
Content-Length: 0
1225088753 -> 1525 [CDialog::receiveInviteRequest] a new Server INVITE transact
ion is in progress
1225088753 -> [---*--- SESSION-TIMER ---*---] New CSessionTimerContext from requ
est (Server, UA)
1225088753 -> [---*--- SESSION-TIMER ---*---] Update CSessionTimerContext (refre
sh reception)
1225088753 -> [---*--- SESSION-TIMER ---*---] Session-Expires updated : 3600
1225088753 -> [---*--- SESSION-TIMER ---*---] Refresher updated : r
1225088753 -> 1125 [CCall::checkAuthentication] INVITE
1225088753 -> 1125[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Contr
ol authentication
1225088753 -> [CGwMngData::isAuthenticationRequiredForThisClient] 125.254.25.4 .
1225088753 -> [isDomainFromGwExt] Host from request is : 125.254.25.4.
1225088753 -> [isDomainFromGwExt] User from request is : 283066276
1225088753 -> [isDomainFromGwExt]-->gw_ext_save=0
1225088753 -> domain from External Gateway 0.
1225088753 -> 1125[CMotorCall::toGatewayOrProxy] request for proxydomain=203.36.
12.10.
1225088753 -> [isUserRegistred] getRegistration=0290083901.
1225088753 -> [isUserRegistred] result=-1.
1225088753 -> 1125[CMotorCall::onReceiveRequest] request for gateway.
1225088753 -> 1125[CMotorCall::onReceiveRequest] state = INITIAL_STATE.
1225088753 -> 1125[CMotorCall::methodInviteReceived] nb available licenses=99999
1225088753 -> 1125[CMotorCall::compareDialogFromContext] presumed to be the same
Dialog
1225088753 -> 1125[CMotorCall::methodInviteReceived] Invite => update the invite
Context.
1225088753 -> [CForkedBranch::CForkedBranch] context = 0x839d57c.
1225088753 -> 1125[CMotorCall::methodInviteReceived] CAC = 0
1225088753 -> [receiveInviteMessage] Call: 1951982-3434077754-545220@MSX01-KENT-
SYD.comindico.com.au eqt: -1 INITIAL_STATE received a message.
1225088753 -> [decodeInviteCLIR].
1225088753 -> [decodeInvitePAssertedId].
1225088753 -> [isValidGwExt] ext gw 0 is valid
1225088753 -> [isSessionTimerTooSmall].
1225088753 -> [decodeInviteSDP].
1225088753 -> [checkSdpValidity] Sdp contains 1 media description(s).
1225088753 -> [checkSdpValidity] Media 0 type 1 contains 16 formats.
1225088753 -> [checkSdpValidity] Format : 18.
1225088753 -> [convertSdpIntoTsdp] Sdp contains 1 media description(s).
1225088753 -> [convertSdpIntoTsdp] The audio media contains 16 format(s).
1225088753 -> [convertSdpIntoTsdp] Format 0 is 18.
1225088753 -> [convertSdpIntoTsdp] Format 1 is 0.
1225088753 -> [convertSdpIntoTsdp] Format 2 is 8.
1225088753 -> [convertSdpIntoTsdp] Format 3 is 99.
1225088753 -> [convertSdpIntoTsdp] Format 4 is 102.
1225088753 -> [convertSdpIntoTsdp] Format 5 is 2.
1225088753 -> [convertSdpIntoTsdp] Format 6 is 103.
1225088753 -> [convertSdpIntoTsdp] Format 7 is 4.
1225088753 -> [convertSdpIntoTsdp] Format 8 is 104.
1225088753 -> [convertSdpIntoTsdp] Format 9 is 3.
1225088753 -> [convertSdpIntoTsdp] Format 10 is 105.
1225088753 -> [convertSdpIntoTsdp] Format 11 is 106.
1225088753 -> [convertSdpIntoTsdp] Format 12 is 107.
1225088753 -> [convertSdpIntoTsdp] Format 13 is 125.
1225088753 -> [convertSdpIntoTsdp] Format 14 is 101.
1225088753 -> [convertSdpIntoTsdp] Format 15 is 100.
1225088753 -> [convertSdpIntoTsdp] Get the direction.
1225088753 -> [convertSdpIntoTsdp] Direction is sendrecv.
1225088753 -> [convertSdpIntoTsdp] The connection is at session level.
1225088753 -> [convertSdpIntoTsdp] Connection address retrieved in sdp: 125.254.
25.65.
1225088753 -> [convertIPStrIntoTuipv] 125.254.25.65 => 125.254.25.65
1225088753 -> [isCACWithInvalidMediaAddr].
1225088753 -> [decodeInviteTo].
1225088753 -> [decodeInviteReferredBy].
1225088753 -> [receiveInviteMessage] ReferBy = Zero indirect=1
1225088753 -> [decodeInviteACSBU].
1225088753 -> 1125[CMotorCall::emitEventToMonitel] content size (lginfo): 652
1225088753 -> [ipc_thread] IPC Thread : Ipc reception.
1225088753 -> [ipc_thread] IPC Thread : TCL thread signaled.
1225088753 -> [CMotorCallManager::insertCallwithEqt] CMotorCall 1036 inserted.
1225088753 -> 1125[CMotorCall::emitEventToMonitel] Event sent on eqt : 1036
1225088753 -> [display_ipc_out] ------------ Begin ---------------
1225088753 -> INVITE
1225088753 -> REQUEST URI : <> 0290083901@203.36.12.10:5060 ; user=phone
1225088753 -> FROM : <> 283066276@125.254.25.4:5060 ; user=name
1225088753 -> TO : <> 0290083901@203.194.24.28:5060 ; user=phone
1225088753 -> CAC : 0
1225088753 -> CAC ADDRESS :
1225088753 -> CLIR : 0
1225088753 -> SDP :
1225088753 -> ADDRESS : 125.254.25.65 :21120
1225088753 -> ALGOS :
1225088753 -> G729
1225088753 -> PCMU
1225088753 -> PCMA
1225088753 -> G723
1225088753 -> 101
1225088753 -> DIRECTION : SEND & RECEIVE
1225088753 -> N_GW_EXT : 0
1225088753 -> [display_ipc_out] ------------- End ----------------
1225088753 -> [exec_ipc] in.
1225088753 -> [display_ipc_in] ------------ Begin ---------------
1225088753 -> neqt : 1036
1225088753 -> SERVER FAILURE
1225088753 -> xx : 0
1225088753 -> RELATIVE REQUEST : INVITE
1225088753 -> [display_ipc_in] ------------- End ----------------
1225088753 -> [CMotorCallManager::onIncomingEvent] an event 10768 arrived on the
eqt 1036.
1225088753 -> [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
1225088753 -> [onIncomingEvent] SERVER FAILURE arrived.
1225088753 -> [receiveServerFailureEvent] Call: 1951982-3434077754-545220@MSX01-
KENT-SYD.comindico.com.au eqt: 1036 PROCEEDING_STATE received an event.
1225088753 -> [receiveServerFailureEvent] incoming call.
1225088753 -> 1125 [CCall::makeGenericResponse] 500
77754-545230)
1225088753 -> 1525 [CDialog::createResponse] 500
1225088753 -> 2123 [CTransProceedingState::createResponse] CResponse 46 ref=1
1225088753 -> 46 [CMessage::send] sip_sendMessage (125.254.25.4:5060)
1225088753 -> SEND MESSAGE TO NETWORK (125.254.25.4:5060 [UDP]) (BUFF LEN = 411)
SIP/2.0 500 Internal Server Error
To: <sip:0290083901@203.194.24.28:5060;user=phone;transport=udp>;tag=ccfd084bda8
89936f333e59e78b570db
CSeq: 1 INVITE
c
Content-Length: 0
1225088753 -> 45 [~CResponse] resp(100) 1951982-3434077754-545220@MSX01-KENT-SYD
.comindico.com.au 1 INVITE
1225088753 -> 2123 [CTransProceedingState::createResponse] Final : Transaction c
1225088753 -> 2123 [CTransaction::changeState] STATE CHANGED TO COMPLETED
1225088753 -> 1525 [CDialog::onTransactionState(pTrans = 2123, previousState = P
roceeding, currentState = Completed, reason = Final resp creation]
1225088753 -> 2123 [CTransaction::startTimer] Timer G is started (delay = 500 ms
1225088753 -> 2123 [CTransaction::startTimer] Timer H is started (delay = 32000
ms)
1225088753 -> 1525 [CDialog::updateRouteSet] there are 0 record-route headers
1225088753 -> RECEIVE MESSAGE FROM NETWORK (125.254.25.4:50195 [UDP])
ACK sip:0290083901@203.36.12.10;user=phone SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
BE, PRACK
c
Contact: <sip:283066276@125.254.25.4:5060;user=phone;transport=udp>
Content-Length: 0
1225088753 -> 48 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWO
RK)
1225088753 -> [CIOCom::receiveRequest] Received CRequest 48 ref=1
1225088753 -> [CDispatcher::onIncomingRequest()]
1225088753 -> [CDispatcher::processRequestFromManagerIndex()] start at index 0
1225088753 -> 102 [CCallManager::onIncomingRequest()]
1225088753 -> 1125 [CCall::receiveRequest] ACK
1225088753 -> 1125 [CCall::getDialog] Confirmed Dialog is not found (ID = ccfd08
4bda889936f333e59e78b570db;3434077754-545230)
1225088753 -> 1525 [CDialog::receiveAckRequest]
1225088753 -> 2123 [CTransCompletedState::receiveRequest] ACK(UDP) : Transaction
changes to Confirmed state
1225088753 -> 2123 [CTransaction::changeState] STATE CHANGED TO CONFIRMED
1225088753 -> 1525 [CDialog::onTransactionState(pTrans = 2123, previousState = C
ompleted, currentState = Confirmed, reason = Request reception]
1225088753 -> 2123 [CTransaction::freeTimerToken] Timer G is freed
1225088753 -> 2123 [CTransaction::freeTimerToken] Timer H is freed
1225088753 -> 2123 [CTransaction::startTimer] Timer I is started (delay = 5000 m
s)
1225088753 -> 1525 [CDialog::receiveAckRequest] receiving an ACK on a previously
rejected INVITE
1225088753 -> 1125 [CCall::checkAuthentication] ACK
ol authentication
1225088753 -> 1125[CMotorCall::controlAuthentication] ---*--- END ---*--- Contro
l authentication
12.10.
1225088753 -> 1125[CMotorCall::onReceiveRequest] state = TERMINATED_STATE.
1225088753 -> 1125[CMotorCall::compareDialogFromContext] same Dialog
1225088753 -> 1125[CMotorCall::methodAckReceived] Ack => update the inviteContex
t.
1225088753 -> [receiveAckMessage] Call: 1951982-3434077754-545220@MSX01-KENT-SYD
.comindico.com.au eqt: 1036 TERMINATED_STATE received a message.
1225088753 -> 1125[CMotorCall::emitEventToMonitel] CAC = 0 eqtCAC = -1
1225088753 -> ACK
1225088753 -> SIP EQT RELEASED
1225088753 -> [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the
eqt 1036.
1225088753 -> [CMotorCallManager::onIncomingEvent] The call with eqt: 1036 has r
1225088753 -> 1125[CMotorCall::unRegister] Remove eqt : 1036 from the map.
1225088753 -> [CMotorCallManager::eraseCallwithEqt] CMotorCall 1036 erased.
1225088753 -> [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
1225088753 -> [CMotorCallManager::onIncomingEvent] killSession.
1225088753 -> 1125 [CCall::killSession]
1225088753 -> 2123 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1225088753 -> 2123 [CTransaction::freeTimerToken] Timer I is freed
1225088753 -> 2123 [CTransaction::changeState] no transaction state
1225088753 -> 1125 [CCall::onKill Session Call manager close is called]
1225088753 -> 1125 [CCall::killSession] notifying the call manager
1225088753 -> 102 [CCallManager::onCallClosed]
1225088753 -> 102 [CCallManager::onCallClosed()] removing from the maps
1225088753 -> [CMotorCallManager::onNotifyCallClosed] Call : 1951982-3434077754-
545220@MSX01-KENT-SYD.comindico.com.au is closed.
1225088753 -> [CMotorCallManager::onNotifyCallClosed] call processResponse.
1225088753 -> 1125[CMotorCall::processResponse] call chooseBestResponse.
1225088753 -> 1125[CMotorCall::chooseBestResponse] pForkedBranch=0x839f280 iResp
onseCode=2000.
1225088753 -> [CForkedBranch::getResponseCode] response=2000.
1225088753 -> 1125[CMotorCall::chooseBestResponse] next branch.
1225088753 -> 1125[CMotorCall::processResponse] no response found.
1225088753 -> [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1225088753 -> [CCall::onKill] set callmanager to null
1225088753 -> [CTransaction::notifyDialog]
1225088753 -> [CTransaction::notifyDialog] notify parent dialog
1225088753 -> 1525 [CDialog::onTransactionState(pTrans = 2123, previousState = n
1225088753 -> 1525 [CDialog::onTransactionState] dialog is terminated
1225088753 -> 1525 [CDialog::onTransactionState] onDialogClosed
1225088753 -> 1125 [CCall::onDialogClosed]
1225088753 -> 1125 [CCall::onDialogClosed] only initial *********
1225088753 -> 1125 [CCall::onDialogClosed] All the initial dialogs in the Call a
re closed
1225088753 -> 48 [~CRequest] req 1951982-3434077754-545220@MSX01-KENT-SYD.comind
ico.com.au 1 ACK
1225088754 -> 102 [CCallManager::removeGarbage] at index i = 0
1225088754 -> 1125[CMotorCall::~CMotorCall] Call : 1951982-3434077754-545220@MSX
01-KENT-SYD.comindico.com.au is being destructed.
1225088754 -> 1125 [CCall::~CCall]
1225088754 -> 1125 [CCall::removeGarbage]
1225088754 -> 1525 [CDialog::~CDialog]
1225088754 -> [---*--- SESSION-TIMER ---*---] Free CSessionTimerContext
1225088754 -> 46 [~CResponse] resp(500) 1951982-3434077754-545220@MSX01-KENT-SYD
1225088754 -> 47 [~CRequest] req 1951982-3434077754-545220@MSX01-KENT-SYD.comind
ico.com.au 1 INVITE
alcatelboy
hello, from the trace message , i seem it can outgoing call but not test the incoming call.
see below:
(1)xa000000> traced +----------------------------------+
** UNIX-trace-daemon started ... (static user group No 1) **
traced started ...
1225586962 -> DECT: get_redial_nb_cells nb_cells=4 tiny=0
1225586962 -> DECT: get_redial_nb_cells nb_cells=5 tiny=0
1225586962 -> [ipc_thread] IPC Thread : Ipc reception.
1225586962 -> [ipc_thread] IPC Thread : TCL thread signaled.
1225586962 -> [exec_ipc] in.
1225586962 -> [display_ipc_in] ------------ Begin ---------------
1225586962 -> neqt : 1036
1225586962 -> INVITE
1225586962 -> REQUEST URI : <> 0437407840@125.254.25.4:5060 ; user=phone
1225586962 -> FROM : <0290083901> 0290083901@203.36.12.10:5060 ; user=name
1225586962 -> TO : <> 0437407840@125.254.25.4:5060 ; user=phone
1225586962 -> CAC : 0
1225586962 -> neqt CAC : -1
1225586962 -> CLIR : 0
1225586962 -> SDP :
1225586962 -> ADDRESS : 203.36.12.2 :32514
1225586962 -> ALGOS :
1225586962 -> PCMA
1225586962 -> PCMU
1225586962 -> G723
1225586962 -> 97
1225586962 -> DIRECTION : SEND & RECEIVE
1225586962 -> N_GW_EXT : 0
1225586962 -> [display_ipc_in] ------------- End ----------------
1225586962 -> [CMotorCallManager::onIncomingEvent] an event 10752 arrived on the eqt 1036.
1225586962 -> [CMotorCallManager::onIncomingEvent] New Call created.
1225586962 -> [CMotorCallManager::callFactory].
1225586962 -> [CMotorCallManager::callFactory]=839e048.
1225586962 -> [CMotorCallManager::onIncomingEvent] eqt=1036.
1225586962 -> [CMotorCallManager::insertCallwithEqt] CMotorCall 1036 inserted.
1225586962 -> [CMotorCallManager::onIncomingEvent] state = INITIAL_STATE.
1225586962 -> [onIncomingEvent] INVITE arrived.
1225586962 -> [receiveInviteEvent] Call: eqt: 1036 INITIAL_STATE received an event.
1225586962 -> 1161[CMotorCall::emitInviteMessage] begin.
1225586962 -> [isValidGwExt] ext gw 0 is valid
1225586962 -> 1161[CMotorCall::inviteBuildAurlWithBelongingDomain] bres2=0
1225586962 -> [quoteString] => "0290083901"
1225586962 -> 1161[CMotorCall::inviteBuildAurlWithBelongingDomain] P-Asserted-Identity: "0290083901" <sip:02900839
01@125.254.25.4>
1225586962 -> 1161[CMotorCall::emitInviteMessage] From: "0290083901" <sip:0290083901@125.254.25.4>
1225586962 -> 1161[CMotorCall::emitInviteMessage] reqUri :sip:0437407840@125.254.25.4;user=phone
1225586962 -> 1161[CMotorCall::inviteBuildSupportedHeader] Invite directed to external gw : 0
1225586962 -> 1161[CMotorCall::emitInviteMessage] Request Uri : sip:0437407840@125.254.25.4;user=phone
1225586962 -> 1161[CMotorCall::emitInviteMessage] To: <sip:0437407840@125.254.25.4;user=phone>
1225586962 -> 1161[CMotorCall::emitInviteMessage] Contact: sip:203.36.12.10
1225586963 -> 1161[CMotorCall::makeRequestSdp] Begin sdp : v=0
o=OXE 1225586962 1225586962 IN IP4 203.36.12.10
s=-
c=IN IP4 0.0.0.0
t=0 0
1225586963 -> 1161[CMotorCall::makeRequestSdp] Direction: 0.
1225586963 -> 1161[CMotorCall::makeResponseSdp] format 97
1225586963 -> 1161[CMotorCall::makeRequestSdp] Final sdp: v=0
s=abs
c=IN IP4 203.36.12.2
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=ptime:20
a=maxptime:30
a=ptime:30
a=maxptime:30
1225586963 -> 1161[CMotorCall::emitInviteMessage] The sdp build: .
1225586963 -> 1161[CMotorCall::new_determineTargetsForTheRequest] is not Responsible For This URI.
1225586963 -> 1161[CMotorCall::makeInitialMotorRequest] nb contacts=1.
1225586963 -> 1161[CMotorCall::makeInitialMotorRequest] *pcszNameToFind : 0437407840
1225586963 -> 1161[CMotorCall::makeInitialMotorRequest]-->extGw=0
1225586963 -> 1161[CMotorCall::makeInitialMotorRequest] contact : sip:0437407840@125.254.25.4;user=phone
1225586963 -> 1161[CMotorCall::makeInitialMotorRequest] nb available licenses=99999 .
1225586963 -> 1161[CMotorCall::makeInitialMotorRequest] req_Uri_OK=0
1225586963 -> 1161[CMotorCall::makeInitialMotorRequest]-->pSipAddSpec->getHost()=125.254.25.4
1225586963 -> 1161[CMotorCall::makeInitialMotorRequest] user= 0437407840
1225586963 -> [CGWMngData::isMainServer] CPU is MAIN.
1225586963 -> 1161 [CCall::makeGenericRequest] INVITE
1225586963 -> 1161 [CCall::getDialog] Confirmed Dialog is not found (ID = ;)
1225586963 -> 1161 [CCall::getDialog] Returning Initial Dialog Client
1225586963 -> 1561 [CDialog::createRequest]
1225586963 -> 1561 [CDialog::buildServicesForAllRequest]
1225586963 -> 1561 [CDialog::createInviteRequest]
1225586963 -> 2160 [CTransaction::changeState] STATE CHANGED TO INITIAL
1225586963 -> 2160 [CTransaction::changeState] notifying the parent dialog
1225586963 -> 1561 [CDialog::onTransactionState(pTrans = 2160, previousState = Terminated, currentState = Initial,
reason = None]
1225586963 -> C0 [CRequest::CRequest] Creation of a request
1225586963 -> C0 [CMessage::send] sip_sendMessage (125.254.25.4:5060)
1225586963 -> SEND MESSAGE TO NETWORK (125.254.25.4:5060 [UDP]) (BUFF LEN = 881)
INVITE sip:0437407840@125.254.25.4;user=phone SIP/2.0
P-Asserted-Identity: "0290083901" <sip:0290083901@125.254.25.4>
From: "0290083901" <sip:0290083901@125.254.25.4>;tag=48d620b732a6a960e8dbe3591dc23f9f
Call-ID: a0724114c599302eec5e699c56e3f7ab@203.36.12.10
CSeq: 1343123546 INVITE
Via: SIP/2.0/UDP 203.36.12.10;branch=z9hG4bK4aa0502bfa042365267ab7fef4835683
Max-Forwards: 70
Content-Length: 315
v=0
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
a=ptime:20
a=maxptime:30
a=ptime:30
a=maxptime:30
1225586963 -> 2160 [CTransInitialState::createRequest] Transaction changes to Calling state
1225586963 -> 2160 [CTransaction::changeState] STATE CHANGED TO CALLING
1225586963 -> 1561 [CDialog::onTransactionState(pTrans = 2160, previousState = Initial, currentState = Calling, re
1225586963 -> 2160 [CTransaction::startTimer] Timer A is started (delay = 500 ms)
1225586963 -> 2160 [CTransaction::startTimer] Timer B is started (delay = 32000 ms)
1225586963 -> [---*--- SESSION-TIMER ---*---] New CSessionTimerContext from request (Client, UA)
1225586963 -> [---*--- SESSION-TIMER ---*---] Update CSessionTimerContext (refresh creation)
1225586963 -> 1161[CMotorCall::makeInitialMotorRequest] nb contact=1.
1225586963 -> [CForkedBranch::CForkedBranch] context = 0x839e13c.
1225586963 -> 1161[CMotorCall::branchAllocation] built branch number=1.
1225586963 -> [onIncomingEvent] CallID must be inserted.
1225586963 -> [onIncomingEvent] CallID inserted.
1225586963 -> RECEIVE MESSAGE FROM NETWORK (125.254.25.4:50195 [UDP])
SIP/2.0 100 Trying
Content-Length: 0
1225586963 -> [CIOCom::receiveResponse] CResponse BF ref=1
1225586963 -> [CDispatcher::onIncomingResponse]
1225586963 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1225586963 -> 102 [CCallManager::onIncomingResponse]
1225586963 -> 1161 [CCall::receiveResponse] 100
1225586963 -> 1161 [CCall::receiveResponse]Trying to find the right dialog
1225586963 -> 1161 [CCall::getDialog] Confirmed Dialog is not found (ID = 48d620b732a6a960e8dbe3591dc23f9f;)
1225586963 -> 1161 [CCall::receiveResponse]One dialog found
1225586963 -> 1561 [CDialog::receiveResponse]
1225586963 -> 2160 [CTransCallingState::receiveResponse] Provisional : Transaction changes to Proceeding state
1225586963 -> 2160 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
1225586963 -> 1561 [CDialog::onTransactionState(pTrans = 2160, previousState = Calling, currentState = Proceeding,
1225586963 -> 2160 [CTransaction::freeTimerToken] Timer A is freed
1225586963 -> 2160 [CTransaction::freeTimerToken] Timer B is freed
1225586963 -> 1161[CMotorCall::searchForkedBranch]pForkedBranch=0x83b0d80.
1225586963 -> [receiveInformationalMessage] Call: a0724114c599302eec5e699c56e3f7ab@203.36.12.10 eqt: 1036 PROCEEDI
1225586965 -> RECEIVE MESSAGE FROM NETWORK (125.254.25.4:50195 [UDP])
SIP/2.0 183 Session Progress
To: <sip:0437407840@125.254.25.4;user=phone>;tag=3434575974-886308
Allow: INVITE, BYE, OPTIONS, CANCEL, ACK, REGISTER, NOTIFY, INFO, REFER, SUBSCRIBE, PRACK
Contact: <sip:0437407840@125.254.25.4:5060;user=phone>
Call-Info: <sip:125.254.25.4>;method="NOTIFY;Event=telephone-event;Duration=1000"
Content-Length: 226
v=0
o=MSX01-KENT-SYD 1874411 0 IN IP4 125.254.25.4
s=sip call
c=IN IP4 125.254.25.65
t=0 0
m=audio 26388 RTP/AVP 8 101 100
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
1225586965 -> [CIOCom::receiveResponse] CResponse C0 ref=1
1225586965 -> [CDispatcher::onIncomingResponse]
1225586965 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1225586965 -> 102 [CCallManager::onIncomingResponse]
1225586965 -> 1161 [CCall::receiveResponse] 183
1225586965 -> 1161 [CCall::receiveResponse]Trying to find the right dialog
1225586965 -> 1161 [CCall::getDialog] Confirmed Dialog is not found (ID = 48d620b732a6a960e8dbe3591dc23f9f;3434575
974-886308)
1225586965 -> 1161 [CCall::receiveResponse]One dialog found
1225586965 -> 1561 [CDialog::receiveResponse]
1225586965 -> BF [~CResponse] resp(100) a0724114c599302eec5e699c56e3f7ab@203.36.12.10 1343123546 INVITE
1225586965 -> 1561 [CDialog::updateRouteSet] there are 0 record-route headers
1225586965 -> 1161[CMotorCall::searchForkedBranch]pForkedBranch=0x83b0d80.
1225586965 -> [receiveInformationalMessage] Call: a0724114c599302eec5e699c56e3f7ab@203.36.12.10 eqt: 1036 PROCEEDI
1225586965 -> [checkSdpValidity] Sdp contains 1 media description(s).
1225586965 -> [checkSdpValidity] Media 0 type 1 contains 3 formats.
1225586965 -> [checkSdpValidity] Format : 8.
1225586965 -> [convertSdpIntoTsdp] Sdp contains 1 media description(s).
1225586965 -> [convertSdpIntoTsdp] The audio media contains 3 format(s).
1225586965 -> [convertSdpIntoTsdp] Format 0 is 8.
1225586965 -> [convertSdpIntoTsdp] Format 1 is 101.
1225586965 -> [convertSdpIntoTsdp] Format 2 is 100.
1225586965 -> [convertSdpIntoTsdp] Get the direction.
1225586965 -> [convertSdpIntoTsdp] Direction is sendrecv.
1225586965 -> [convertSdpIntoTsdp] The connection is at session level.
1225586965 -> [convertSdpIntoTsdp] Connection address retrieved in sdp: 125.254.25.65.
1225586965 -> [convertIPStrIntoTuipv] 125.254.25.65 => 125.254.25.65
1225586965 -> 1161[CMotorCall::emitEventToMonitel] content size (lginfo): 652
1225586965 -> 1161[CMotorCall::emitEventToMonitel] CAC = 0 eqtCAC = -1
1225586965 -> 1161[CMotorCall::emitEventToMonitel] Event sent on eqt : 1036
1225586965 -> [display_ipc_out] ------------ Begin ---------------
1225586965 -> INFORMATIONAL
1225586965 -> xx : 83
1225586965 -> RELATIVE REQUEST : INVITE
1225586965 -> SDP :
1225586965 -> ADDRESS : 125.254.25.65 :26388
1225586965 -> ALGOS :
1225586965 -> PCMA
1225586965 -> 101
1225586965 -> DIRECTION : SEND & RECEIVE
1225586965 -> [display_ipc_out] ------------- End ----------------
1225586968 -> RECEIVE MESSAGE FROM NETWORK (125.254.25.4:50195 [UDP])
SIP/2.0 200 OK
Content-Length: 226
v=0
s=sip call
t=0 0
a=fmtp:101 0-15
a=fmtp:100 192-194
1225586968 -> [CIOCom::receiveResponse] CResponse C1 ref=1
1225586968 -> [CDispatcher::onIncomingResponse]
1225586968 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1225586968 -> 102 [CCallManager::onIncomingResponse]
1225586968 -> 1161 [CCall::receiveResponse] 200
1225586968 -> 1161 [CCall::receiveResponse]Trying to find the right dialog
1225586968 -> 1161 [CCall::getDialog] Confirmed Dialog is not found (ID = 48d620b732a6a960e8dbe3591dc23f9f;3434575
974-886308)
1225586968 -> 1161 [CCall::receiveResponse]One dialog found
1225586968 -> 1561 [CDialog::receiveResponse]
1225586968 -> 1561 [CDialog::receiveResponse] create a CONFIRMED dialog
1225586968 -> 1562 [CDialog::CDialog] look for the transaction #0, transaction key = z9hG4bK4aa0502bfa042365267ab7
fef4835683
1225586968 -> 1562 [CDialog::CDialog] copy the transaction #0, transaction key = z9hG4bK4aa0502bfa042365267ab7fef4
835683
1225586968 -> 2161 [CTransaction::CTransaction] Transaction is cloned in 4 state
1225586968 -> 1562 [CDialog::startDialogTTL]
1225586968 -> 1562 [CDialog::receiveResponse]
1225586968 -> 2161 [CTransProceedingState::receiveResponse] Final : Transaction changes to Completed state
1225586968 -> 2161 [CTransaction::changeState] STATE CHANGED TO COMPLETED
1225586968 -> 2161 [CTransaction::changeState] notifying the parent dialog
1225586968 -> 1562 [CDialog::onTransactionState(pTrans = 2161, previousState = Proceeding, currentState = Complete
1225586968 -> 2161 [CTransaction::startTimer] Timer D is started (delay = 32433 ms)
1225586968 -> [---*--- SESSION-TIMER ---*---] New CSessionTimerContext from response (Client, UA)
1225586968 -> [---*--- SESSION-TIMER ---*---] Update CSessionTimerContext (response refresh reception)
1225586968 -> [---*--- SESSION-TIMER ---*---] No refresh
1225586968 -> 1562 [CDialog::updateRouteSet] there are 0 record-route headers
1225586969 -> 1161 [CCall::insertInDialogMap] added dialog #1562 with the key 48d620b732a6a960e8dbe3591dc23f9f;343
4575974-886308
1225586969 -> 1561 [CDialog::updateRouteSet] there are 0 record-route headers
1225586969 -> 1161[CMotorCall::searchForkedBranch]pForkedBranch=0x83b0d80.
1225586969 -> [CForkedBranch::setFinalResponse] pResponse=0x83a16b8.
1225586969 -> [CForkedBranch::setFinalResponse] response=200.
1225586969 -> 1161[CMotorCall::responseToInviteOrCancel] call chooseBestResponse.
1225586969 -> 1161[CMotorCall::chooseBestResponse] pForkedBranch=0x83b0d80 iResponseCode=2000.
1225586969 -> [CForkedBranch::getResponseCode] response=200.
1225586969 -> 1161[CMotorCall::chooseBestResponse] last iResponseCode=200.
1225586969 -> 1161[CMotorCall::chooseBestResponse] next branch.
1225586969 -> 1161[CMotorCall::responseToInviteOrCancel] inviteResponse => update the lastInviteContext.
1225586969 -> [receiveSuccessfulMessage] Call: a0724114c599302eec5e699c56e3f7ab@203.36.12.10 eqt: 1036 PROCEEDING_
1225586969 -> [checkSdpValidity] Sdp contains 1 media description(s).
1225586969 -> [checkSdpValidity] Media 0 type 1 contains 3 formats.
1225586969 -> [checkSdpValidity] Format : 8.
1225586969 -> [convertSdpIntoTsdp] Sdp contains 1 media description(s).
1225586969 -> [convertSdpIntoTsdp] default T38 config.
1225586969 -> [convertSdpIntoTsdp] The audio media contains 3 format(s).
1225586969 -> [convertSdpIntoTsdp] Format 0 is 8.
1225586969 -> [convertSdpIntoTsdp] Format 1 is 101.
1225586969 -> [convertSdpIntoTsdp] Format 2 is 100.
1225586969 -> [convertSdpIntoTsdp] Get the direction.
1225586969 -> [convertSdpIntoTsdp] Direction is sendrecv.
1225586969 -> [convertSdpIntoTsdp] The connection is at session level.
1225586969 -> [convertSdpIntoTsdp] Connection address retrieved in sdp: 125.254.25.65.
1225586969 -> [convertIPStrIntoTuipv] 125.254.25.65 => 125.254.25.65
1225586969 -> 1161[CMotorCall::emitEventToMonitel] content size (lginfo): 652
1225586969 -> 1161[CMotorCall::emitEventToMonitel] CAC = 0 eqtCAC = -1
1225586969 -> 1161[CMotorCall::emitEventToMonitel] Event sent on eqt : 1036
1225586969 -> [display_ipc_out] ------------ Begin ---------------
1225586969 -> SUCCESSFUL
1225586969 -> xx : 0
1225586969 -> RELATIVE REQUEST : INVITE
1225586969 -> CLIR : 0
1225586969 -> COLP : 0
1225586969 -> SDP :
1225586969 -> ADDRESS : 125.254.25.65 :26388
1225586969 -> ALGOS :
1225586969 -> PCMA
1225586969 -> 101
1225586969 -> DIRECTION : SEND & RECEIVE
1225586969 -> [display_ipc_out] ------------- End ----------------
1225586969 -> 1161[CMotorCall::onReceiveResponse] INVITE case => cancelAllCancelableForkedBranch.
1225586969 -> 1161[CMotorCall::cancelAllCancelableForkedBranch] nb branch=1.
1225586969 -> RECEIVE MESSAGE FROM NETWORK (125.254.25.4:50195 [UDP])
SIP/2.0 200 OK
Content-Length: 226
v=0
s=sip call
t=0 0
a=fmtp:101 0-15
a=fmtp:100 192-194
1225586969 -> [CIOCom::receiveResponse] CResponse C2 ref=1
1225586969 -> [CDispatcher::onIncomingResponse]
1225586969 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1225586969 -> 102 [CCallManager::onIncomingResponse]
1225586969 -> 1161 [CCall::receiveResponse] 200
1225586969 -> 1161 [CCall::receiveResponse]Trying to find the right dialog
1225586969 -> 1161 [CCall::getDialog] Confirmed Dialog found
1225586969 -> 1161 [CCall::receiveResponse]One dialog found
1225586969 -> 1562 [CDialog::receiveResponse]
1225586969 -> [---*--- SESSION-TIMER ---*---] Update CSessionTimerContext (response refresh reception)
1225586969 -> [---*--- SESSION-TIMER ---*---] No refresh
1225586969 -> C2 [~CResponse] resp(200) a0724114c599302eec5e699c56e3f7ab@203.36.12.10 1343123546 INVITE
1225586969 -> [ipc_thread] IPC Thread : Ipc reception.
1225586969 -> [ipc_thread] IPC Thread : TCL thread signaled.
1225586969 -> [exec_ipc] in.
1225586969 -> [display_ipc_in] ------------ Begin ---------------
1225586969 -> neqt : 1036
1225586969 -> ACK
1225586969 -> [display_ipc_in] ------------- End ----------------
1225586969 -> [CMotorCallManager::onIncomingEvent] an event 10754 arrived on the eqt 1036.
1225586969 -> [CMotorCallManager::onIncomingEvent] state = ACCEPTED_STATE.
1225586969 -> [onIncomingEvent] ACK arrived.
1225586969 -> [receiveAckEvent] Call: a0724114c599302eec5e699c56e3f7ab@203.36.12.10 eqt: 1036 ACCEPTED_STATE recei
ved an event.
1225586969 -> 1161[CMotorCall::emitAckMessage] begin.
1225586969 -> 1161[CMotorCall::emitAckMessage] SDP ok.
1225586969 -> 1161 [CCall::makeGenericRequest] ACK
1225586969 -> 1562 [CDialog::createRequest]
1225586969 -> 1562 [CDialog::buildServicesForAllRequest]
1225586969 -> 1562 [CDialog::createAckRequest]
1225586969 -> 1562 [CDialog::createAckRequest], previous trans 2161 is found
1225586969 -> 1562 [CDialog::createAckRequest], previous trans 2161 is client
1225586969 -> C1 [CRequest::CRequest] Creation of a request
1225586969 -> 1562 [CDialog::buildServicesForAck]
1225586969 -> C1 [CMessage::send] sip_sendMessage (125.254.25.4:5060)
1225586969 -> SEND MESSAGE TO NETWORK (125.254.25.4:5060 [UDP]) (BUFF LEN = 461)
ACK sip:0437407840@125.254.25.4:5060;user=phone SIP/2.0
CSeq: 1343123546 ACK
Via: SIP/2.0/UDP 203.36.12.10;branch=z9hG4bK299bf551f78a33523be373d942a471a9
Max-Forwards: 70
Content-Length: 0
1225586969 -> 2161 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1225586969 -> 2161 [CTransaction::freeTimerToken] Timer D is freed
1225586969 -> 2161 [CTransaction::changeState] no transaction state
1225586969 -> 1562 [CDialog::createAckRequest] successful INVITE is terminated after the ACK is sent
1225586969 -> [CTransaction::notifyDialog]
1225586969 -> [CTransaction::notifyDialog] notify parent dialog
1225586969 -> 1562 [CDialog::onTransactionState(pTrans = 2161, previousState = null, currentState = Terminated, re
1225586980 -> main.trace.timer = 480mn
AQPS ACFE ACSE
alcatelboy
please give me the new trace.thank
AQPS ACFE ACSE
alcatelguru
The above posted are the new traces.Thanks
alcatelboy
i need the incoming traces.
AQPS ACFE ACSE
Return to “H323 / Sip”
